Brakes & Suspension Forum sponsored by The Tire Rack |
03-08-2004, 06:54 PM | #1 |
Member#: 14908
Vehicle:2002 PSM WRX Sedan Exhaust, IC Spray, RE92s |
Front sway bar worth it?
I've sold myself on getting the Perrin rear swaybar (w/ heavy-duty mounts) and Perrin endlinks, but I'm not quite sure yet about the benefits of an upgraded front swaybar.
"Improved stability, turn-in, and steering response" There's some good info on this thread, but I'm still not sure whether or not to get the front swaybar as well. For those who have done the install... how is it? Taking the subframe off doesn't seem too bad, but it seems lots of people are worried they'll screw something up. Is it really that hard? I don't AutoX/track (yet) so I'm just looking for better handling / less body roll / less understeer on the street. Thanks, Trevor
03-08-2004, 11:37 PM | #2 |
Member#: 14908
Can anyone with rear swaybar who added a front swaybar comment on how things changed?
03-09-2004, 12:25 AM | #3 |
Member#: 34723
NWIC
Vehicle:fwd FTL! |
i highly suggest doing it. it drastically increases turn in response and it really flattens out the car in the corners. there has been a lot of debate about whether or not it will add understeer which in all honesty it will, but it is a different sort of understeer than the car has from the factory. it actually adds a lot of grip to the front end of the car do to the fact that it actually wont let the front suspension go thru its full range of motion. a macpherson struts natural tendency is to increase positive camber thru its full range of motion which promotes the loss of grip. the fsb will limit how much of this positive camber is gained. when you get to the cars limit the bigger bar will make it understeer but you will have to push it a lot harder to get it to do that. you can easily eliminate this by just bumping your rear sway bar up one setting though. my front and rear bar have made a very neutral, flat, grippy setup. i wouldnt go back to not having a front bar.
03-15-2004, 08:03 PM | #4 |
Member#: 19435
NESIC
Thanks abaxter, I was wondering the same thing.
FSB sounds like just the thing I need/want. |
03-15-2004, 08:45 PM | #5 |
Member#: 5851
VIC
Vehicle:17 Ford Escape SE Blk |
I did it on my legacy and was definitely a noticeable improvement however I found the Whiteline ALK made more of a difference. I have since taken the front bar off as it was rubbing on my new headers. I've installed a Perrin Bar on a WRX and was not impressed as on one of the settings the bar was being forced to flip over (so the endlinks and bar were very low under the car). The design quality of the Perrin stuff seemed a little hokey and looks like they put minimal R&D into it, rather they just coppied someone elses bar and added a few minor changes.
03-15-2004, 08:50 PM | #6 |
Member#: 17498
South East
Vehicle:2016 Subaru WRX STi 2004 Subaru Imprza RallyX |
I would definitely suggest a smaller front bar...
Oversteer!!! Yay!! Isnt that what the SPT kit does? Smaller front and larger rear? Follow Subaru's lead - dow |
03-15-2004, 10:29 PM | #7 |
Member#: 34723
NWIC
Vehicle:fwd FTL! |
i have a wagon so i went with the whiteline front bar because they make one specifically for the narrower track. i didnt run into any of the problems that Tora mentioned. however it isnt adjustable, but i dont think the whiteline really needs adjustment, it feels perfectly suited to the car. i do like my perrin rear bar though. if your still thinking about putting one on there is some pretty good reading on the front bar in the motorsports forum, i trust a lot of those guys opinions because they obviously track their cars.
03-15-2004, 10:50 PM | #8 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
For the street, especially the roads aren't good where you are, the 'comfort' ALK and HD front endlinks may be a better option.
abaxter34 points out that the larger bar won't let the suspension go through it's full range of motion....bad juju on bad roads. Removing the 'slop' in the front end by stifining it structurally and by using stiffer bushings as well as increasing caster is a better way to go for a street driven vehicle, IMO. There is a HUGE amount of good info on suspension stuff here: http://svc007.bne143p.server-web.com/reviews03.htm |
03-15-2004, 10:57 PM | #9 |
Member#: 2135
Vehicle:2002 WRX Silver |
I've driven my front bar'd WRX sedan (set at 23mm) for the past year. As I was SCCA D-Stock legal, this was my only suspension modification other than Koni adjustable struts. The bar substantially reduced body roll, and increased total front end grip by reducing camber loss under compression. To compensate for the understeer resulting from the increased front stiffness, I simply increased the rebound in the rears with the Koni's. This resulted in a net gain.
You can bet your life that the STX car I'm driving this season will have front AND rear bars. -- Gary |
03-15-2004, 11:09 PM | #10 |
Member#: 16200
ConeMasher...what you say is all fine and good....but I really wish that people would stop trying to equate what works for a particular autocross class as to what works on the street.
The two are not the same thing. Just because they do it in D-stock does NOT mean that it is the best way to do it...it just means that that is what the rules allow in D-stock. |
03-16-2004, 07:28 AM | #11 | |
Member#: 12901
South East
Vehicle:2005 STi/95 VX Pastelito Racing / SFSOC |
What he said. I have the 22mm front whiteline and rear adjustable whiteline. Made a very big difference in driving on the autocross and on the street as well. k |
03-16-2004, 08:51 AM | #12 | |
Member#: 2135
Scotty, I didn't state "Here's my D-Stock setup, I recommend it for EVERYONE on the street, track, and rally". What I said was, even with JUST a front bar, I noticed improvements in performance, and that given the opportunity to run any configuration of bar (i.e. STX), that I would run BOTH.
I was just trying to answers the original question, which was: Quote:
-- Gary Last edited by ConeMasher; 03-16-2004 at 10:57 AM. |
03-16-2004, 11:11 AM | #13 |
Member#: 19435
NESIC
Might as well ask opinions on this:
What do you think of solid/stiffer endlinks for the FSB? I have a RSB I will install soon and will get endlinks and heavy-duty mounts for it. I heard it's not as important for the FSB. That true? or are stiffer endlinks a good investment? |
Front tower bar - worth it? | Screwbal | Car Part Reviews | 7 | 05-08-2009 11:55 PM |
2002 WRX – is changing to 21mm front and 22mm rear sway bars worth it? | JoeTX | Brakes, Steering & Suspension | 2 | 11-09-2005 10:07 PM |
Adjustable Front Sway Not Worth It? | draggin wagon04 | Brakes, Steering & Suspension | 23 | 05-02-2005 08:20 PM |
Front sway bar worth it in my case? | dman918 | Brakes, Steering & Suspension | 24 | 10-05-2004 09:40 PM |
Is a front sway bar worth getting? | JayByRd724 | Brakes, Steering & Suspension | 32 | 12-18-2003 01:34 AM |
