Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2025
Old 04-23-2004, 10:39 AM   #1
speedway7414
Member#: 60253
Question Service Bulletin WWP-99: Coolant Conditioner Additive = Head Gasket leak??
speedway7414 is offline   Reply With Quote
Old 04-23-2004, 11:31 AM   #2
poison
Member#: 37678
Make an appointment to take it to the dealer for the leak. Since it is already leaking (apparently) they will have to fix it. I wouldn't put the additive in until the issue is resolved.
I wish mine would leak before my 60,000 is up so I could get it replaced, but I had the goop put in. Now I am sure it will start leaking at 100,001 miles...
poison is offline   Reply With Quote
Old 04-23-2004, 03:59 PM   #3
C-daleRidr
Member#: 18074
2008 Speed3
Originally posted by speedway7414
Head gasket problem?
A month ago, my Suby started running really hot. I checked the antifreeze levels and ended up pouring 3/4 gallon into the radiator- a lot.
Recently, I received this Service Bulletin for a conditioner to be added to the coolant system to avoid head gasket leaks.
Since I believe my head gasket has already been leaking, I am concerned that only adding a conditioner is a band aid measure. I do not want to have the problem resurface once I am out of warranty, or have this existing leak reduce the long term reliability. My 2000 Suby has 48k on it, and I have an extended warranty to 100k or 2006. I expect to get 200k+ miles out of the engine.
*** Any experts out there willing to offer some advice/insight on importance of getting the gasket replaced, and ideas on how to negotiate this?
Thank you in advance for you assistance
Hate to be the resident asshat, but it's never bothered me before: There's a thread over in the warranty forum about this. It may be buried, but if you search for the bulletin number in that forum you'll find more information. I've said my piece there, and counted to three...
C-daleRidr is offline   Reply With Quote
Head Gasket leaking coolant credekop Warranty Issues & SOA Problems 12 08-08-2009 02:17 AM
Engine coolant... possible blown head gasket? WRX_REED Normally Aspirated Powertrain 2 05-07-2005 07:28 PM
Service Bulletin WWP-99: Coolant Conditioner Additive = Head Gasket leak?? speedway7414 Service & Maintenance 12 05-11-2004 10:15 AM
Service Program Bulletin WWP-99: Engine Cooling System Conditioner speedway7414 Warranty Issues & SOA Problems 2 04-24-2004 12:35 PM
Both Head Gaskets leaking on a 2001 :( 2001LegactGT Legacy Forum 7 05-26-2002 11:39 AM
