Welcome to the North American Subaru Impreza Owners Club Monday August 10, 2020
Old 07-27-2015, 10:28 AM   #1
xluben
Member Sales Rating: (17)
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default FlexConverter.com Plug-and-Play Bluetooth E85 Sensor
This weekend I installed the Bluetooth E85 sensor from FlexConverter.com
http://flexconverter.com/collections/subaru
This is a product made and sold by the creator of the Carberry ROM. His ROM's now support full Flex Fuel. I am still using COBB SD so I'm not using the Flex Fuel application, but I still like having the sensor for ethanol percentage and fuel temp. This setup uses a Bluetooth app (for your phone) instead of a hard mounted gauge. This saves cost and works well for what I need.
The kits are fully plug and play and the kit I got is set up for a speed density setup. The harness has one connector for the OEM MAF wiring, another wire for a GM IAT sensor, and the last connector is for the GM ethanol sensor. Just splice the sensor into the fuel return line and everything else is plug and play. Install takes just a few minutes.
The last fill up I did was from a different gas station that I normally use. It is right next to my work, but normally doesn't have as good of E85. The sensor confirmed that it was only 69%. I'm hoping to get a new tank in soon from my normal station and see how it compares.
xluben is offline   Reply With Quote
Old 09-06-2015, 10:06 AM   #2
TheMonaLisa
Member#: 357722
2006 Legacy GT
Had any problems with it?
TheMonaLisa is offline   Reply With Quote
Old 09-06-2015, 10:43 AM   #3
ToneWrx02
Member Sales Rating: (9)
Member#: 239095
2002 Wrx
Subbed. Will buy this soon as well! ****ing jack pot!
ToneWrx02 is offline   Reply With Quote
Old 12-09-2015, 05:26 PM   #4
carlos.danger
Member Sales Rating: (6)
Member#: 363268
2015 WRX STi
Updates.
carlos.danger is offline   Reply With Quote
Old 12-10-2015, 01:17 AM   #5
jon7009
Member#: 394646
2003 WRX Flex Fuel
EJ205 TD04L FMIC SD
The system is designed to work in tandem with the Carberry ROM and uses bluetooth for calibration of the unit and for viewing ethanol content remotely.
He's just using it for the ethanol sensor/bluetooth portion, but from the people who are also running the Carberry ROM and are using it for blended or weekend fill-ups it works perfectly. Nobody has reported any issues with it yet, but I'm not sure how many people are using it quite yet.
More information is available on romraider and the flexconverter.com site.
If one was curious, you could download the latest Carberry rom and definitions, and check out the tables yourself to see.
jon7009 is offline   Reply With Quote
Old 12-10-2015, 01:49 PM   #6
ToneWrx02
Member#: 239095
2002 Wrx
I dont mind the bluetooth feature but lets say you want to add a 52mm gauge to display percentage. Could you do that?
Old 06-10-2016, 04:19 PM   #7
carlos.danger
Member#: 363268
2015 WRX STi
Updates. How are you liking this?
Does it read gas octane as well?
Old 06-23-2016, 06:54 PM   #8
181stLeader
Member Sales Rating: (83)
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
It does not read gasoline octane. Only ethanol content in the fuel.
181stLeader is online now   Reply With Quote
Old 06-23-2016, 07:07 PM   #9
carlos.danger
Member#: 363268
2015 WRX STi
Is there a kit that does?
Old 08-29-2016, 08:20 PM   #10
2015wrxsti
Member#: 444208
2015 STI
WR Blue Pearl
Will this work on +15 sti ?
2015wrxsti is offline   Reply With Quote
Old 08-31-2016, 07:08 PM   #11
bmxhotsauce
Member Sales Rating: (10)
Member#: 127099
02 IMPERZA WRX
BLACK
are you running their GM IAT or the AEM?? going to buy their SD wiring 100% just wnated to see if the GM sensor is worth it or stick with AEM.
thank you
bmxhotsauce is offline   Reply With Quote
Old 10-23-2016, 11:47 PM   #12
paulpat
Member Sales Rating: (5)
Member#: 237145
02 WRX
12 FXT
updates?
paulpat is offline   Reply With Quote
Old 10-25-2016, 06:36 AM   #13
wikedcobra312
Member Sales Rating: (1)
Member#: 203207
2004 wrx 2.0/e55amg
I just bought this, I will update as well.
wikedcobra312 is offline   Reply With Quote
Old 11-29-2016, 10:14 AM   #14
carlos.danger
Member#: 363268
2015 WRX STi
No you wont
Old 11-29-2016, 10:37 AM   #15
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
I will once I receive it, super backed up
Old 11-29-2016, 12:43 PM   #16
carlos.danger
Member#: 363268
2015 WRX STi
Promise?
Old 11-29-2016, 12:46 PM   #17
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Of course, my buddy has it and loves it. I can ask him if you have any questions
Old 12-13-2016, 08:47 AM   #18
STIzzley
Member#: 459680
2015 WRX STI
Does anyone know if this setup (or any setup from flexconverter.com) will work on a '15 STI? I'm curious specifically about hooking up the ethanol content analyzer. I will probably end up connecting it to the ECU via the rear O2 plug or one of the TGV plugs (if possible) and plan to have the car tuned by COBB Plano to run flex fuel. As best I can tell my only options for this is a setup similar to this from foexconverter.com or pay $600 (outrageous) for basically the same thing from COBB.
I know that COBB's system uses the rear O2 plug for power and sends data to the ECU via the TGV. I'm trying to find something that works in the same or a similar way. Any help is appreciated.
STIzzley is offline   Reply With Quote
Old 12-17-2016, 04:56 AM   #19
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Well I still have not received my kit, weaksauce
Old 12-17-2016, 05:24 PM   #20
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
How long has it been ?
Old 12-17-2016, 05:29 PM   #21
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Over a month
Old 12-17-2016, 05:30 PM   #22
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Terrible also since they don't respond to emails
Old 12-17-2016, 05:30 PM   #23
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
But since this is not a primary car I have time to wait
Old 12-17-2016, 10:36 PM   #24
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
So what!! U should get a refund.. who cares if it's not your DD.
Old 12-17-2016, 10:46 PM   #25
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Yeah, I was gonna go that route but it comes in this monday...we will see, if not then I will get my refund and I guess go a different flex fuel route
