Welcome to the North American Subaru Impreza Owners Club Wednesday July 16, 2025
Old 12-31-2009, 12:15 AM   #1
A5un
Member#: 174095
2011 EVO X MR
Default 08+ WRX SPT Short-shifter kit
Hi,
I looked around but can't seem to find the information. So here I am...
The SPT short-shifter kit, does it use urethane bushing? I'm considering changing them if they're not already urethane ones to improve the shift feel.
Thanks.
A5un is offline   Reply With Quote
Old 12-31-2009, 08:11 AM   #2
HyperSl4ck3r
Member#: 179982
2008 Impreza WRX STI
Obsidian Black Pearl
The SPT SS is junk compared to what you can get aftermarket for the same money.... Changing to a good Kartboy SS and the full bushing kit from TiC will make a bigger difference...
HyperSl4ck3r is offline   Reply With Quote
Old 12-31-2009, 09:21 AM   #3
A5un
Member#: 174095
2011 EVO X MR
^ How so? Is it further reduction in throw? Or is it just a more precise shift? I could use both really...
Old 12-31-2009, 09:31 AM   #4
JohnnyG
Member#: 164671
2009 WRX 265
The SPT SS will keep the OE geometry, which is a good thing. I've got the TIC holy shift kit, and would couple that with the SPT shifter.
JohnnyG is offline   Reply With Quote
Old 12-31-2009, 09:38 AM   #5
A5un
Member#: 174095
2011 EVO X MR
Are you talking about
http://www.turninconcepts.com/produc...roducts_id=321
That's the only one I could find on their website, and it seems the SPT SS owner would need a narrow pivot bushing (?) from what I read on their other product the super shifter set.
Old 12-31-2009, 10:06 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It depends which OEM SS kit they put in your car. That is something that is installed at the dealer and not at the factory. Problem is that the dealer sometimes uses the kit from the older cars which is different, but will fit. The newer 08+ kits have the same pivot bushings as the factory lever, but the older ones need the narrow version. The best thing to do is measure the pivot point. If it's just about an inch wide you need the narrow. If it's closer to 1.25" you need the wide.
Tony
Old 12-31-2009, 11:59 AM   #7
JohnnyG
Member#: 164671
2009 WRX 265
That's the one, yes. It made a big difference in the shifter feel, now it no longer feels like I'm stirring spaghetti when I shift.
FS: OEM / SPT Short Shifter kit for 08-09 STi nostra Drivetrain 10 04-25-2011 11:11 AM
FS: 08 WRX TWM Short Shifter klanner AKIC Private Classifieds 0 01-13-2009 01:58 PM
NEVER USED! BRAND NEW! Kartboy SPT and up to 01 short shifter kit with stay bushings thumpetto007 Drivetrain 12 07-23-2008 09:33 AM
Subaru WRX SPT Short Shifter 5 Speed WRX0520 Engine/Power/Exhaust 0 11-19-2007 09:44 PM
2007 WRX TR w/ spt short shifter linkage, with Cobb adjustable shifter lennyTR Car Part Reviews 0 05-27-2007 04:23 PM
