Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
View Poll Results: Did you pass inspection, catless in NJ?
Yep....no problem! 8 24.24%
SOB! No! 8 24.24%
Obligatory 3rd option for those who feel the need to vote in every poll posted on Nabisco. 17 51.52%
Voters: 33. You may not vote on this poll
Old 05-26-2006, 07:54 PM   #1
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Default NJ Inspection: Catless and passing?
OK, so I'm catless in NJ....do you think I'm passing? I can put the third cat eliminator on since I have a lift but I'm way too lazy. Anyone here pass inspection catless in NJ?
Here's the vitals
2004 WRX Wagon
Cobb Tuning AccessPort Stage 2,
Grounding Kit, GFB Stealth FX Blow-Off Valve, K+N Air Filter, Optima Performance Battery, Bosal Brospeed Twin-Tip Catback Exhaust, Bosal 3rd cat eliminator, Perrin Lightweight Pulley,Bosal Divorced Wastgeate DownPipe, and APS UpPipe
ScoobyNubieToo! is offline   Reply With Quote
Old 05-26-2006, 07:57 PM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
just dont thro a cel and hope they dont look under ur car and ur good
99subi is offline   Reply With Quote
Old 05-26-2006, 08:13 PM   #3
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
I have no CELS....but I'm worried about a visual....
Old 05-26-2006, 09:21 PM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
if u want to be slick cut the stock heatsheild cover off of the cat from the stock exhuast and tack weld it to ur aftermarket one , this way it looks like a cat is prestent
Old 05-26-2006, 09:34 PM   #5
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Good idea! Maybe I'll do that....
Old 05-27-2006, 01:45 AM   #6
HEAVY.HITTIN
Member#: 116031
Last time I went to inspection they mirrored under the car to look for a cat. From then on I now spring the extra $60 and go to a gas station just in case something goes wrong.
HEAVY.HITTIN is offline   Reply With Quote
Old 05-27-2006, 09:03 PM   #7
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
Wouldn't it just be smarter to just spend the extra $100 and get a cat? Unless you're running some monster, it's not worth the trouble.
iamchris is offline   Reply With Quote
Old 05-28-2006, 06:25 AM   #8
4or2wheels
Member#: 14112
2002 wrx wagon
2010 STI DGM
At my last inspection they used a mirror to look for the cats and also looked closely under the hood.
4or2wheels is offline   Reply With Quote
Old 05-28-2006, 11:55 AM   #9
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
WoW! Really? They're getting tough. I might have to find a hookup somewhere on a sticker.
Old 05-28-2006, 05:06 PM   #10
allroy81
Member#: 62260
2004 sti
2013 forester
they looked under my hood last time i went too.
allroy81 is offline   Reply With Quote
Old 05-28-2006, 05:28 PM   #11
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
I am worse off than just a cat cause the UTEC makes my OBII useless! I have modded injectors so I can't take it off and try to go through either
2002WRXSTi is offline   Reply With Quote
Old 05-29-2006, 11:21 PM   #12
Trip McNealy
Member#: 37338
2007 Legacy 2.5 GT
2009 Daytona 675
im in the same position as you, granted my inspection isn't until next fall 2007.
probably just gonna slap on the stock DP again, sell off the Helix catless one I have and call it a day. was going to sell the car shortly thereafter.
Trip McNealy is offline   Reply With Quote
Old 05-30-2006, 11:12 AM   #13
elsanto
Member#: 34832
1989 M3
even if they dont use a mirror. would it pass hte sniffer test?
i just passed with a high flow cat, it is NOT visible from under the car (in the DP) and they passed me with no gripes at a state facility.
elsanto is offline   Reply With Quote
Old 05-30-2006, 04:01 PM   #14
2002WRXSTi
Member#: 58647
02 Exedy Carbon
On a OBDII car you get no sniffer. They plug into you OBD port and that is it on the engine part of inspection aside from them looking to see if the cat is there with a mirror.
