Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Old 02-09-2010, 09:21 PM   #1
Feal Suspension
Vendor Sales Rating: (1)
Member#: 227414
Default Replacement STI struts, 2004, 2005-07
These are OEM rebuilt and revalved struts for your 2004 and 2005-07 Subaru Impreza WRX STI. They will out perform and outlast your original struts. We can also sell you struts that are custom tailored to your aftemarket springs and or driving style/needs at no extra charge. You can mail back your old sti struts for a $350 core refund.
The Revalve Service that we perform to the STI struts includes:
Cleaning and re greasing strut housings (eliminates strut clunk)
Polishing out nicks and glazed spots from insert surface (long term reduction of strut clunk causing friction)
Revalving inserts (improves ride quality over stock)
High performance motocross grade shock fluid and nitrogen recharge (less change in ride comfort in cold weather)
*Installation of Zerk fittings ($20 extra)*
What the heck are Zerk fittings for?
We strategically place this fitting between the strut's bushings. This now allows you to add fresh grease to your struts without removing them from your car! When grease is worked away from the strut bushings, the strut begins to clunk. By applying more grease via a Zerk fitting, you create grease pressure between the bushing and fill the dry spots.
Your set up the options explained:
Tarmac Spec (most popular)- Great for high spirited driving utilizing the original or aftermarket springs. "Tarmac Spec" offers a more compliant and balanced ride over stock. There is a noticeble ride improvement driving on rough road surfaces as well as tighter curvy roads.
Gravel Spec- This is ideal for those who participate in Rallyx or demand more performance on gravel. Gravel spec valving is harsher at low vehicle speed, but resists bottoming at higher speeds and big ruts. There is more high speed rebound damping to control rebound speeds after the sturts get close to bottoming. We do not recommend this spec for daily driving.
Custom Spec- This is for those who have dedicated their cars to a specific use such as road racing or just want to run a spring rate that is much softer or stiffer than the original spring rate.
You can also choose to ship your struts in for the service:Save money on shipping by not sending us your springs or top hats. We will finish the work within 5 business days and ship them back to you. You can prepay using our website below, or simply send us your contact info and we will call you for your billing and shipping details. Going this route you will avoid the refundable $350 core fee.
2005-07 Cores in stock!!!
We now have struts in stock ready to ship for 2004 and 2005-07 models!
__________________
[B]Please do not send PMs, email or call us instead. [/B]
Like us on Facebook
Follow us on Instagram
Phone: (909) 930-1300
Email:
Feal Suspension is offline   Reply With Quote
Old 02-09-2010, 10:16 PM   #2
fourdegrees
Member Sales Rating: (15)
Member#: 49662
2005 FEALing fine
Um, wow. I can't wait to hear the reviews. Good luck guys. Hope this is a viable option.
fourdegrees is offline   Reply With Quote
Old 02-10-2010, 11:14 AM   #3
Feal Suspension
Member#: 227414
Default Price
I forgot to include the price. Introductory price is $400 for all four corners.
__________________
Like us on Facebook
Email:
Old 02-10-2010, 11:54 AM   #4
Swine
Member Sales Rating: (42)
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
Ok man, ive looked at your posts about this and im having a hard time figuring out what you are selling.
-Is this revalve only for stock springs or can aftermarket, higher spring rate, lower ride height aftermarket springs easily be put on with little ride consequence.
-Will this revalve ride better or worse then the oem shock/strut from a DD stand point?
-Is compression being hardened or softened?
-Is rebound being softened or hardened?
Basically, what are the oem shocks downfall? How will your revalved shock perform better then oem valving?
Really curious man.
Swine is offline   Reply With Quote
Old 02-10-2010, 02:28 PM   #5
Feal Suspension
Member#: 227414
Really curious man.
This revalve is for stock or aftermarket springs. If you run a much stiffer or lower spring we can custom valve your inserts, hence the "custom" option on the add. Same goes if you want to use a softer spring like WRX springs. There is no price difference for this option.
The ride qualiy will feel more balanced from a DD standpoint.
The oem shocks are improved by tuning:
-More compression damping to the front
-Less compression damping to the rear
-Less rebound damping to the rear
The graph illustrates the changes we make from the oem settings.
Hope that answers your questions, and thanks for asking.
__________________
Like us on Facebook
Email:
Old 04-10-2014, 09:24 PM   #6
edwinhui
Member#: 330608
are the price still active?
edwinhui is offline   Reply With Quote
Old 02-25-2010, 05:29 PM   #7
nickrice20
Member Sales Rating: (48)
Member#: 95153
2013 Impreza Sport
Do you have a service to take care of the strut clunk/stiction issue?
nickrice20 is offline   Reply With Quote
Old 03-02-2010, 01:02 AM   #8
subynation
Member Sales Rating: (4)
Member#: 229023
06 STi
obp
i can just send you the shock body only right?it would save on shipping vs send the whole shock/body.
subynation is offline   Reply With Quote
Old 03-02-2010, 11:00 AM   #9
07 Flt4bxr
Member Sales Rating: (1)
Member#: 159918
2007 STi
urban grey metalic
This service would rid strut clunk as the clunk is due to poor greasing and bad valves,which they say the replace....
