Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 09-10-2014, 09:18 AM   #451
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Cool
Originally Posted by Robstunner View Post
Does anyone know if the added 10w over stock (55w vs H9's 65w) will cause issues over time with the LIN Battery Sensor in the new 15' model year subarus? It's the reason why I ripped out my HIDs today.
Not exactly what you're asking, but...
I've been running the H9's on my 2013 XV Crosstrek for about two weeks now. No issues at all. I'm even impressed how good they work in OEM reflector bowls! I did aim them down just a touch (even though I ran them at factory set height for two nights without any issues to oncoming traffic.) Just being mindful to others on the road.
These in combination with the TRS Morimoto XB LED fog lamps are fantastic!
MackDaddy is offline   Reply With Quote
Old 10-17-2014, 08:08 PM   #452
Scooby207
Member#: 255687
11 WRX DGM
Default H11 to H9 conversion. DIY with temps
Is there anything wrong with wiring a socket that takes h9 bulb rather than having to trim the bulb every time one goes out. It can probably be done in the same time it takes to trim the bulb and then you only do it once. This will be my fourth time changing bulbs since I started doing this mod and it's kind of getting old
Sent from my iPad using NASIOC
Scooby207 is offline   Reply With Quote
Old 10-17-2014, 08:43 PM   #453
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It takes me 10 seconds to trim the bulb with a pair of snips.
Buy spare bulbs and prep them, then keep them in the glove box. Beats hacking the wiring.
Old 10-17-2014, 09:31 PM   #454
Scooby207
Member#: 255687
11 WRX DGM
Ok. What are these snips you speak of? I've always used my Dremel but the bit isn't exactly perfect so it takes a while. If it only took 10 seconds that would change everything
Old 10-17-2014, 10:17 PM   #455
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Small flush-cutters, like this or similar-
http://www.radioshack.com/product/in...ductId=3932532
Reach right into the socket, snip the tab flush with the socket body, done.
Old 10-17-2014, 11:54 PM   #456
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Scooby, if you know what you're doing, go for it. Just get a nice, quality set of H9 sockets.
The good thing is, if you're in a pinch or just want to go back to the dimmer, longer lasting H11s, they will fit just fine.
Tha Chakal is offline   Reply With Quote
Old 10-18-2014, 03:06 PM   #457
MackDaddy
Member#: 15451
Lunar Silver
I'm using these harnesses without issue. I had to modify one end to facilitate H9 connectivity, but it's a one time modification.
http://www.amazon.com/gp/product/B00CYB90UO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Seems like they're no longer available, but there are plenty of other vendors that carry these.
Old 10-18-2014, 03:19 PM   #458
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
2 X H8/H9/H11 Extension Adapter Wiring Harness Sockets Wire for Headlight - Extension Cords - Amazon.com
You should leave a review on Amazon so that other people can see that you can do it.
A couple people left reviews saying you cannot use this with H9 bulbs and you can, as you can see. I left comments letting other people know you can though.
BWX is offline   Reply With Quote
Old 10-19-2014, 09:42 PM   #459
Obsidian2007sube
Member#: 363190
2013 Wrx Hatch
Ice Silver Metallic
After installing these bulbs, I took a quick drive around my neighborhood. I did noticed that the lights shown a tad high on the side of parked vehicles. The "steps" you see in the lights when up close on a garage door, fence or wall, is obscured a little now. I have the 3100k H9 bulbs in my wrx. Just bought them today at Autozone, they were low on H11 and I just happened to look at the H9 right next to it.
Obsidian2007sube is offline   Reply With Quote
Old 10-19-2014, 10:48 PM   #460
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Thanks for posting the link to these cutters! They look like they'd make short work of that damn plastic tab. I've been using an exacto knife with a flat tipped blade to cut the tab out, but it's a PITA and takes longer than I'd like.
jr0bb5 is offline   Reply With Quote
Old 10-20-2014, 12:39 AM   #461
ktong721
Member#: 364682
2013 WRX 5-dr
Crystal Black Silica
Just did this mod today. I purchased the generic Philips H9 Halogen Bulbs from Amazon.
I didn't have any tools small enough to get rid of that plastic tab so I ended up using a nail file and went at it with good old elbow grease.
The install was a piece of cake for the most part. With the plastic tab removed, the H9 snapped right into place when I connected it to the headlight harness. However, the H9 would not "lock" into place when I installed it back into the headlight housing. That quarter turn to lock it into place just wouldn't give me that solid 'snap' telling me that it locked. Did anybody else have this issue? Looking at the bulbs it looks like the mounting structure is a bit different between the H9 and H11. I don't want my bulb to wiggle while I'm driving...
