Welcome to the North American Subaru Impreza Owners Club Saturday February 17, 2018
Old 10-29-2005, 10:04 PM   #1
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
Default grounding kits stock ground points
Ok, so i've had a grounding kit for a while, and i took it off to replace some other stuff to get a benchmark. Thats all fine and good till i plugged in my new GPS and was getting a bad alt whine outa built in speaker. Why is my power-outlet giving an alt whine? I figure i must have some grounding issues someplace. so i was gonna go though and swap out my stock ground wires with some newer ones and redo the connections to the frame. Does anyone know how many there are and where they are? I'd really like to fix the alt whine coming outa my gps.
thanks...
-ben
spdracr00 is offline   Reply With Quote
Old 10-29-2005, 11:30 PM   #2
Wiscon_Mark
Member#: 94945
2015 Dodge Charger
AWD
good grounding points on the frame are:
Both Strut Towers
Radiator Frame
An already existing point near the battery
There are already a lot of grounding points around the car in various places, you can probably just clean those up, and attatch a more sturdy wire to it.
Wiscon_Mark is offline   Reply With Quote
Old 10-29-2005, 11:32 PM   #3
spdracr00
Member#: 65823
2018 Impreza Sport
Pearl White
thats what i was hoping to do. but I wanted to make sure i got them all. I mean all the factory ones. dont need a grounding kit if the factory ones are clean.
Old 10-30-2005, 11:29 AM   #4
Wiscon_Mark
Member#: 94945
2015 Dodge Charger
AWD
okay, well...
There are the ones I mentioned, and then there's one along that wall below the airbox (waaaay down there). There are probably several more that I haven't seen, but if you look, you'll be able to find them easily enough
Old 10-30-2005, 11:05 PM   #5
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Both Strut Towers
Radiator Frame
Don't ground anywhere near the radiator or the alternator. The radiator grounding point increases oxidation of the radiator internals. Propylene Glcol is a great electrical conductor, but you don't want a ground anywhere near it. Everywhere you ground make sure to scrape the paint off or the crud off first. I dunno how many countless times I have heard that the mod doesn't work yet they are grounded against paint . Also invest in a good grounding kit. Not an Ebay Grounding kit. Popular belief is they are real HKS pieces. They aren't.... HKS grounding kits are purple. GEt an HKS kit, a Sun automobile kit etc... Just to know when you ground against the body in anyway corrosion rates increase. So stay away from fenders, rad supports, and the firewall. Focus mainly on the intake manifold, strut tower braces, and engine block. Also place them somewhere else other than the stock ground. Its useless to double up on an existing ground point. If you need new OEM grounds go buy the cables and do that, but usually a good cleanup job of them works best.....
Sorry its a long post.
Russell
Russell Rogers is offline   Reply With Quote
Grounding kit Built07 Engine/Power/Exhaust 6 07-05-2010 11:25 AM
If only four, which points to use for ground-kit? BeBop86 Electrical & Lighting 1 11-20-2008 08:09 AM
washer bottle, stock bpv, grounding kit Trevor723 Engine/Power/Exhaust 6 04-28-2007 12:41 PM
SoCal: 7 point grounding kit 30$ jmanny152 Private 'For Sale' Classifieds 2 08-22-2005 02:26 PM
Single-point ground mod vs. Multi-point ground mods DrBoy01 Normally Aspirated Powertrain 5 12-05-2003 05:21 PM
