Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 05-11-2017, 01:13 PM   #1
BlobeyeSTi
Member Sales Rating: (35)
Member#: 187877
Default WV - Garage Sale - WRX, STi, LGT, FXT parts
Parts list & pictures updated: 7/18/18
Mostly GD WRX & STi parts but some 04 FXT & 05 LGT parts
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
Thanks,
Tony
*Links to albums of individual pictures of each part are located beside each group*
04 FXT Pics: https://imgur.com/a/CM4Qgsf
• TMIC $35
• TMIC splitter $20
• BPV $20
• BPV hose $5
• 6 Disc $25
• Power steering pump $45
• Stock cat back exhaust $50
• Red OEM mud flaps $40 set
05 LGT Pics: https://imgur.com/a/gQPn9Vq
• Taillights $100 set
• Intake manifold $50
• Engine harness $50
• Throttle body $40
• Side feed TGVs $80
• Side feed fuel lines $50
• Turbo inlet $15
• Gauges auto $75
• ECU auto #22611AJ18B $100
• MAF #22680AA31A $35
• BPV $25
• BPV hose $5
• Airbox lid $5
• Intake pressure sensor #22012AA160 $5
• Purge valve $10
• Purge valve solenoid $15
• Boost solenoid controller $25
• 04-09 Legacy all weather subaru mats $40
• Auto momo shift knob $10
GD WRX & STi Parts
Engine & Drivetrain Pics: https://imgur.com/a/xYSVkuV
• DW200 $50
• EJ20 valve $40 set
• STi heads $450
• STi front axle $50
• STi clutch master $40
• STi clutch master line $20
• STi side feed fuel rails with line $50 set
• STi passenger side feed fuel rail with line $25
• Side feed TGVs $80 set (3 available)
• Coolant crossover pipe $20 (3 available)
• Purge valve $10 (2 available)
• STi proportioning valve $20
• MAF sensor #22680AA31A $35
• BPV with crush mod no elbow $25
• WRX STi blow off valve adapter for FMIC $30 (new)
• Boost solenoid controller $25 (2 available)
• Boost solenoid controller bracket $5
• 04/05 WRX fuel pump assembly with pump #42021FE010 $50
• STi fuel pump controller $50 #22750AA000 (2 available)
• Radiator mounts $10 set (3 available)
• Fuel filter bracket $20
• Power steering reservoir $20 (2 available)
• Power steering reservoir bracket #34633FE001 $5
• Power steering lines $30
• 04 WRX steering column with ignition & key $75
• 04 STi steering column with ignition, key & remote $100
• 06 STi steering column with ignition, key & remote $100
• Pull type clutch fork pin (5 or 6 speed) $20
• Transmission mount $20
• AC condenser $40 (2 available)
• STi driver radiator fan $25
• STi passenger radiator fan $25
• Coolant overflow tank $10
• Starters $50 (3 available)
• Intake air duct $25
• 02-04 washer tank $20
• Radiator coolant hard line $10 (2 available)
• Manifold coolant hard line $10 (2 available)
• DBC throttle body $35
• Oil dipstick $10 (2 available)
• TMIC hard lines $10
• Oil cap $5
• Oil cap with fill neck $10
• 02-05 WRX cruise control actuator module $20
• Hood prop $5 (2 available)
• Batter tray $5
• Turbo heat shield $15
• Turbo uppipe bracket $5 (2 available)
• Pitch Stop Mount $10
• Grimmspeed uppipe to turbo gasket $10 new
• OEM intake manifold to TGV gasket $5 new
• Timing Covers: left, center(3) and right(2) available $10 each
• Front O2 sensor plastic cover $5
• AC Lines $25+
Suspension & Brakes Pics: https://imgur.com/a/1Ms6AE1
• Cusco 22mm front sway bar with oem mounts $150
• Cusco 22mm rear sway bar with oem mounts $150
• Front sway bar mounts $10
• Rear sway bar mounts $10
• STi LCA bushings $40 set
• 04 WRX STi ABS module #27534FE200 $40
• WRX STi ABS module #27534FE271 $40
• WRX STi ABS module #27534FE270 $40
• ABS Sensors: #27540AE000, #27540AE001, #27540FE050 $10
• 5x114 rotors were turned and never used $50
• WRX rear calipers $60