P.S. I installed one headlight first and just standing back and looking at my headlights I noticed it was brighter than the stock H11. Not a night and day difference, but worth it for the price. I have yet to try these on the road at night. Will come back with an initial review tomorrow night if someone answers my question above^
ktong721 is offline   Reply With Quote
Old 10-20-2014, 05:46 AM   #462
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
If you look straight down at the bulb you will see the circular metal flange or lip with some cut-outs. I think one of those might need to be clipped down a few mm or so sometimes. Compare it to your H11.
-edit-
Some pics...
First pic is obvious mod you need to do..
I just took these pics-
H11, older H9, newer H9.. See the differences?
On the newer one you may have to trim that tab on the the top to seat the bulb all the way in.
Another pic with tabs more clearly depicted.
Old 10-20-2014, 06:49 AM   #463
Tha Chakal
Member#: 372100
Good looking, BWX! I wonder when they changed it...
Old 10-20-2014, 07:08 AM   #464
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Thanks, and I am not sure when they changed it. On that older H9, I bought that about 3 years ago maybe.. something like that- at Autozone. The newer one I bought same place maybe 9 months ago, maybe longer.
-EDIT- added another pic above that wasn't as washed out with light..
https://lh4.googleusercontent.com/-N...ustom%2529.JPG
Old 10-20-2014, 11:52 AM   #465
MackDaddy
Member#: 15451
Lunar Silver
Good call, I'll do just that. They're an easy modify to work with H9.. giving you the ability to swap in new bulbs (say, in the middle of nowhere in pitch dark) with ease.
Old 10-20-2014, 12:51 PM   #466
Obsidian2007sube
Member#: 363190
2013 Wrx Hatch
Ice Silver Metallic
I noticed that as well last night when I installed them. I just shaved it enough with my dremel. It still has a snug feel and locked in with the 1/4 turn.
Old 10-20-2014, 11:19 PM   #467
ktong721
Member#: 364682
2013 WRX 5-dr
-edit-
Some pics...
Thanks BWX! That definitely cleared things up. I figured I'd have to modify the metal mount to get the bulb to snap into place. I don't have a dremel but I'll find some way to shave those tabs down this weekend...
Initial review of the H9: I drove back home from work tonight and the difference is totally worth the price! The H9 burns brighter and whiter than the H11. The width of the light trail also seems a bit wider than the H11. The height of the light did not seem to be higher than the H11 as opposed to what some people said. I was driving behind a Fiat 500 the entire time and my headlights were aimed right as his taillights (did not seem to be aiming into his rearview). I was also driving on a single lane highway with opposing traffic with no center divide; did not get flashed once by opposing traffic. Overall, I think this simple upgrade is a must for every owner!
Old 10-21-2014, 03:29 AM   #468
Obsidian2007sube
Member#: 363190
2013 Wrx Hatch
Ice Silver Metallic
I just got home from work at this time of post, i355 is three lanes and I was lighting up all three pretty well. Of course when the highway lights aren't lighting my road way. It isn't that much whiter in brightness per se but the width of the light pattern - AWESOME compared to H11.
Old 10-28-2014, 08:50 PM   #469
James2.5i
Member#: 305063
2016 VDUBBB
This is one of my favorite mods so far. My fat fingers had a hard time getting out that extra tab, but the light output is amazing.
I did this with a set of the PIAA 55w bulbs.
James2.5i is offline   Reply With Quote
Old 10-29-2014, 08:25 PM   #470
Scooby207
Member#: 255687
11 WRX DGM
I have a low beam socket that looks messed up. No power going to the socket either. I'm hoping its unrelated to this mod. Working on a fix
Old 10-29-2014, 08:35 PM   #471
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
That's concerning. Is anything melted?
Old 11-14-2014, 08:22 PM   #472
Scooby207
Member#: 255687
11 WRX DGM
No, looks cracked. Not sure how it happened as I am pretty careful about the way I do things. Didn't notice it happen but last time I went to change the bulb noticed the problem.
And my power issue has been solved. The wire was corroded. Replaced the socket and wiring and everything is working fine now
Old 11-16-2014, 11:40 PM   #473
krnxbrian
Member#: 399704
are these the bulbs that everyone is buying?
http://www.amazon.com/PHILIPS-12361-Bulb-Standard-Headlight/dp/B00P32H0G2/ref=sr_1_2?s=automotive&ie=UTF8&qid=1416195579&sr=1-2&keywords=philips+h9+bulb
krnxbrian is offline   Reply With Quote
Old 11-17-2014, 06:52 AM   #474
wrxnh
Member#: 393998
/// WRx ///
Originally Posted by krnxbrian View Post
Yep that's what I bought.
If you haven't, a good time to read up on realigning horizontal & vertical to make sure the headlights aren't blinding someone. I've been flashed few times and realized my vertical was a tad bit higher than it should be.
wrxnh is offline   Reply With Quote
Old 11-17-2014, 09:13 AM   #475
krnxbrian
Member#: 399704
Cool. I actually went through all 19 pages. Haha
i did see the aiming link too. Thanks!
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
