#1 |
Member#: 507873
![]() I have a 250W RMS A/B amp for my mid range speakers and 1000W RMS Class D for a sub in my 2012 Impreza, so at max power draw probably 1750W going into the amps.
I have an issue where the headlights will dim for a fraction of a second when the sub hits hard, but they almost instantly go back up to full brightness. I know a lot of people say caps are useless, but I've also heard that's because most people had no idea what they were supposed to be used for and just slapped them onto setups that didn't need them. I'm guessing the reason my headlights dim for a fraction of a second when the sub hits (even if it's an ongoing bass note) is because the alternator takes time to catch up to increased power demand. I'm almost positive I can actually feel the alternator being loaded and unloaded repeatedly if I'm driving at a low speed and the sub is hitting hard intermittently. It makes the entire car jerk slightly like I'm tapping the brakes a tiny bit. From what I understand, that's exactly the only valid use case for a capacitor, right? It's supposed to bridge that gap to prevent major voltage drop for a fraction of a second while the charging system ramps up. For what it's worth, when the sub hits the charging voltage on the car when parked/idle only drops from 14.4v to 14.3v on my multimeter. The multimeter isn't fast enough to catch the initial super short voltage drop when the sub hits though. So... cap: yes, no?
#2 |
Member#: 103273
SWIC
Vehicle:2002 WRX 2.15 18gxtr Sedona Red Wagon |
![]() A cap is really a band aid in this situation. If your amperage needs are exceeded by your accessories, the fix is a higher amperage alternator that will meet your requirements. When I bumped into this year's ago I used ohms law to figure out that I needed about 10 more amps than the stock alternator was putting out. I used these guys to get a new alternator with higher amperage.
https://www.maniacelectricmotors.com/ |
#3 |
Member#: 283194
RMIC
Vehicle:2017 STi and '05 WRX WRB and PSM |
![]() Caps are outdated.
Big 3 upgrade! It's cheap and effective. I'm running more draw then your setup, and it fixed my drop. Big three consists of, Upgrading the power wire from alternator to battery. Upgrading the ground wire between battery ground and engine ground. Upgrading the ground wire between battery ground and chassis ground. Whatever gauge power wires you add off your battery need to be upgraded for the big 3. I.E you ran 4ga to your amps, add 4ga wire between the three points listed. |
#4 |
Member#: 283194
RMIC
![]() Double post for double power!
#5 | |
Member#: 507873
![]() Quote:
#6 |
Member#: 510366
![]() I think yout at the alternator now man, i have seen some big power set ups that run a whole second deep cycle marine battery. Then when all that fails, caps.
#7 |
Member#: 103273
SWIC
![]() If your wattage info is correct, ohms law shows your peak use current draw as 125amps. 1750W/14V=125 amps.
From what I could find on a quick search, your car has a 110amp alternator. Thicker gauge wire or large capacitors won't "fix" your issue. |
#8 |
Member#: 103273
SWIC
![]() That is just your audio we're talking about. You still need the required amperage the car requires to run correctly.
#9 | |
Member#: 507873
![]() Quote:
I was looking at a high output alternator at one point, but I don't know who to trust. I'd rather get the stock one rewound if that's still a thing, but I was unable to find any services like that, and unsure if it'd be cheaper than just buying a good HO alternator. "power bastards" has a drop in one supposedly, but everyone says they're an absolute garbage company. Last edited by IHaveAHorse; 06-11-2023 at 04:47 PM. |
#10 | |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
![]() Quote:
Anyway, does sound like an upgraded alternator is in your future. Does it happen when you're driving or just at idle? |
