Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 03-17-2007, 10:00 AM   #1
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Default My take on hauling tires on the hitch.
Some may have seen or have the Tire Tail for hauling their rims & tires.
I have heard the Tire Tail jiggles a bit on the highway.
http://www.izoomgraphics.com/index.p...products_id=10
Some like the small trailers available at Menards or Harbor Freight (I have the 4'x8' one my self).
If you know some one or have a welder & feel competent, the material will total up to $70-80
I took a very short receiver tongue with a 2" rise & ground off the powder coat.
1 - 2" x 3/16" x 4' angle
2 - 1.5" x 1/8" x 4' angle
1 - 1.5" x 3/16 x 3' angle
1 - 1.5" x 3/16 x 3' flat
1 - 1" x 1/8" x 4' angle
8 - 1.5" steel rings
The interior dimension of the frame is 48" x 19.5"
Platform Weight - 28#
Bottom of tires off ground - 9"
The pics here have a set of 225's on them.
I added three LED marker lights to the rear wired in for L,R, & Tail operation
As shown in the overlay pic the centerline of the weight is about what the Tire Tail appears to be.
The Tire Tail puts the tires on a longer arm higher up as well.
GLwagon is offline   Reply With Quote
Old 03-17-2007, 11:19 AM   #2
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
I LOVE IT! I use my S10 to haul stuff in but making your own ***** is the *****. Post more when you are finished.
nottofast is offline   Reply With Quote
Old 03-17-2007, 11:20 AM   #3
Vikingmoose
Member#: 50319
2006 STI
Props to you for being creative and finding an alternative solution. Subscribed for curiosity to see how the finished "product" ends up.
*EDIT - How low to the ground does that thing sit? It seems like you could easily scrape the bottom if you went up a driveway or something. Does it feel sturdy? (Compared to a Tire-Tail if you've tried one)
Vikingmoose is offline   Reply With Quote
Old 03-17-2007, 11:25 AM   #4
REX8
Member#: 24038
Did you do the math on that? Structurally that is?
Besides that, you're certainly over the tongue weight of an Impreza...so keep in eye on it. 5 g's in bump with 160-190 lbs of wheel/tire can do some damage (to the rig, let alone rear shocks, etc.). I know a trailer is more expensive, but if money was no object, a little 4 x 4 for $170 is hard to beat.
+1 on doing a cool little project, let us know how it works out.
REX8 is offline   Reply With Quote
Old 03-17-2007, 06:14 PM   #5
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
I'm biasing the tongue weight on the distances & leverage of the Tire Tail.
As far as structural design there is triangulated bracing underneath that is hard to see.
I compared the thicknesses of material to the platforms that are rated up to 400-500#
The bottoms of the tires will be approximately 9" off the ground.
Old 03-17-2007, 07:34 PM   #6
REX8
Member#: 24038
The bottoms of the tires will be approximately 18+" off the ground.
The tire tails shape is stronger than a single straight beam in shear. The platform may be fine for 400 lbs, but your max tongue weight is only 200...and your weight is placed further out then that tongue weight spec is given for. You are exceeding that by a fair amount I'd bet.
Just playing devils advocate here, as I know a lot of cars actually sustain some damage using tire tails, and of course, over long distances, that weight does a number on your shocks.
I've run a platform before, bought from Home Depot, much like the one you have, so I'm not saying its not fine...just typing my thoughts after using mine for a while and deciding on a 4 x 4 trailer instead.
Old 03-17-2007, 08:04 PM   #7
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
The actual weight we are dealing with is:
40# a tire = 160#
Platform = 28#
So we are at 188#
Yes, the leverage concerns me.
I'll be doing a comparative check on the load centerline VS. the "Tire Tail".
Having the load more in line (low) with the hitch will help with load stability.
The leverage of the Tire Tail really makes me wonder how much abuse a hitch will take.
As far as my struts in the rear, that is minor compared to other issues.
Old 03-17-2007, 11:02 PM   #8
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
Here is the Tire Tail on an overlay with my car...
The weight center line appears to be very close.
Any thoughts?
Old 03-18-2007, 12:25 PM   #9
WRX11
Member#: 26638
One thought comes to mind from one of your pictures are, can you be tickets for blocking your brake lights/turn signals?
Are there any hooks in your trunk that you can anchor a pair of straps/tie downs to support it even further? Hopefully your trunk will close with the straps taunt.
Maybe straps from the rear wing deck?
The last one was a joke..
WRX11 is offline   Reply With Quote
Old 03-19-2007, 06:27 PM   #10
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
The blinkers are unobstructed, & the brake & tail lights are 1/2 covered.
I added the marker lights to the rear so that there is something more.
Old 03-19-2007, 08:30 PM   #11
gotsol
Member#: 17346
08 Cayman S
looks good. I've used the Harbor Frieght trailer and now I use the tire tail.
What kind of damage can the tail cause on a car? I've used mine for a couple of years with no problems.
gotsol is offline   Reply With Quote
Old 03-19-2007, 09:08 PM   #12
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
Here is some information taken from Hidden Hitches Website & Instruction Manuals.
http://www.hiddenhitch.com/
WARNING: With a 5000 lb. rated receiver the cargo carrier can carry a maximum 500 lb. load,
with a 3500 lb. rated receiver it can carry a maximum 300 lb. load. DO NOT EXCEED lower of vehicle mfg’s or hitch mfg’s maximum tongue
weight rating.
WARNING: Not for transport of people, animals, or flammable liquids.
WARNING: If the load or cargo carrier blocks or impairs visibility of the taillights or turn signals, the optional light kit must be used.
Class I
Class I hitches are weight carrying (WC) hitches rated up to 2000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 200 lbs. The use of a drawbar and hitch ball of the same rating or higher is required. Some hitches in this class may attach to the vehicle bumper or trunk pan. Most other Class I hitches attach to the vehicle frame. Always consult your owner's manual for vehicle rating.
Class II
Class II hitches are weight carrying (WC) hitches rated up to 3500 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 300 lbs. The use of a drawbar and hitch ball of the same rating or higher is required. Class II hitches normally attach to the vehicle frame and or bumper. Always consult your owner's manual for vehicle rating.
Got my summer rims and tires on! buuuut... ricepapertiger Mid Atlantic Impreza Club -- MAIC 25 04-05-2010 04:58 PM
Stock Z06 on Stock Tires in the 10's AllForSRT Non-Subaru News & Rumors 131 12-06-2007 10:52 AM
Latest pics of my car, with new tires on ---> 265/35/18. JDM addict Member's Car Gallery 84 12-23-2005 01:28 PM
Easy Streets WRX goes 10.7 @ 135 on street tires. *Need the Video Hosted* Ryan Autry Proven Power Bragging 20 08-13-2002 11:16 PM
buy my stock 16" wheels/tires at the tri-state meet? BashoPoem Tri-State Area Forum 6 07-16-2002 10:07 AM
