Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2020
Old 02-07-2020, 10:39 PM   #1
xXforgotenxX
Member#: 511131
Default 102mm ls throttle body to subaru intake manifold
I was wondering if anyone sees a problem doing this
xXforgotenxX is offline   Reply With Quote
Old 02-08-2020, 04:33 PM   #2
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
Besides it being massive?
I'm running an 80mm Hemi throttle body and it's massive compared to stock.
102mm throttle body you're looking at a 4" inlet. I'm all for giving things a shot but 102 seems a bit excessive. My 80 is probably excessive.
Barge is offline   Reply With Quote
Old 02-09-2020, 12:03 PM   #3
xXforgotenxX
Member#: 511131
Haha yeah probably is excessive I found 1 for $40 so that's why I was curious
Old 02-13-2020, 04:58 PM   #4
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
We did a Q45 TB on the TIC time attack car and that 90mm TB was more than enough for our GTX3582R at 32 PSI.
Old 02-24-2020, 06:51 PM   #5
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Not worth it IMO. Pretty common to see turbo LS motors running the factory intake manifolds and throttle bodies (86-90mm IIRC).
Guess you could build a manifold to fit the flange then guess correct upper plenum volume, plenum floor height, and runner dimensions. If you're that good, I'd convert to a 4150 style throttle with delayed secondary butterfly.
imma_stocker is offline   Reply With Quote
Old 02-25-2020, 01:30 PM   #6
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
Just for comparison this is the flange for my Hemi TB overtop of a stock size TB inlet.
I added several rods of filler behind the new flange to fill in thin area or completely ground away holes to get it ported out to size.
It would be interesting to see some differential pressure changes across throttle bodies. I have too many other projects I need to get done first though.
Old 02-25-2020, 03:09 PM   #7
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
I'd be interested to see how individual cylinder cfm is affected. Uneven flow between cylinders is more dangerous than total flow restriction.
Old 02-25-2020, 04:29 PM   #8
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
I was pretty careful keeping it aligned on center and making sure the plate opens the same direction as stock. I also attached my new flange to the stock flange to at least give it some area flow into the plenum.
These NA manifolds seem to have pretty equal flow based on what tests I've seen and hopefully I maintained that.
Without individual widebands or EGT I don't really have a good way to say for sure that they're balanced though.
Old 02-26-2020, 06:32 PM   #9
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Oh didn't realize you're modifying the NA manifold. That would also be my pick for this project. Got anyone local with a flow bench?
Old 02-27-2020, 04:41 PM   #10
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
I'm sure someone in the Detroit area has a flowbench. Really need to run it with the TB on for true numbers in my opinion. Also be nice to run it with different TB opening percentages.
I only have an 80mm though... 102 is way too big hah.
I doubt I'll do any flow work on the NA manifold. I've got some ideas to build a custom one so when I get around to that for sure. As said.. runner balance is pretty critical.
I recall in the old intake manifold flow comparison some of the high flowing aftermarkets manifolds had pretty terrible runner to runner variation.
