Welcome to the North American Subaru Impreza Owners Club Sunday August 9, 2020
Old 06-14-2019, 01:33 PM   #1
mamun316
Member#: 303390
2017 WRX Premium
Crystal White Pearl
Default Post Ceramic Pro Care - Adams Polishes
So I had my car Ceramic coated after picking it up from the dealership. The first wash is coming up and I just want to get opinions regarding the sequence for the wash.
I am going to go with the Adams Polishes Wash and Wax.
Next, I am not sure if I should use the H2O Guard and Gloss or the Ceramic Boost?
As per the video on their site they mention that you can use the H2O every wash but they recommend maybe once every 2 washes.
Any other products you guys would recommend?
(Based in Canada)
mamun316 is offline   Reply With Quote
Old 06-14-2019, 02:51 PM   #2
silverscooby
Member#: 15060
2015 WRX
MAPerformance Stage2+ E30
I use CarPro Reload on mine after every couple of washes. I really like it and it seems to keep the ceramic nice and slippery.
https://www.detailedimage.com/Ask-a-...spray-sealant/
silverscooby is offline   Reply With Quote
Old 06-14-2019, 08:01 PM   #3
sebhockey
Member#: 138957
2016 WRX STI Limited
For shampoo always use a shampoo without additives, so no waxes, gloss enhancers etc. Waxes won't stick to the coating, and any additives interfere with the properties of the coating. Ie. water won't bead as well, not as clear etc. The only exception to this rule is a shampoo with a silica sealant built in (Carpro Hydrofoam, Gyeon Bathe+).
For shampoo Carpro Reset is pretty much the standard that others are compared to for use with coatings and a little goes a long long way (a 500ml bottle can last years). Other good shampoos include Gyeon Bathe, Adams Car Shampoo.
Wash and Gloss is a polymer sealant, so doubtful it will bond to your coating. The only polymer sealant that plays nice with a coating that I'm aware of at the moment is P&S Beadmaker. Beadmaker has developed a cult like following as of late due to its properties, coating compatibility, and is comparably cheaper than others. It's fairly common to use it as a drying aid every time and it certainly doesn't break the bank.
If you would rather do a silica spray sealant, I highly suggest CarPro Reload. It really only needs to be applied once every 3 months, way too expensive to apply every wash. I use Carpro ECH20 mixed 20:1 as a dying aid/QD and it stays slick all the time (slicker than Reload by itself), it contains small amounts of silica in it just like Reload.
sebhockey is offline   Reply With Quote
Old 06-20-2019, 01:22 PM   #4
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
I also use CarPro Reset to wash my cars as it plays well with coatings. After that what you do is up to your budget and how much effort you want to put in. With a ceramic coating you don't NEED to put anything on top. Anything else is just maintenance to "extend" the life of the coating by some unknown amount. I never put anything on top of my ceramic coating and it lasted just about 3 years. Now that it's gone I've switched back to a polymer sealant and will probably put CarPro Reload on top of it to improve the dust / water shedding.
Scooby921 is offline   Reply With Quote
Old 06-20-2019, 11:52 PM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
dont use a polish it will take the ceramic coating right off
Old 06-21-2019, 12:40 PM   #6
cknowlen
Member#: 189077
2011 STI limited
Personally I wouldn't use any shampoo which has waxes or fillers added, not needed and will not bond to the ceramic. Be sure to use the two bucket or gary dean method of washing to reduce the chance for new scratches and swirls. As for a maintenance product, CarPro reload is good, Gtechniq C2v3 in my opinion is the best on the 'prosumer' grade market.
cknowlen is offline   Reply With Quote
Old 09-17-2019, 09:31 PM   #7
TriAxis 6
Member#: 377862
Adams car shampoo (the blue one) for a foam cannon pre wash (touchless wash). I actually prefer griots foaming surface wash for this, but Adams is also wonderful and you mentioned you like the Adams brand
Follow up with carpro reset for a contact wash.
Iíd seal all that with The Last Coat V2...only after complete chemical decon and if needed mechanical decon.
While youíre at it...
Make your own sio2 quick detailer with carpro products:
2oz reload
2 oz ech20
20 oz distilled h20
Or go out and get their elixir which is that combo with some hudro2 thrown in.
If you wanted to go to a polymer based topper instead of SiO2 based- BEADMAKER!!!! Gloss and slickness are unbeatable
TriAxis 6 is offline   Reply With Quote
