Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 08-31-2017, 12:55 PM   #1
nc21
Member Sales Rating: (2)
Member#: 341745
Default Sold
SOLD
I did the swap in my bugeye and then totalled the car only ~3000 miles later so the transmission only has about ~45k miles on it. It was a low speed, rear end collision but the damage to the radiator support was enough surpass the $4500 dollar value of the car (as assessed by my insurance company). I have about $9k invested in everything here. Most of the bolts were replaced with new hardware and everything was torqued to factory spec. Everything you would want/need to replace while doing this swap has already been taken care of, and the hardware is already sorted into plastic containers for each section of the swap to make install a breeze (especially when compared to the pile of hardware you'd get from the importer that may or may not be stripped, rusted, and rounded off).
There are more pictures below the details.
-Have paper work from importer (~40k miles on swap when purchased and was only in car for ~3000 miles) and receipts for ALL parts
-Full 6MT swap! EVERYTHING you need!
-Tranmission code: TY856WB7KA
-Gears and synchros in good condition and shifts beautifully
-Brembos w/ stoptech pads, slotted rotors and stainless steal brake lines
-New ball joints with new bosses w/ STI front LCA's
-Comp Clutch stage 3
-Resurfaced STI flywheel
-Starter
-STI rear sway, AVO rear endlinks, and perrin front endlinks
-r180 LSD Rear Diff
-NEW OEM Rear hubs/bearings/seals/ABS Sensors/ABS tone rings/lateral link bolts
-STI rear subframe and lateral links and control arms
-STI front control arms and spindles
-STI Driveshaft
-BNIB Spiider Auto/Manual DCCD controller
-Torque Solutions short shifter and shifter bushings (and stock shifter)
-All new STI axles
nc21 is offline   Reply With Quote
Old 09-21-2017, 01:10 PM   #2
nc21
Member#: 341745
bumpppp
Old 09-22-2017, 09:28 AM   #3
nc21
Member#: 341745
bumppppp
