09-18-2010, 10:35 PM | #1 |
Member#: 219643
Vehicle:09 WRX Hatch |
09 WRX Power Steering Leak. Anybody else?
It's under warranty and they're fixing it. It's leaking at the valve where the shaft goes down into the rack and pinion. When I was at the dealership they had an STi up on the rack replacing the steering rack. Just curious if this is/has been a problem for others.
09-19-2010, 12:52 AM | #2 |
Member#: 143040
Vehicle:2008 WRX SWP with some gold |
I had to replace mine when I had just under 25k. Replaced under warranty.
09-19-2010, 03:56 PM | #3 |
Member#: 220629
SCIC
Vehicle:2010 White WRX Hatch 2015 White WRX Limited |
are you guys modified in anyway?
09-19-2010, 05:25 PM | #4 |
Member#: 219643
Nothing but the SPT exhaust that the dealership put on when I bought it.
09-22-2010, 09:34 AM | #5 |
Member#: 103399
E. Canada
Vehicle:2009 Stripped STI Dirty White |
I just had my rack replaced. My pump was replaced just before that. It still squeals and whines and sounds like ****.
09-23-2010, 12:03 AM | #6 |
Member#: 219643
The rack has been replaced under warranty. It feels pretty good. Now to wait for the next problem to pop up...
11-15-2011, 11:25 PM | #7 |
Member#: 208296
SCIC
Vehicle:2012 Chrysler 300 2015 Jeep Grand Cherokee |
Old post but I can't really find anything current. My rack just started leaking where the shaft goes in. 66,000 miles. Hopefully they won't deny my warranty (gold package) considering my swaybars, coilovers, etc.
02-22-2012, 12:10 PM | #8 |
Member#: 206579
Vehicle:2009 WRX Obsidean Black Pearl |
Reviving an old thread as well.
Just turned 50K and my steering rack is leaking like a bitch. Same place as mentioned above...where the two lines come into the rack by the valve. 09 WRX with Whiteline Steering rack bushings I was told my warranty will not cover it (steering rack isnt considered part of the powertrain warranty). How difficult is it to install a new rack and get the fluid bled? |
05-11-2012, 01:18 PM | #9 | |
Member#: 203940
Vehicle:2014 FR-S Raven |
11-26-2012, 11:53 PM | #10 |
Member#: 130742
South East
Vehicle:2011 sti red |
My 2011 sti just started doing the same thing am at 39,xxx don't think they will cover it under Warranty but **** not cool as all!!
01-01-2013, 01:53 PM | #11 |
Member#: 330162
Humby45 where did u have it done at?
01-15-2013, 10:55 PM | #12 |
Member#: 201721
SCIC
Vehicle:2010 WRX STI Satin White |
I just found out I have the exact same leak, 2010 STI 44k miles. Any info helps
02-28-2013, 05:07 PM | #13 | ||
Member#: 235475
PRSIC
Vehicle:2008 WRX Silver |
I told the dealer about having lowering springs and sway bars, and they told me that suspension warranty is lost, but the steering rack is a completely different system and not related to suspension in terms of warranty. What I forgot to mention was wheels. Although they're 17x8, they sit on 235/45, so I don't know what they'll say about that... I'll update when I'm carless, bored out of my mind, with nothing else to do but browse the web... Quote:
There are plenty of guides to replace the rack. I know because I was planning on doing it myself until I decided to call the dealer. My recommendation... be sure about everything you'll need, check the OEM catalog from subarugenuineparts.com, and get some help. Also, check ebay item 170969343419... Full rack with joints, and only driven for 5K miles. |
03-29-2013, 04:04 PM | #14 |
Member#: 229971
Vehicle:2009 WRX w/ SF hotbox |
Add mine to the list. 09 WRX 46,xxx. Slow leak
03-29-2013, 04:28 PM | #15 |
Member#: 235475
PRSIC
Well... Went to the dealer... They "re-sealed" the rack, and told me that it would need replcement if it happens a second time... Not because anything was wrong, but because it was policy. Everything seems fine now, so we'll see...