Exterior Pics: https://imgur.com/a/o4gYp1I
• BBS center caps $25 each (2 available)
• 04/05 right headlight bracket $10
• Driver front exterior door handle PSM $20
• Driver rear exterior door handle PSM $20
• Passenger front exterior door handle PSM $20
• Passenger rear exterior door handle PSM $20
• Wiper arms $30 (2 sets available)
• Driver mirror PSM $25
• Passenger mirror CGM $25
• Driver mirror no cover black $25
• Passenger mirror no cover black $25
• Gas lid PSM $10
• Exterior B pillar molding $15 each
• Doors $150 each except for rear passenger is $100 because no glass (driver front sold)
Interior Pics: https://imgur.com/a/G7vOkeh
• Visor clips $5 set
• Center rear view mirror sun visor $10
• Interior mirror cover right #94251FE000 $5
• Interior upper B pillar trim $10 each
• Interior lower B pillar trim $10 each
• Interior C pillar trim $10 each
• Rear seat trim $10 each
• Trunk latch trim $10
• Door kick molding trim $10 each
• Driver center console side cover $10
• Rear heat vents $10
• Seat belts: passenger front and all rear available*$40 each
• Seat belt buckles $10 each
• Trunk release cable $10
• Gas lid release cable $10
• WRX trunk hinges and torsion bars $20
• Weatherstripping: Doors, hood and trunk avaiable $5 each
• Fuel pump cover $5
• Jack $5 (2 available)
• Tool kit #97010FE040 $10
• Driver Trunk Side $20 (no jack cover)
• Rear dash $40
• Bugeye door cards $50
• Bugeye front seats $50
• Bugeye rear seats $50
Electronics Pics: https://imgur.com/a/QuPpVtK
• Headlight leveling switch $10 (2 available)
• I/C water spray switch $10
• Switch blanks $5 (2 available)
• Timer I/C assembly #88017FE040 $10
• 05-07 mirror switch $10
• 02-04 mirror switch $10
• Hazard switch $10
• OBD II port $10
• Engine bay fuse box $25
• Rear view mirror wire cover $5
• Map light $20
• Dome light $20
• 05 STi ignition with 2 keys & 2 remotes $50
• 04 STi ignition, key & remote $40
• 06 STi ignition, key & remote $40
• 04 STi clockspring $50
• Headlight/blinker switch $25 (3 available)
• Wiper switch $25 (3 available)
• OEM horns $5 (2 available)
• ECU cover $10
• Wiper motor $40 (2 available)
• STi headlight leveling motors $20 each (2 available)
• Positive battery terminal cable $5
• 04/05 WRX fuel tank wiring $20
• DRL module #84067FE060 $10
• DRL module #84067fe000 $10
• 04/05 control unit air bag #98221FE110 $40 (2 available)
• 06/07 control unit air bag #98221FE220 $40
• WRX STI left front air bag sensor #98231FE070 $10 (3 available)
• WRX STI right front air bag sensor #98231FE060 $10 (3 available)
• WRX STI left side airbag sensor #98235FE150 $10 (2 available)
• WRX STI right side airbag sensor #98235FE140 $10 (2 available)
• WRX STI left side airbag sensor #98231FE010 $10
• WRX STI right side airbag sensor #98231FE000 $10
• Airbag harness $25
• WRX STI G Sensor ABS #27540FA022 $10
• WRX STI G Sensor ABS #27540FE090 $10
• Fuel injector resistor module #684227 $10 (2 available)
• Door ajar sensors $20 set of 4 (2 sets available)
• 04/05 WRX STi keyless entry module #88035FE140 $20
• 04/05 WRX STi keyless entry module #88035FE141 $20
• 06/07 WRX STi keyless entry module #88035FE190 $20
• 04/05 WRX STi integrated control module #88281FE160 $20
• 06/07 WRX STi integrated control module #88281FE340 $20
• WRX STI clarion antenna amplifier assembly #86327FE090 $20
BlobeyeSTi is offline   Reply With Quote
Old 05-13-2017, 08:19 PM   #2
BlobeyeSTi
Member#: 187877
Old 05-13-2017, 08:22 PM   #3
BlobeyeSTi
Member#: 187877
Old 05-13-2017, 08:24 PM   #4
BlobeyeSTi
Member#: 187877
bump.
