04-08-2002, 02:38 PM | #51 | |
Member#: 3319
Torque can be changed with gearing, power cant. In short, without getting into a discussion that has been beaten up on the internet too much already------ If torque was all that mattered, why doesnt everyone run a turbo diesel? Youd have 200 hp and 500 ft lb at your disposal. Run that against the same car with 500 hp and 200 ft lb. Who do you think will win?
04-08-2002, 02:55 PM | #52 |
Member#: 1994
Vehicle:2018 STI WRB |
torque, is what pushes you in your seat. The work the car get's out of the torque produced is what makes you fast. Work = Horsepower. High torque, low HP engines just do a poor job of converting the torque into work at high RPMs. You can't feel HP.
04-08-2002, 04:06 PM | #53 | ||||
Member#: 3319
04-08-2002, 05:20 PM | #54 | |
Member#: 1994
04-19-2002, 12:40 AM | #55 |
Member#: 6070
South East
Vehicle:2015 STi Dark Gray Metallic |
Volume vs. Mass
There are advantages to running boost other than effective compression ratio. Although there is the same volume filling the cylinders at 14.7 psi of boost you are effectively pushing twice the mass of air (and fuel) into the combustion chamber, which should yeild greater power if properly applied. High compression is more efficient, but sometimes yields the side effects such as heat and detonation. This volume would also be somewhat reduced if the charge air is hotter, and thus less overall mass at BDC, so that a 2 liter engine with 14.7 psi boost will not necessarily produce the same power as a 4 liter engine.
I think the issue of what effective compression ratio your engine can handle is a good one. Can you cool rapidly? Do you have strong rods for the initial expansion shock? Is the chamber and piston head properly shaped? Forged aluminum pistions? These are all factors effecting the effective compression ratio. I am building up an SVX engine. Rebello racing builds the 3.3 Liter and 2.2 L engines for racing and airplanes. At high boost these engines must be modified to dissapate more heat or they melt down or detonate. That is why I have been looking to hear what success people have had running 10:1 compression on their 2.5 L RS, as it would be somewhat comparible to my SVX engine. Porche runs 9.4:1 compression in their engines with about 12 psi boost. They have piston sleaves that are made to reduce friction. The cylinders and heads are made to reduce heat. Engine management and control are also a must. fuel is also important as a higher octane fuel will burn cooler. Bottom line is what are people running succesfully on the subaru engine at 91 or 93 octane? What is the acceptable effective compression ratio for our engine? How can it be improved (cooling or slicker internals)? What is your ultimate power goal? Using your ultimate power goal coupled with the effective compression ration, then it just becomes a function of how much to boost is needed to achieve the goal without loosing too much bottom end power. Race fuel can be used at the track then all bets are off. |
04-19-2002, 12:44 PM | #56 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
I plan to hit the track this weekend, weather permitting, on 93 octane pump gas and 12-13 psi.
My TB fuel injectors seem to cool down the intake air temps at the MAP sensor, similar to water injection, but without the antidetonation properties of water injection. I am still seeing in the neighborhood of 80% intercooler efficiency with my air/air IC which does help. Is it cheating if I put ice in my intercooler watersprayer bottle? Larry |
04-23-2002, 09:21 AM | #57 |
Member#: 6070
South East
12-13 psi
Hey larry. How'd it go this weekend?
04-23-2002, 12:25 PM | #58 |
over boosted again
RMIC
$30 and 6 hours later, waiting for only two runs since they were so busy...
Bogged the 1st launch because the clutch keeps slipping if I slip it, so I have to dump it instead. And, my new 1st is 15% taller than stock, and 10% traller than 1st in a WRX, so it likes the clutch to be slipped a little to launch and I can't do that. And, since the track is so sticky when I dumped the clutch only the front wheels spun and when they hooked up revs dropped from 5,000 to 2,800 and bogged = 13.9 @ 97 Second and last run of the day I hit 2nd gear going into 4th and after hitting 8,500 rpm I coasted through the lights all freaked out = 15.1 @ 65 mph Bah! Larry |
04-23-2002, 12:26 PM | #59 |
over boosted again
RMIC
Plus, I was only building 10 psi in 1st gear, and 11-12 psi in 2nd - 4th since it warmed up. That's like 8-9 psi at sea-level.
Time to gut the second cat or get a 3" downpipe made up... Larry |
04-23-2002, 06:31 PM | #60 |
Member#: 6070
South East
times
The 13.9 isn't too bad. Still faster than a Rex.
09-07-2004, 07:22 PM | #61 |
Member#: 59458
so 2 years and 4 months later... can anyone sum up everything that was said?
