Welcome to the North American Subaru Impreza Owners Club Thursday April 25, 2024
Old 11-25-2010, 07:35 PM   #1
DrBelmore
Member#: 254057
Default Car wont boost over 10psi
Hi I have a 02 bugeye hybrid with vf39, grimmspeed ebcs, and all supporting mods. I have been boosting 19psi at 11.4:1 AFR with no problems. Then all of a sudden one day I was getting on the freeway and I hit on it and it stuttered for a second and then kept going (19psi). Well I get off the freeway and boosted it in first, right when the boost was getting over 10psi the pressure started going all crazy like 13psi, 17, 15, 18, 14, 19. And my AFR's went down to 10:1. Also the motor started stuttering and was kind of shaking (and it was back firing from going so rich). Then I let off and the car drove fine as long as I dont go over 10psi. I tried the same thing in second gear and it did the same exact thing. I did a 20psi boost leak test and heard no leaks. I took off the TMIC tightened all the clamps, checked all the couplers/gaskets and found nothing.
What do you guys think it could be?
Eric
DrBelmore is offline   Reply With Quote
Old 11-26-2010, 08:55 AM   #2
quazimoto
Member#: 70395
If your using the factory boost control system sounds like the motor detonated pretty bad and the ECU dropped boost and timing. Post a datalog.
Old 11-26-2010, 11:39 AM   #3
DrBelmore
Member#: 254057
Oh sorry I should of added that but I am on the Grimmspeed boost solenoid.
Old 11-26-2010, 06:23 PM   #4
quazimoto
Member#: 70395
Doesn't mater. The ECU is still controlling the boost. Post a datalog or find out what the IAM is.
Old 11-26-2010, 10:52 PM   #5
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
If 10psi is all it will boost, it sounds like you are running spring pressure at your IWG. Could be an issue with you EBC. That doesn't explain the shaking and rich AFRs though.
gotsugg is offline   Reply With Quote
Old 11-27-2010, 09:51 AM   #6
quazimoto
Member#: 70395
Or the engine is knocking repeatedly and the ECU has decided to run wastegate boost.
Old 12-03-2010, 10:37 AM   #7
DrBelmore
Member#: 254057
Well I don't have a computer right now that I can datalog but I am still having the same problem. When I slowly give the motor boost, right when I start getting around 8 psi I start hearing tons of fluttering almost like it's the wastegate but it sounds louder then the wastegate. But when I check for boost leaks I cant hear anything leaking.
Old 12-03-2010, 04:43 PM   #8
DrBelmore
Member#: 254057
Anyone have any ideas?
Old 12-03-2010, 05:37 PM   #9
GrimmSpeed
Member#: 136396
2020 STI, 2022 WRX
Hey, I do not think our valve is operating incorrectly BUT we just had this same scenario happen, check your wiring connections to the valve, while they are tough if it has been yanked around at all they can break loose. Double check these wires and report back!
Will
GrimmSpeed is offline   Reply With Quote
Old 12-03-2010, 06:22 PM   #10
DrBelmore
Member#: 254057
Will
Sounds good. I will check it in the morning. Thanks
Eric
Old 02-22-2024, 03:22 PM   #11
steagalarus
Member#: 535693
Did you fix the issue?
Can't go above 15psi boost when I was previously able to get to 22-23.
21 WRX
steagalarus is offline   Reply With Quote
Old 02-22-2024, 04:55 PM   #12
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
OP hasn't been on this site in almost 10 years.
Old 04-02-2024, 03:50 PM   #13
steagalarus
Member#: 535693
Sadness, I really need to fix my problem
Old 04-18-2024, 06:00 PM   #14
Zackvbra
Member#: 537738
Check wastegate duty under boost. If you have an issue with your wastegate it could just be making whatever the mechanical boost limit for the turbo is.
Zackvbra is offline   Reply With Quote
WRX 2.0 wont boost over 4lbs TPPERFORMANCE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-02-2010 12:47 PM
Car wont rev over 5000 RPM, pulled Map sensor and cars fine.... Please help!!! Cautionjump Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-08-2007 11:45 PM
wont boost over 5psi v8eaterWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-25-2006 06:06 PM
wont boost past 10psi mtxfrk2k1 Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-02-2006 04:01 AM
HELP!Car wont get over 3800 rpm? 4CEFED6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-19-2002 10:23 AM
