Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2025
Old 03-30-2003, 02:50 PM   #1
TheBaron862
Member#: 34073
2001 impreza 2.5rs
red
Default subaru awd vs audi quattro vs other systems
i just got a 2001 impreza 2.5rs coupe(5 spd) and i was wondering how the awd system compares to the audi quattro system that i previously had in an a4 and other systems that are currently on the market. what kind of advantages/disadvanteges do you get w/ the subaru awd system as compared to the quattro system and other systems?
TheBaron862 is offline   Reply With Quote
Old 03-30-2003, 03:10 PM   #2
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Well, you're going to have some confusion in the area of Audi Quattro and I guess to some extent in Subaru AWD as well.
Audi Quattro in the A4, A6, A8 (and S's) is one thing (VW Passat too AFAIR). Quattro/4motion in the TT, Golf, A3, is another thing. I believe the TT, Golf, A3 system is almost always FWD. The other is more AWD.
With Subaru AWD, your guranteed a center differential. Viscous in Manuals and most Autos. In the newer Autos(WRX,H6) you get VTD. In the rear diff of 2.5rs (pre 2002) and the WRX you also get an LSD. This system is 50/50(45/55 VTD) under normal conditions.
Zahnster is offline   Reply With Quote
Old 03-30-2003, 03:30 PM   #3
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
So, a 2001 RS sedan has a rear LSD?
el~sharko is offline   Reply With Quote
Old 03-30-2003, 03:35 PM   #4
Aphex28
Member#: 11506
2010 Legacy GT
1999 10AE Miata
yup
98-01 RS's have Rear LSD
Aphex28 is offline   Reply With Quote
Old 03-30-2003, 04:04 PM   #5
Max
Member#: 788
2023 MachE Nite Pony
Max is offline   Reply With Quote
Old 03-30-2003, 05:23 PM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Originally posted by Aphex28
yup
Max is correct, 2000 was the first year they came with the rear LSD, and the new bodystyle 2.5RS's do not come with a rear LSD. So 00 and 01 where the only years that the RS came from the factory with a rear LSD.
HondaH8er is offline   Reply With Quote
Old 03-30-2003, 08:34 PM   #7
liigod
Member#: 30512
01 2.5rs
black
here is the deal
quattro is better in turns on the road and their traction control is better
the skyline's awd is just plain cool being able to select rwd or a percentage to the front wheels
subarus awds are cheap and good all around, but they arent very durrable for racing
DCCD subarus are PIMPly nice and durrable
4motion is quattro
tt's can be converted to 50 50 front rear awd, they did it the otehr way just to save gas.
mercedes awd is too slow and crap
mitsubishi, i wont even coment because it is way to hot of a debate
the best awd really is a unicycle
liigod is offline   Reply With Quote
Old 03-30-2003, 09:04 PM   #8
PJ2.5RS
Member#: 33697
""subarus awds are cheap and good all around, but they arent very durrable for racing""
...in terms of things start wearing out & break, or it's just not a high performance system for the track?
PJ2.5RS is offline   Reply With Quote
Old 03-31-2003, 12:14 AM   #9
liigod
Member#: 30512
01 2.5rs
black
in terms of like redline drops :-D and high power applications i see a lot of second gear's going out, sure they werent designed for that so i dont discredit subaru, but its just something to know.
Old 03-31-2003, 08:31 AM   #10
Impresario
Member#: 344
2004 Impreza WRX
Java Black Pearl
Everything you would want to know about various 4WD/AWD systems:
http://home.attbi.com/~eliot_www/awd.html
Impresario is offline   Reply With Quote
Old 04-01-2003, 05:40 AM   #11
abaxter34
Member#: 34723
fwd FTL!
i've got a 1990 audi 90 quattro 20 valve which has a full torsen system with a limited lsd in the rear, electronically lockable rear diff. and an open front. i resently drove a 2000 rs in the rain and i was really surprised by how long it took for the driveline to transfer the power from the front to the rear. when the rear end finally kicked in it felt great, but at first i had my doubts as to if was going to transfer power at all. in my car it happens instantaneously due to the fact that all the diffs are mechanical. i was test driving the subaru from a local dealer who was kind enough to give me the keys and let me go off on my own for as long as i wanted. needless to say i hammered the **** out of that car and that was the only thing that really stuck out when comparing it to my car.
