06-02-2009, 01:11 PM | #1 |
Member#: 179551
Vehicle:2003 WRX World Rally Blue |
TURN SIGNALS? Nothing?
okay so here is the deal my wife has a 2006 impreza wagon and recently her turn signals just stopped working you hit the lever nothing on the outside and nothing on the inside in the dash? checked the fuses and they looked good? so what could be my problem? relay? please help
06-02-2009, 08:15 PM | #2 |
Member#: 100117
VIC
Vehicle:2009 Impreza 2.5i Satin White Pearl |
It might be the turn indicator stalk with a loose connection (or malfunction). Have you check that yet?
06-02-2009, 11:33 PM | #3 |
Member#: 179551
not yet what do i have to pull to get to that?
06-03-2009, 08:51 PM | #4 |
Member#: 100117
VIC
06-03-2009, 01:27 AM | #5 |
Member#: 179551
check it and nothing????
06-03-2009, 03:19 PM | #6 |
Member#: 24464
Vehicle:2007 WRX STi (SWP) Surgeline Tuned |
Try cycling the hazards button.
Turn it on: do hazards flash? Turn it off: did they go off? Now do the turn signals work? |
06-04-2009, 12:15 AM | #7 |
Member#: 190724
Vehicle:2008 2.5i Sedan Lightning Red |
no one suggested checking the flasher? the flasher is just a relay that can eventually go bad. do the hazards work?
06-04-2009, 06:27 AM | #8 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
It is important to see if the flashers are working like SonicWRX and Bcware suggested. If not then the flasher needs to be replaced, if power has been verified that it is getting to the flasher first.
06-04-2009, 05:48 PM | #9 |
Member#: 179551
the hazards do work i cycled them and nothing. weird that the hazards will make the turn signals work but they don't work from the column?
06-05-2009, 04:06 AM | #10 |
Member#: 53443
The hazard switch switches power to the turn signal module so be sure power is getting to the brn/red wire of the turn signal module. If that is ok then maybe the turn signal module is bad.
06-05-2009, 09:52 AM | #11 |
Member#: 201438
Did you recently do any sort of electrical modifications? If so you will need to plug in a code reader and reset the codes for your car. The same thing happened to me about 2 weeks ago.
06-05-2009, 11:35 AM | #12 |
Member#: 53443
Resetting the codes will have nothing to do with the blinkers working. If that happened when you cleared yours it really wasn't due to that action.
Similar Threads | ||||
Front turn signal, brake light, and running light won't turn off | Floor it | Electrical & Lighting | 0 | 06-27-2009 10:34 PM |
im sure its been beatin to death but my search turned up nothing | pestysti | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 02-22-2004 05:01 PM |
Turning the side marker light into a turn signal | romanom | Interior & Exterior Modification | 3 | 03-20-2002 08:48 AM |
('93-'01) WRX turn signal bulb size?????? | BkylnWReX | Impreza Forum | 0 | 06-02-2001 05:19 PM |
