#1 |
Member#: 254057
Vehicle:2002 WRX |
![]() Hi I have a 02 bugeye hybrid with vf39, grimmspeed ebcs, and all supporting mods. I have been boosting 19psi at 11.4:1 AFR with no problems. Then all of a sudden one day I was getting on the freeway and I hit on it and it stuttered for a second and then kept going (19psi). Well I get off the freeway and boosted it in first, right when the boost was getting over 10psi the pressure started going all crazy like 13psi, 17, 15, 18, 14, 19. And my AFR's went down to 10:1. Also the motor started stuttering and was kind of shaking (and it was back firing from going so rich). Then I let off and the car drove fine as long as I dont go over 10psi. I tried the same thing in second gear and it did the same exact thing. I did a 20psi boost leak test and heard no leaks. I took off the TMIC tightened all the clamps, checked all the couplers/gaskets and found nothing.
What do you guys think it could be? Thanks Eric
#2 |
Member#: 70395
![]() If your using the factory boost control system sounds like the motor detonated pretty bad and the ECU dropped boost and timing. Post a datalog.
#3 |
Member#: 254057
Vehicle:2002 WRX |
#4 |
Member#: 70395
![]() Doesn't mater. The ECU is still controlling the boost. Post a datalog or find out what the IAM is.
#5 |
Member#: 204014
South East
Vehicle:02 02 WRB Bugeye GTX3582 front mount turbo |
![]() If 10psi is all it will boost, it sounds like you are running spring pressure at your IWG. Could be an issue with you EBC. That doesn't explain the shaking and rich AFRs though.
#6 |
Member#: 70395
![]() Or the engine is knocking repeatedly and the ECU has decided to run wastegate boost.
#7 |
Member#: 254057
Vehicle:2002 WRX |
![]() Well I don't have a computer right now that I can datalog but I am still having the same problem. When I slowly give the motor boost, right when I start getting around 8 psi I start hearing tons of fluttering almost like it's the wastegate but it sounds louder then the wastegate. But when I check for boost leaks I cant hear anything leaking.
#8 |
Member#: 254057
Vehicle:2002 WRX |
![]() Anyone have any ideas?
#9 |
Member#: 136396
Vehicle:2020 STI, 2022 WRX |
![]() Hey, I do not think our valve is operating incorrectly BUT we just had this same scenario happen, check your wiring connections to the valve, while they are tough if it has been yanked around at all they can break loose. Double check these wires and report back!
Will |
#10 | |
Member#: 254057
Vehicle:2002 WRX |
![]() Quote:
Eric |
#11 |
Member#: 535693
Vehicle:2021 WRX (sti trans) |
![]() Did you fix the issue?
Can't go above 15psi boost when I was previously able to get to 22-23. 21 WRX |
#12 |
Trust no one
Moderator Member#: 11170
Vehicle:13 Mini MT 15 WRX/11 CRZ |
![]() OP hasn't been on this site in almost 10 years.
#13 |
Member#: 535693
![]() Sadness, I really need to fix my problem
#14 |
Member#: 537738
#15 |
Member#: 535693
![]() it was a bad one way check valve for my iag aos
once it was replaced the oil and smoke spewing stopped |
WRX 2.0 wont boost over 4lbs | TPPERFORMANCE | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 07-02-2010 12:47 PM |
Car wont rev over 5000 RPM, pulled Map sensor and cars fine.... Please help!!! | Cautionjump | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 06-08-2007 11:45 PM |
wont boost over 5psi | v8eaterWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 12-25-2006 06:06 PM |
wont boost past 10psi | mtxfrk2k1 | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 04-02-2006 04:01 AM |
HELP!Car wont get over 3800 rpm? | 4CEFED6 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 27 | 08-19-2002 10:23 AM |
