11-02-2005, 12:06 PM | #1 |
Member#: 46254
Vehicle:2005 Outback XT Wago Blue |
Why does my clutch release when I start to push on the peddle?
Is it normal to be able to change gears-shift through the entire range of my clutch peddle throw? My 05 OB-XT has always had a strange clutch peddle feel. And the feel of the shifting is notchy-like the clutch is not fully released. The clutch also has squeak towards the end of its throw next to the fire wall. SOA said the squeak is a known issue and will fix the problem once they figure out what to do about it. Has anybody had similar issues with their dual mass flywheel clutch?
11-02-2005, 06:35 PM | #2 |
Member#: 19733
Vehicle:2002 WRX BLOOO |
The notch may be that you need to change the transmission fluid.
11-02-2005, 06:58 PM | #3 |
Member#: 46254
The car has less then 6000 miles on it-do you think the trnsmission oil is low or high (ie the oil is whipped)?
11-02-2005, 10:09 PM | #4 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
Since this sounds like a new car to you, perhaps you are just not used to how the clutch and shifter feel for this car.
11-03-2005, 07:00 PM | #5 |
Member#: 46254
Does a dual mass flywheel, clutch and pressure plate feel different then a conventional OEM solid flywheel, clutch, with spring dampeners, and pressure plate? I know the spring dampeners in a conventional clutch compress about 1 mm; however I do not know how much the springs compress between the center and outer ring of a dual mass flywheel. Regardless of the dampening mechanisms, shouldn’t the pressure plate engage and disengage the same in both types’ mechanisms?
11-03-2005, 09:42 PM | #6 |
Member#: 37359
Vehicle:2003 WRX |
When I first got my WRX I didn't like the way the clutch released so close to the top of the pedal travel so I adjusted the rod that goes through the firewall by the throttle. It allowed me to move the engagement point.
Also, I had the squeak and just ignored it. It's gone away now. |
Why does my scalp itch when I eat spicy food? | psychoskip | Off-Topic | 19 | 02-05-2010 01:51 PM |
why does my subwoofer "thump" when I turn off my car. | chadt02 | Car Audio, Video & Security | 24 | 11-30-2007 08:15 PM |
Why does my car stall when I try to start it (rarely happens) | stillillmatic7 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 04-28-2007 05:42 AM |
why does my fuel pump go from loud to quiet after start up? | blackie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 09-22-2004 10:13 PM |
Why does my clutch smell!!! | SDEWYZ | New England Impreza Club Forum -- NESIC | 6 | 02-02-2003 02:57 PM |
