Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 12-15-2017, 09:50 AM   #1
SprinterWRX2018
Member#: 477013
Default 2018 loud on start up
Hey guys just bought a new 2018 wrx premium with the 6speed manual back in September . Just wondering why on start up the engine sounds very loud almost like theres no oil in it for about 10 seconds then goes away. The noise is also heard in the exhaust. Not sure if this is done on purpose for an agressive tone at start up. Anyone know if this is normal? Also while in gear, 4th gear is the only one i feel vibration in the shifter. Thanks for the help
SprinterWRX2018 is offline   Reply With Quote
Old 12-15-2017, 10:18 AM   #2
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
Congrats on the purchase. It's programmed to idle high at start up to heat up the catalytic converter - this is normal. Not sure about the vibration, but my 15 wrx had a slight vibration in 4th when i placed my hand on it, although, it didn't occur all the time. Maybe someone else on here can chime in.
Raikkonen-F1 is offline   Reply With Quote
Old 12-15-2017, 12:50 PM   #3
wrbrexx
Member#: 461037
2016 Subaru
World Rally Blue
You are describing the cold start cycle. As said above it idles higher and the result is a louder and more aggressive sound from the exhaust. Completely normal. I have the 4th gear vibration too sometimes and I am pretty sure itís normal. I donít think any manual car ever made has zero vibration in the shifter.
wrbrexx is offline   Reply With Quote
Old 12-15-2017, 01:02 PM   #4
namr0n
Member#: 452695
2017 WRX Limited
everything you mentioned is normal
namr0n is offline   Reply With Quote
Old 12-16-2017, 08:16 AM   #5
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Yup, perfectly normal - just one of the "fun" things engineers can do with direct injection...
The actual purpose as mentioned is to heat the cat up faster. The ECM is injecting fuel late in the compression cycle which then finishes burning in the exhaust after the exhaust valves open.
Elbert Bass is offline   Reply With Quote
Old 12-16-2017, 10:07 PM   #6
SprinterWRX2018
Member#: 477013
Thanks for the info guys it all makes sense.
Is it also normal to hear some slight clanking noises from the front suspension when hitting bumps? almost sounds like bad strut mounts that i used to have in an older car. But I'm sure this is something normal due to the sport riding nature of this car. Thanks again
Old 12-16-2017, 10:16 PM   #7
ChUt26
Member#: 465695
2017 WRX Premium
Black Silica
It's pretty normal for a cold startup.
ChUt26 is offline   Reply With Quote
Old 12-18-2017, 10:45 AM   #8
wrbrexx
Member#: 461037
2016 Subaru
World Rally Blue
Do you have a video?
Old 12-18-2017, 10:09 PM   #9
FLTFOUR
Member#: 465423
2018 WRX Premium
THIS...I also feel vibration after shifting to fourth. And NO I am not resting my hand on the shifter. It can be felt immediately after shifting into 4th! Thought there was something wrong with mine.
FLTFOUR is offline   Reply With Quote
Old 12-19-2017, 04:55 AM   #10
Gel Mibson
Member#: 219009
2018 LBP WRX Ltd.
2005 PSM WRX - St.2 (rip)
it will always be loud on a cold startup. kind of standard for wrxs. enjoy the car.
Gel Mibson is offline   Reply With Quote
Old 12-21-2017, 04:25 PM   #11
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
It's loud also there is an air pump that's pumping fresh air into the exhaust to heat up the cat. It's pretty normal. Some cars sound like a vacuum when you start it.
jasonwrx86 is offline   Reply With Quote
Old 12-23-2017, 08:51 PM   #12
wrxey
Member#: 167150
2006 WRX
put me in for 4th gear shifter vibrations...
wrxey is offline   Reply With Quote
Old 12-24-2017, 10:26 AM   #13
Elbert Bass
Member#: 283429
No, you have STI and WRX confused.
There is no secondary air pump on 2018 WRX. Nor 2017, 2016, 2015...
Old 12-25-2017, 07:25 PM   #14
That_Boosted_Life
Member#: 422693
2016 WRX Premium
Lapis Blue Pearl
I believe the loudness is the ignition timing retard that is on the OTS tunes to heat the cat up. I have an etune and noticed that my car no longer does this, but still have close to 2k rpm idle on a cold start. Have a catted grimmspeed jpipe.
That_Boosted_Life is offline   Reply With Quote
Old 12-26-2017, 11:29 AM   #15
Elbert Bass
Member#: 283429
Nope, it's injection timing. Subaru calls it "Stratified Mode". It injects a lean pulse of fuel on the intake stroke and then a rich pulse during compression. The result is the fuel/air mixture is still burning as the exhaust valves open creating that noise.
Old 12-27-2017, 09:07 PM   #16
subrad
Member#: 468884
Mine drones until it settles @ 850
subrad is offline   Reply With Quote
Old 12-27-2017, 09:42 PM   #17
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Actually there is. I can hear it turning off.
It stays on after you shut off the engine for a couple of more seconds to cool down the cat.
Old 12-27-2017, 09:49 PM   #18
MidnightS2000
Member#: 471388
2017 WRX
sounds like a normal cold start to me.
MidnightS2000 is offline   Reply With Quote
Old 12-28-2017, 07:38 AM   #19
rtv900
Member#: 428511
2016 STI
nope, it's ignition timing.
My STI sounds the same way due to ultra retarded timing when cold.
I'm pretty sure my STI isn't injecting a rich pulse during the compression stroke considering the intake valve is closed.
The spark timing is what affects 'when' the majority of the burn takes place.
rtv900 is offline   Reply With Quote
Old 12-28-2017, 08:18 AM   #20
Elbert Bass
Member#: 283429
No, you can't inject fuel after the valves are closed on your STI (last century port fuel injection technology). The discussion is regarding a later model WRX equipped with a very different engine than your EJ25 STI with port injection and a secondary air pump.
Since 2015 WRX has had an FA20 with Direct injection Turbo and it can (and does) inject fuel at different times and multiple times during intake and compression strokes depending on conditions.
Old 12-28-2017, 09:25 AM   #21
rtv900
Member#: 428511
2016 STI
no doubt, direct injection can inject during the exhaust stroke if you really wanted it to.
The louder, deeper, later ignition timing exhaust sound on cold start ups is from a later ignition timing.
That's why it's the same louder, deeper, later ignition timing sound in my STI.
Old 12-28-2017, 05:31 PM   #22
Zcypot
Member#: 372777
2014 WRX Sedan Lmtd
Piston slap, normal. take it easy until it warms up
Zcypot is offline   Reply With Quote
Old 12-30-2017, 08:47 AM   #23
Elbert Bass
Member#: 283429
I'll be sure to tell Subaru, they will need to correct the description for Stratified Warm-up Mode in the "2014 Forester" and "Direct Injection System" training literature and curriculum.
Old 12-31-2017, 06:40 PM   #24
rtv900
Member#: 428511
2016 STI
training literature and curriculum?
are you serious man?
What am I missing about cold start operation?
serious question too. why is my sti no different if it's the direct injection fundamentals causing this?
