08-21-2006, 09:13 AM | #1 |
Member#: 122633
Help! Rough low rpm operation, poor mileage :(
Hi guys,
Just bought a WRX with 80K on clock and in the last couple of days it began running poorly at low rpm (who the hell rush hour test-drives a car anyhow? ). Basically it's hesitant to pick up under 2000 rpm, jerking pretty badly at constant throttle application. After that it picks up quite smoothly, but I'm sure that even if it has no low-end power, it shouldn't act like the engine's trying to break free and run away. The situation was helped a bit by a nice high rpm rip through the first gears, but it's coming back now . Also mileage is somewhere around 450 km/tank, which is kinda poor considering I was going on boost in rush hour traffic. I come from a Honda, and I know that if one of those behaved like this, I'd attack the cap, rotor, plugs, wires, and fuel filter before thinking of anything else to fix it....I realize the Subaru's a completely different beast, so please help a n00b get the most out of his new purchase .
08-21-2006, 11:04 AM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
check the air filter and fuel filter (hard to check the latter - if it looks old, replace it). Also - check the MAF sensor to see if it's fouled and needs cleaning.
08-21-2006, 04:33 PM | #3 | |
Member#: 72132
NWIC
Vehicle:2000 Legacy GT White |
08-21-2006, 09:09 PM | #4 |
Member#: 22412
SWIC
^^^^ probably everything listed above (in terms of replacing) - plugs, filters, etc. is a good idea for a car with 80k miles and an unknown history.
Rough, irregular RPM @ idle and low acceleration | erikkellison | Engine Management & Tuning | 18 | 02-03-2010 05:52 PM |
Help! Non-typical low RPM hesitation | gtwagon941 | Legacy Forum | 13 | 06-18-2009 08:00 PM |
Need help on low RPM hesitation/High EGT problem | kracka99 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 13 | 08-28-2005 09:31 PM |
Help! Sti Stalling at low RPM (sorry, long) | BlackWRX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 36 | 11-23-2004 07:40 PM |
Low RPM hesitation problems.. please help! (cont. ) | Orbiter | Technical Forum Archive | 0 | 08-18-2000 03:47 AM |