Old 05-13-2017, 08:43 PM   #5
BlobeyeSTi
Member#: 187877
bump.
Old 05-15-2017, 01:47 PM   #6
BlobeyeSTi
Member#: 187877
bump.
Old 05-16-2017, 11:11 AM   #7
mav1c
Hoodbridge!
Member Sales Rating: (52)
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Would you sell just the rear Brembo calipers and/or the front axles?
What type of bushings are in the lower control arms? How many miles on the bushings?
Old 05-16-2017, 01:28 PM   #8
BlobeyeSTi
Member#: 187877
PM sent
Old 05-18-2017, 01:35 PM   #9
BlobeyeSTi
Member#: 187877
OP Updated
Old 05-18-2017, 07:05 PM   #10
frankenwrx
Member Sales Rating: (2)
Member#: 419550
All
Willing to ship?
20636
Cusco Center power braces $225
Cusco Rear T power braces $75
Cusco Rear sub-frame brace $75
GTspec Front tie bar brace $125
frankenwrx is offline   Reply With Quote
Old 05-18-2017, 07:36 PM   #11
BlobeyeSTi
Member#: 187877
^Ya I can ship those no problem. PM sent
Old 05-20-2017, 10:35 PM   #12
BlobeyeSTi
Member#: 187877
Bump!
Old 05-21-2017, 03:28 AM   #13
Bigalfromva
Member#: 444450
2005 WRX STI
Pic of CF rad shroud???
Bigalfromva is offline   Reply With Quote
Old 05-21-2017, 12:14 PM   #14
BlobeyeSTi
Member#: 187877
^PM sent
Added more parts and pictures
Old 05-23-2017, 02:30 PM   #15
BlobeyeSTi
Member#: 187877
Bump!
Old 05-24-2017, 06:45 PM   #16
BlobeyeSTi
Member#: 187877
OP Updated
Old 05-26-2017, 09:16 AM   #17
BlobeyeSTi
Member#: 187877
Bump!
Old 05-28-2017, 11:58 AM   #18
BlobeyeSTi
Member#: 187877
OP updated
Old 05-28-2017, 12:21 PM   #19
Bigalfromva
Member#: 444450
2005 WRX STI
I'm in need of a front right axle for my sti, anyway you'd sell me one?
Old 05-29-2017, 10:40 AM   #20
BlobeyeSTi
Member#: 187877
Sorry don't want to separate from the 6 speed swap
Old 05-29-2017, 12:22 PM   #21
Lagunagreen
Member Sales Rating: (5)
Member#: 410537
2002 Wrx Sedan
Wrb
Where in WV are you located?
Lagunagreen is offline   Reply With Quote
Old 05-29-2017, 12:58 PM   #22
BlobeyeSTi
Member#: 187877
Near Morgantown
Old 06-02-2017, 09:13 AM   #23
BlobeyeSTi
Member#: 187877
Bump...
Old 06-07-2017, 05:48 PM   #24
BlobeyeSTi
Member#: 187877
Bump!
Old 06-12-2017, 03:57 PM   #25
BlobeyeSTi
Member#: 187877
OP Updated
