05-21-2007, 08:47 PM | #1 |
Member#: 11616
Vehicle:1998 2.35RS-T 2006 Baja 2007 Leg. Wagon |
Strange (to me) starting problem
Okay, I'm having some trouble getting my car to turnover. Its been sitting for right around 1 full year without being started or even cranked. I've kept a battery tender (for gel cell) on my optima yellow top, and it shows to be 13.6 volts. I can put the key in the ignition and the dash lights will come on. The MOMENT I turn the key to engage the starter I lose power to EVERYTHING. I can check the battery and it shows 13.2-13.4 volts - no popped fuses. Continuity from battery terminals to starter terminals. I even show 12+ volts on the fuses inside the cabin.
I do have a Hydra EMS if that makes a difference. PLEASE help me! Its stressing me out. I haven't got to start my car in over a year and I'd like to hear it again. *edit* I forgot to mention that after about 5-15 minutes the dash lights will come back on and I can go thru the same process again Kyle
05-21-2007, 08:56 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Make sure all your power and ground connections are tight and clean, particularly the battery terminals and main grounds. A poor connection at the battery will cause exactly the symptoms you are reporting. You should pull the terminals off the battery to look at them, there can be deposits inside or on the posts that aren't visible otherwise.
05-21-2007, 09:12 PM | #3 |
Member#: 11616
Checked terminals, looked clean. Cleaned anyways. Same result
05-21-2007, 09:26 PM | #4 |
Member#: 11616
Loose ground strap - thanks!!
05-21-2007, 09:31 PM | #5 |
Trust no one
Measure the voltage at the battery while you are trying to crank the engine. It should be 10V or above, if it dips much lower the battery may be NG even though the no-load voltage appears normal.
If the voltage does NOT drop when attempting to start, I'd look for a bad connection someplace. Probe with the voltmeter between the battery terminals and various points in the positive and negative lines, while either engaging the starter or turning on some high-current accessories (lights, defroster etc.). You should not see more than a fraction of a volt drop anywhere, if you do that is where you need to look for a problem. edit- ok see that I typed all that for nothing. Oh well at least you found it, I'll leave this for future reference. |
05-21-2007, 10:32 PM | #6 |
Member#: 11616
Thanks mulder - thats basically what I did but under no load conditions. I started checking the voltage from the positive terminal to each individual ground point. I eventually found one that read 2.7 volts at the anchor point and 13.6 on the wire. This was obviously the loose connection.
Trying to troubleshoot a problem before I start taking things apart... | RuskeR | Car Audio, Video & Security | 3 | 12-20-2007 08:53 AM |
Strange noise when starting in reverse | six3jag | Transmission (AT/MT) & Driveline | 1 | 07-16-2007 10:41 PM |
Strange (to me) starting problem | Andursun0013 | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 05-21-2007 10:30 PM |
Having problem with (new to me) used legacy AWD | evm1024 | Transmission (AT/MT) & Driveline | 6 | 09-30-2006 02:04 AM |
Weird(to me) electrical problem | TwinkE | Electrical & Lighting | 5 | 10-23-2003 10:14 PM |