03-29-2013, 06:03 PM | #16 |
Member#: 242205
Vehicle:2009 I don't know Dirt |
Mine started leaking with 5k on the odometer. They replaced it under warranty and hasn't leaked since, 86k
03-29-2013, 08:44 PM | #17 |
Member#: 220629
SCIC
67k miles, several track days, and absolutely no maintenance on the power steering. No leaks.
04-01-2013, 01:50 PM | #18 |
Member#: 73223
SCIC
Vehicle:2009 STI |
09' STI leaking rack replaced at 40K SOA good willed parts. Bad pump replaced at 60K SOA goodwilled parts. Pretty sad at that mileage if you ask me...
01-07-2014, 11:46 PM | #19 |
Member#: 73223
SCIC
Vehicle:2009 STI |
Bump- third rack and lines just went in at 75K. Pathetic engineering. While SOA helped out with a few hundred bucks off its time to sell a lemon.
If I do decide to replace it with another STI I'll be forced to pay for the longest warranty. |
01-08-2014, 01:17 AM | #20 |
Member#: 303678
my 2010 wrx started leaking at only 28k miles...My local dealership would no replace it under my factory or extended warranty due to my coilovers. They tried to hit me with a $1200 bill...after much fighting and hassling i just traded the car in. I was tired of dealing with them and was just pissed bout the whole situation, they kinda killed my love for that car...
01-08-2014, 03:32 PM | #21 |
Member#: 377887
Vehicle:2004 Impreza WRX San Remo Red |
Hey man get a o ring kit and replace the o ring that is on top of you PWR steering pump, i dont know what its called but there is a line that goes to the top of the pump if you replace the o ring i bet it will solve your whine problems. I have done it to my car, i was so close to buying a $500 power steering pump(only way to get the o rings for my year model, but i ended up usuing a o ring kit from advanced). But a 40 cent o ring fixed my problem and about 4 or 5 other WRX and STI's in our shop. With a Power steering whine.
01-08-2014, 04:57 PM | #22 |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
2010 wrx started noticing my PS fluid disappearing at about 55k. Its a very slow leak and I think I'v pinned it down to turning the wheel to full lock
I'v been careful not to take turns at full lock for awhile now and haven't noticed any fluid loss. I really need to fix that **** though |
02-09-2014, 11:47 PM | #23 |
Member#: 348963
Vehicle:2008 WRX Lightning Red |
My 08 wrx started leaking from the pinion valve at about 80k.
If this happens, just replace the entire rack, don't do what I did and just swap out the pinion valve, more trouble than what it is worth. |
02-10-2014, 09:21 PM | #24 |
Member#: 379827
Vehicle:2010 WRX Impreza Racing blue |
This appears to be a common theme, mine started to leak at around 48K miles, a bit annoying seeing this is very low miles IMHO. Ended up having the dealership fix it, did not replace the rack, they pulled it, fixed a $15 seal, threw it back and charged me about $400. I was happy with the dealer, they are great, but called Subaru and complained whined to them for a bit. I don't mistreat the car.
02-10-2014, 11:36 PM | #25 |
Member#: 73223
SCIC
Vehicle:2009 STI |
Steering components are clearly substandard in these cars or defective. I've never had a pump or rack go out in any car even 200K mile beaters. Hope the 2015s get an upgrade...
Similar Threads | ||||
2002 wrx power steering leak HELP | vettedriver986 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-12-2010 10:53 PM |
Power Steering Leak, where at those loose fittings? | 275Performance | Service & Maintenance | 0 | 05-03-2003 11:46 PM |
Power Steering Leaking!! | waezsn | Service & Maintenance | 2 | 02-09-2003 06:12 AM |
power steering leak | thng | Service & Maintenance | 2 | 10-19-2002 04:04 PM |