the a4, a6, and a8 all have the traditional mechanical torsen setup which requires that the engine be mounted longitudinally. the new a3, tt, and gti r32 all have transversly mounted engines due to packaging restraints and the pursuit of better balance. this has required audi to adapt the haldex type diff which uses electronically controlled clutch packs. this is the same system used in volvos. personally i don't like it because it is mostly fwd and it kicks in after front wheel slip is detected. vw's 4motion is not the same thing as a genuine quattro driveline. it uses a center viscous coupling.
as far a durability goes, with audis torsen you could do redline clutch drops all day. and contrary to popular belief, awd isnt any faster in corners. one of the reasons audi has done so well in touring car championships is due to tire conservation.
thats all i've got on audis, don't ask me about suburas, don't have a clue.
abaxter34 is offline   Reply With Quote
Old 04-01-2003, 06:50 AM   #12
sleepy-scoobie
Member#: 17463
Originally posted by liigod
here is the deal
4motion is quattro
Oh, so thats the deal, huh?
So skylines can select RWD? Do you mean an R32, R33 or R34? Try `selecting` RWD in an R33 and come back to us after you fly off the 2WD dyno. Skylines are biased towards RWD until the computer decides to direct drive to the front via a pack of electronically controlled multiplate clutches.
4motion is quattro, huh? Do you mean with the Haldex electronic differential or the Torsen mechanical?
The USDM Evo VIII has a viscous locking center differential, like the WRX, along with a open front diff. JDM Evo VII & VIII GSRs have a variable electronically controlled center diff (ACD). Note that the lighter, faster RS models (much like our Impreza TypeRA) don`t use the electronic gimmics, and that one of Mitsu`s reasons for not bringing it is because of its unreliability and higher maintanence requirements.
Funny, Ive never heard of a Subarus diff failing under `racing`... unless you mean drag `racing`... and 2nd gear failures has more to do with transmission design than with the type of AWD differentials. Redline drops? In second gear?
abaxter34, Your RSs AWD system is solid. It uses viscous locking units that are a good compromise in price and weight between viscous units and mechanical (like Torsen) diffs. Your A4 used Torsen mechanical diffs which have the fastest lockup of non-active diffs, but has the disadvantage of added weight and cost. Aggressive mechanical diffs also can make a car more of a handful under lockup conditions.
sleepy-scoobie is offline   Reply With Quote
Old 04-02-2003, 02:29 PM   #13
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
You sir, are a moron. This has nothing to do with AWD and everything to do with transmission design(as previously stated above).
Old 04-02-2003, 03:02 PM   #14
timatwood
Member#: 2920
The audi 90q20v has quattro II, which is torsen center, open front, locking rear. It doesn't have a limited slip rear, it is either locked or open (and only locks under 20 mph). I liked my 20v a lot, especially the rev-happy engine, but I like my 2.5RS just a little better (steering feel, handling).
I assume the RS that abaxter34 drove was the auto, which does tend to have a delay and a "clunk" when switching power rearward from spinning front wheels. If you drove the manual, you would be much happier. It handles a lot like the 20v, but will powerslide the rear a lot easier in the slippery conditions due to the limited slip rear.
The a4 has a torsen center with open front/rear, and uses the brakes to control wheelspin at each end. It can move with traction at only one wheel. The RS can move with traction at either back wheel or both fronts, same as the 90q20v with the rear end locked.
timatwood is offline   Reply With Quote
subaru AWD vs audi Quattro Subabert General Community 93 03-28-2012 09:18 PM
Audi Quattro vs. Subaru AWD spyguy General Community 65 12-28-2004 10:50 AM
Subaru AWD vs Audi Quattro? jcblack General Community 16 01-04-2004 06:43 PM
Subaru AWD versus Audi/Jaguar? BritDrew General Community 21 06-19-2002 08:56 AM
Subaru AWD Vs. Audi Quattro MrX General Forum Archive 13 09-15-2000 07:13 AM
