07-21-2008, 10:31 PM | #1 |
Member#: 144826
Vehicle:2004 WRX PSM |
How much is too much?
So i am swapping my auto out and putting in a 5 spd manual transmission in my 1999 2.5RS. I found a deal with a guy that has all the parts that I need for $600 and it has 148k miles on everything...I was talking to my dad and he thinks that is way too much mileage on parts to put into the car. If I was to buy all of this what kind of things should I ask the seller about the parts? If I buy it, would I want to get the tranny checked by a tranny specialist?
This is the list of the parts: Manual Transmission Manual Transmission Mounts Shifter Assembly (shifter, plate, gasket bushings) Shifter Linkage Manual Drive shaft Manual Rear Differential Clutch Cylinder(s) Manual Clutch/Brake Pedals/Box Manual Transmission Starter Clutch Cable if not hydrolic Manual Transmission ABS Module |
07-21-2008, 10:42 PM | #2 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
i wouldnt think 148k miles would be bad for a tranny, just check the input shaft bearing. If the input shaft moves alot, might not want to buy it.
You could get the tranny checked out, hopefully it wouldnt be too expensive, never had that done, so I dont know about the cost. ~Josh~ |
07-22-2008, 12:18 AM | #3 |
Member#: 166898
W. Canada
Vehicle:1994 T leg SS ABM |
i got a tranny from a 98RS with 80,000km, along with a diff, rear crossmember, clutch asemmbly for 400$ so ya its a little high, try to get down 100$ to 200$
Similar Threads | ||||
1. Can you drink too much green tea? 2. If so, how much is too much? | crowbar | Off-Topic | 32 | 10-19-2006 11:24 AM |
What is the biggest pro/con of more caster? How much is too much on a WRX suspension? | rex n effect | Motorsports | 6 | 06-20-2004 10:05 AM |
Clutch rollover/tickover- how much is too much? | beachbum | Normally Aspirated Powertrain | 0 | 05-16-2001 09:41 AM |
How much is too much? (Remote lead) | BJamerican | Car Audio, Video & Security | 3 | 04-19-2001 10:50 PM |
How much is too much? | LeadFoot | Canada Region Forum | 4 | 04-24-2000 02:28 PM |