Old 05-30-2006, 04:24 PM   #15
elsanto
Member#: 34832
1989 M3
ahh, I wasnt paying much attention when they did my car (as I was too nervous to watch) but I could have sworn there was something in my tailpipe. my bad.
Old 05-30-2006, 05:07 PM   #16
2002WRXSTi
Member#: 58647
02 Exedy Carbon
I haven't taken my WRX through but I took my SVX and just took my Mark VIII to my friends garage for inspection and they didn't do a pipe test that I was able to see. I want to figure out a way to make a fake OBDII port so it passes the tests that inspection wants to see. Shouldn't be the hardest thing to make
Old 05-30-2006, 06:57 PM   #17
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
It's looking like my options are to either weld a heatsheild on or swap in the 3rd cat to get through.....I'ld rather just pay for a sticker rather than deal with the hastle.....
Old 05-30-2006, 09:17 PM   #18
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Good luck cause my pay for sticker guys wont do a OBDII car.
Old 05-31-2006, 06:44 AM   #19
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
WoW....getting tougher all of the time.....
Old 05-31-2006, 10:16 AM   #20
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
"Dude - what do you mean? Look right down there, the cat is CLEARLY visible... moron..."
CirrusWRX is offline   Reply With Quote
Old 05-31-2006, 10:29 AM   #21
2002WRXSTi
Member#: 58647
02 Exedy Carbon
/\/\ that just ain't right! /\/\
Old 05-31-2006, 10:37 AM   #22
ninethreeeleven
Member#: 99777
$60? For what? To do a $18 inspection?
That stinks if they get to charge, in NY they are not allowed to charge you for more than the Inspection, not even $5 more I don't believe. They also can't charge a surcharge for things like Fish & Game permits. So while the Dicks Sports employee has to spend 20 minutes doing the paperwork for my hunting tags, the store doesn't get paid for it.
ninethreeeleven is offline   Reply With Quote
Old 05-31-2006, 01:58 PM   #23
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
I think a "$60 inspection" might be to "gaurantee" the car passes legally. I believe some people in the tristate are unfortunate enough to go to gas stations where they have to pay for $200+ inspections... though only in cash... but yet, for some reason, they ALWAYS pass...
Maybe I'm interpreting it incorrectly...
Maybe I just enjoy using elipseseseses...
Who really knows...
Old 05-31-2006, 04:13 PM   #24
WRX_REED
Member#: 38976
2000 RS 2.5 Coupe
Sedona Red
Its not going to work for all OBDII cars as the scan will show a "Catalytic Converter not ready" error and you will fail with that alone. This is a known and troublsome item as those people even with a cat but with modded chips the piggyback ecu's (UTECs and the like) will also fail as the signal for the cats may be intercepted by the piggyback and give an incorrect or null reading which would not necessarily show as a CEL but will inform the tech that you were modded and fail the inspection as all readings would be invalid. Generally with the piggybacks (if mildly modded) you change the connections back to stock and then rewire afterwards. No cats though, is harder to pass as visual, OBDII and sound issues are almost always a problem.
WRX_REED is offline   Reply With Quote
Old 05-31-2006, 04:14 PM   #25
WRX_REED
Member#: 38976
2000 RS 2.5 Coupe
Sedona Red
Gas techs suppose to post the OBDII reports, can't bypass this supposedly.
catless and still pass emissions? scoobiedude 66 Newbies & FAQs 15 04-15-2010 07:07 AM
Will A Catless DP pass emissions? wricereaterx12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-01-2006 05:09 PM
Parts needed to borrow/rent for NJ inspection: Steering wheel+front seats annointed Tri-State Area Forum 13 11-05-2005 09:46 PM
pass side tail light and pass side fog 03 WRX Imprezanator Private 'For Sale' Classifieds 2 09-06-2005 07:32 PM
Will a catless WRX pass MA emissions? rsilvers Engine Management & Tuning 2 05-13-2003 12:34 PM
