Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 09-17-2019, 11:52 PM   #1
Greyhound
Member#: 469309
Default STI Short Throw Shifter worth it for STI?
I'm debating whether or not I should order a 2020 STI with a Factory STI Short Throw Shifter. What are the differences in terms of driving feel between the stock shifter compared with STS upgrade and is it worth it?
Greyhound is offline   Reply With Quote
Old 09-18-2019, 09:37 AM   #2
Senfinger
Member#: 110912
2018 STi RA
Had it on my 5 STi's and yes... = )
Senfinger is offline   Reply With Quote
Old 09-18-2019, 10:18 AM   #3
vlad11591
Member#: 295970
2019 STI
CWP
Imo I don't think it's worth it. The throws don't seem to be that much different, and it forces you to be much more precise with shifting. I don't hate it, but it's not something you need to spend 4-500$+ on. You could probably get the same effect and spend much less money on a shift stop/bushings/shift plate.
vlad11591 is offline   Reply With Quote
Old 09-18-2019, 10:26 AM   #4
TriAxis 6
Member#: 377862
2017 Z06/Z07 & Fozzy
Admiral Blue & CWP
Totally not worth it, get the cart boy and be done with it.
The difference in the night reduction is drastic with the cart boy. Not so much with the STi
TriAxis 6 is offline   Reply With Quote
Old 09-18-2019, 10:35 AM   #5
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
The answer is very subjective. Best thing to do is to ask your dealership for test drives of both and see for yourself.
TifosiWA is offline   Reply With Quote
Old 09-18-2019, 10:42 AM   #6
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
He's asking for the STI not the WRX
FWIW, my STI came with the STS and I enjoy it. It does take a bit of getting used to at first. You can certainly go with an aftermarket shifter, but then you have to deal with the hassle of installing it.
WRXnick16 is offline   Reply With Quote
Old 09-18-2019, 12:07 PM   #7
vlad11591
Member#: 295970
2019 STI
CWP
I wasn't aware that you can't add shift stop/bushings to STI?
Old 09-18-2019, 12:41 PM   #8
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
The STI transmission is rod shifted so things are a bit different. You can still swap bushings, but no shift plate or shift stop.
Old 09-18-2019, 01:07 PM   #9
vlad11591
Member#: 295970
2019 STI
CWP
ahhh makes sense. Thanks for throwing some knowledge my way.
Old 09-18-2019, 01:13 PM   #10
R1Armadillo
Member#: 481444
2018 STI Limited
I got one when I ordered my '18. I also knew I didn't want to "mess" with anything when I bought it, so got what I could in the order.
If you are one to mod items yourself, then I believe after market is the way to go.
If you are not one to mod items yourself, then order the short throw.
I also opted for the sport exhaust as I had heard/ driven a friend's and it was plenty loud enough for me, and I knew I wasn't going to mess with it. But I believe they got rid of this option after the '19?
GL with your decision!
R1Armadillo is offline   Reply With Quote
Old 09-18-2019, 02:06 PM   #11
wrxlaunch
Member#: 181298
2015 FUQ21BottiTuned
Full Bolt on Flex Fuel
If you have to ask... you prob shouldn't
wrxlaunch is offline   Reply With Quote
Old 09-18-2019, 05:23 PM   #12
super_subie
Member#: 344431
2020 STI
CWP
i just got my 2020 STI and the shift is not bad(non-STS)...compared to my previous car 2013 WRX; the shift is a lot closer
super_subie is offline   Reply With Quote
Old 09-18-2019, 10:19 PM   #13
BlueRibbonRyan
Member#: 503883
2019 WRX STi
World Rally Blue
My 2019 came with factory short shifter, was more of a pleasant surprise than what I was already considering prior to first test drive. I have not driven one without it however I find it to be perfect for me. I have had other cars with short shifter before and have not experienced any issues with precision in my shifts even when first getting accustomed to it. I did find that it took a few hundred miles to "break in" as it was slightly tight, particularly 3-4 shift at first. I am more than capable of installing one myself but at least everything in the assembly is warrantied if something does somehow fail and cannot try and say it was an installer error.
BlueRibbonRyan is offline   Reply With Quote
Old 09-19-2019, 10:39 AM   #14
vlad11591
Member#: 295970
2019 STI
CWP
I'm wondering if the issues I'm having from my STS come from a very heavy weighted aftermarket shift knob, as well as it being taller like a stick rather than spherical. I switched it back to the stock shift knob, (which is slightly weighted anyway) and I've had much smoother transitions from 3-4 and 4-5.
Old 09-19-2019, 11:17 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Kartboy is the gold standard on shifters for the STi. If you don't feel like reaching for a lower knob there's also a solution made by Kartboy but exclusively for me.
If you feel like being baller there's the CAE setup which is quite nice.
Old 09-19-2019, 12:45 PM   #16
SDblitz858
Member#: 498585
I have an 18Sti , how do I know if I have the STS? I feel like the throws are perfect as is but yea, What is a CAE set up? any links? Thank you!
SDblitz858 is offline   Reply With Quote
Old 09-19-2019, 07:25 PM   #17
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
I agree with EricZ 100% and need two of these in my life.
http://turninconcepts.com/driveline/...sti-lever.html
Scorpius is offline   Reply With Quote
Old 09-20-2019, 01:22 AM   #18
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
hacksaw for the win...
Smurftastic is offline   Reply With Quote
Old 09-20-2019, 07:23 AM   #19
Straight6
Member#: 419593
I can't speak for the STI because I haven't driven a regular vs sts back to back but as far as the WRX, it is the only mod I regret doing. Biggest waste of money IMO.
Straight6 is offline   Reply With Quote
Old 09-20-2019, 01:50 PM   #20
Panacea
Member#: 349037
2019 STi Limited
Another vote for the STi short shifter.
Panacea is offline   Reply With Quote
Old 09-20-2019, 04:54 PM   #21
Scooby-Doode
Member#: 28976
2016 Step 2 Push
Buggy GT
OEM one no, aftermarket yes.
Old 09-20-2019, 07:22 PM   #22
Panacea
Member#: 349037
2019 STi Limited
What folks are failing to acknowledge is that for a stock, OEM component, the Subaru short shifter is a great piece. There are certainly others out there that you may like better but the OE one is great.
Old 09-20-2019, 07:33 PM   #23
subaru_gc8
Member#: 29292
2004 WRX wagon
yo know its kinda one of those things that you dont really notice it when you put it in but you sure notice it when you drive someone else that doesnt have one
subaru_gc8 is offline   Reply With Quote
Old 10-09-2019, 12:44 AM   #24
Greyhound
Member#: 469309
Thanks for the replies everyone. I'm likely going to get a STS if I get the STI.
Old 10-09-2019, 01:00 AM   #25
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
I have a kartboy on my 5 speed wrx, I like the shorter throw but donít like the fact that the knob sits lower. I have a oem short shifter on my 6 speed and love everything about it, the knob sits at stock like hight, itís perfect.
D-Rodman is offline   Reply With Quote