10-03-2004, 11:15 AM | #62 |
Member#: 53595
NWIC
Vehicle:1987 GL Hatch EA81 1.6L + Weber |
So, if I am correct... which I may not be...
isn't the point of a turbo, forcing air into the cylinder, to make the cylinder push down harder with more explosive force? ie: getting more static CR? Let's take this example... If you take a 10:1 compression EJ25, it breathes in ~614cc per cylinder. If you take an 7:1 compression EJ25, it breathes in ~614cc per cylinder. Lets just use these numbers. if 79mm stroke and 100mm bore gives you a 2481cc engine (2.5L)... then 10:1 CR is about 248cc of area where everything is squished. and in the 7:1 CR is about 345cc of volume of area above the piston. Now, doing the math... isn't 854cc of mixture packed into 345cc of volume of space the same power output as 614cc packed into 248cc volume of space? (854cc of mixture is the amount needed in the 7:1 engine for it to have the same static CR of 10:1) Doesn't 12/16 = 3/4? The whole time I'm reading this, someone out there saying that a lower compression boosted engine with more boost is going to have more mixture in the cylinder (true) than the less boosted higher cr engine, and so therefor going to make *more* power? How can it make more of anything if the static compression (345cc/854cc = 248cc/614cc) is the same? if there were two engines, one at 13:1 CR, and one at 8:1 CR, and the turbo motor pushing 24.25psi. if the turbo motor were able to have the turbo spooling at exactly the right amount of psi to make the static CR be the same as the 13:1 motor, and be able to do it through the whole RPM band (idle on) then wouldn't the power output regardless of rpm be exactly the same? And furthermore, if you had two IDENTICAL (cams, everything) engines, except that one was the 13:1 CR, and the other 8:1 with 24.25psi, then at the point where the boosted engine reached 24.25 psi, wouldn't that RPM in the other motor bring out the same EXACT hp/torque numbers? (assuming the engines are identical and both at the same timing) I think I'm right. Static CR = static CR regardless of if there is more "mixture" in the cylinder... 854cc of gas/air mixture in a 354cc area doesn't make more power than 614cc of mixture in 248cc of space. It makes the same. (but turbo engines have to spool... so... you don't have as much torque as the engine that has the same peak static CR but has it all across the bandwidth.) |
09-12-2012, 06:11 AM | #63 | |
Member#: 187834
Vehicle:06 2.5i impreza Red |
09-12-2012, 10:40 AM | #64 | |
Member#: 206851
MWSOC
Vehicle:56 Belair Pro Street |
09-12-2012, 01:05 PM | #65 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
8 year bump, woo hoo!!
09-12-2012, 02:39 PM | #66 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Damn zombie-necro-thread..... Good info in here for those that cared to read it all.
~Josh~ |
09-19-2012, 01:33 PM | #67 | |
Member#: 180769
NESIC
Vehicle:lots of junkers |
If you have 850cc's of burning mixture you are going to produce more heat and more energy than 615cc's will. The pressure will stay higher longer inside the cylinder as the piston moves down, imparting more turning force to the crankshaft. |
05-19-2018, 11:35 PM | #68 |
Member#: 484800
And 16+ years later LOL!!!
This is a good read - I love looking at different schools of thought when it comes to building power. Since this thread was started new technologies have been developed, and old technologies have been honed and improved upon. Something I'm itching to do is exploit the daylights out of ceramics - I'd love to coat the pistons, combustion chambers, exhaust ports, cylinder walls... anything that sees a flame, coat it in ceramic. It reflects heat back into the combustion process, providing for a more complete burn. Plus, that coating has much less friction than oil on steel, freeing up even more power. Add to that the advent of gapless piston rings, and suddenly the engine isn't losing ANY intake charge to blow-by. Ever. So now this engine is burning ALL of its fuel with no leakage, doing so more completely due to the ceramic coating on everything, with less friction thanks to that same coating... and now with these gapless rings it can do so more reliably and with less maintenance. No blow-by means no soot or raw gas getting in the oil, meaning more miles between oil changes. Now, enter ceramic bearings. They already make turbos with ceramic ball bearings and titanium impeller shafts. The ultimate in quick/fast spooling, in essence a smaller turbo making bigger boost quicker. They even make ceramic differential, wheel, and axle bearings now. They're much lighter, much tougher, and MUCH less friction than steel bearings. They aren't cheap by any stretch, but when you consider the potential they have in differentials and transmissions both manual and automatic, we have the ability to greatly improve the efficiency of how the engine puts power to the ground. There are even coatings to reduce friction between gears, now. A win-win really, because less power loss means better fuel economy. Theoretically, a more efficient, less powerful WRX can outperform a more powerful, conventional WRX - all other things being equal. I'm stoked to see - maybe even find myself able to use - all this stuff in a build of my own one day. Last edited by Stites; 05-19-2018 at 11:39 PM. Reason: forgot something |
06-01-2018, 11:00 AM | #69 | |
Member#: 175624
MWSOC
Vehicle:0304 WRX WRX SY WRB |
I have seen people sing the praises of ceramic coatings for the entire combustion chamber in vintage cast iron muscle car engines, but there's no turbo downstream in those cases. |
07-25-2018, 03:37 AM | #70 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
not to burst your bubble, but the ceramic bearings in turbos dont allow you to make more power just like ball bearings dont allow you to make more power. turbos are still octane limited and you look at these guys with their smaller turbos having to push 30+ psi to get the power out of a smaller turbo. |
Similar Threads | ||||
Honda S2000 CR vs. Nissan Nismo 350Z (Road & Track) | NYCshopper | Non-Subaru News & Rumors | 17 | 11-07-2007 04:19 PM |
Accessport Live Boost Accuracy vs Boost Gauge? | AKGC8 | Engine Management & Tuning | 28 | 12-06-2005 06:54 PM |
EJ25 vs boost vs 420cc injectors??? | OB2 | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 10-01-2004 04:59 PM |
New CR, Off Boost Fuel Adjustment (Link Plus) | Graham | Engine Management & Tuning | 2 | 01-29-2004 04:21 PM |
CR vs Boost Preesure Explained (continued) | SomeoneStoleMyName | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 01-28-2002 03:58 PM |