This company is 30 min from my house. Im going to call them today
07 Flt4bxr is offline   Reply With Quote
Old 03-02-2010, 11:44 AM   #10
07 Flt4bxr
Member#: 159918
2007 STi
urban grey metalic
Feal suspension number is 661-435-0922 NOT 0933
Old 03-02-2010, 12:59 PM   #11
armyssoldierboy
Member Sales Rating: (3)
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Do yall have a core refund option? Kinda like Deutchworks... we pay more for premade struts from you guys then send you our stock ones and get refunded a portion? Being my dd I would need my suspension lol
armyssoldierboy is offline   Reply With Quote
Old 03-03-2010, 11:21 PM   #12
jdblock
Member Sales Rating: (8)
Member#: 235211
2004 STi
Can you make them adjustable? Add rebound and compression knobs?
jdblock is offline   Reply With Quote
Old 03-04-2010, 12:47 PM   #13
sti robot
Member Sales Rating: (35)
Member#: 110932
2012 STI hatch
I wish you guys had come out with this a couple of weeks ago. I would've loved to have had this option instead of buying d-specs (which clunk btw).
Shipping might be a bear with this service. Might want to tell people up front what they should expect.
sti robot is offline   Reply With Quote
Old 03-04-2010, 07:08 PM   #14
Feal Suspension
Member#: 227414
I'm sorry man.
We will ship these back for $30 anywhere in the continental States. (Springs and top hats must be removed for this rate).
Yes we can. Do not have a feasable price for that service yet.
I am looking for a few sets of Sti struts so I can offer this. I will do an exchange as soon as I have a few sets on hand. We only have "parts" struts at the moment.
Thanks. Can you send me the link where you found that number.
Yes. You would just be left with the fun of cleaning out the old grease and re greasing your strut bodies. We will ship back the inserts for $20 anywhere in the continental States. (No strut bodies, springs, or top hats)
The common clunking problem is solved with proper greasing, we do that during this service.
Thanks for all your questions.
__________________
Like us on Facebook
Email:
Old 03-11-2010, 08:01 PM   #15
SubieEngineer
Member Sales Rating: (53)
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
How long will you be running this special? I'm not completely sold on keeping my PSS9s, but would need something better-valved than OEM.
And to clarify, $400 for the revalve + $30 for return shipping (strut assemblies with inserts) + we pay shipping up-front from us to you...?
SubieEngineer is offline   Reply With Quote
Old 03-15-2010, 01:40 PM   #16
Feal Suspension
Member#: 227414
This price will be going for a few months. I want to get as many revalved units out there as I so people realize how well their sti suspension can perform.
You got the pricing right.
__________________
Like us on Facebook
Email:
Old 03-15-2010, 05:32 PM   #17
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Have you had anyone bite on this? Someone that we can maybe contact to get an idea on how it went for them in terms of the process, or how they like them?
Scoob_13 is offline   Reply With Quote
Old 03-15-2010, 09:44 PM   #18
SubieEngineer
Member#: 208152
2004 350Zed Base
I called earlier today and spoke to a helpful guy (can't remember your name, sorry!), and he told me they'd completed 2 revalves so far. I would like those 2 individuals (who are hopefully on this forum) to chime in.
Originally Posted by 07 Flt4bxr View Post
is there any long term data testing? what will happen to the strut in 6 months after the valving has been changed?
Really, I don't see any negative long-term effects (given my limited suspension knowledge). Even if there were any, OEM take-offs are pretty cheap used, anyway. It's basically like getting a brand-new strut at 0 miles (outside of the existing wear on the outside of the strut housing).
Old 03-16-2010, 12:24 AM   #19
07 Flt4bxr
Member#: 159918
2007 STi
urban grey metalic
possibly....hopefully u r right
Old 03-17-2010, 07:03 PM   #20
Feal Suspension
Member#: 227414
So I have been getting alot of emails and some calls for this service. I asked one of the first customers to write up a review of the service. He has had it for a few months now.
I should also have a few 2004 cores by the end of this month. You will be able to purchase a complete set of struts and send your old ones in for exchange.
I am still on the look out for some 05+ struts to keep for cores.
As far as long term data:
The way we service these inserts is very similar to the way we service most other inverted road and rally suspension. We have cars that have logged numerous horrific races on struts we service and revalve.
We use genuine KYB vavling shims from Japan when revalving these inserts. We also use the same motocross grade shock fluid as we do for all of the race cars we service.
__________________
Like us on Facebook
Email:
Old 03-15-2010, 06:31 PM   #21
07 Flt4bxr
Member#: 159918
2007 STi
urban grey metalic
Old 03-18-2010, 02:44 AM   #22
SubieEngineer
Member#: 208152
2004 350Zed Base
^ A few months! Sweet, let's hope he/she will chime in soon!
Old 03-19-2010, 04:06 PM   #23
409Industries
Member Sales Rating: (5)
Member#: 55553
2001 Impreza 2.5RS
I think i may have been the first one to have the Feal Suspension re-valved STi struts installed on my 04 STi. I have written up a complete review here.
Check it out if you're interested in this service, so far i am very happy with them!
409Industries is offline   Reply With Quote
Old 03-20-2010, 03:02 AM   #24
SubieEngineer
Member#: 208152
2004 350Zed Base
I read your review, great job! I'm seriously considering this, except getting the OEMs revalved to handle the RCE Blacks rates. I'm ditching my PSS9s and probably going this route with the Blacks and RCE lowering camber plates.
Old 03-21-2010, 02:15 PM   #25
Superorb
Member Sales Rating: (30)
Member#: 135252
2002 WRX Wagon
I've been eying the RCE Blacks for quite some time now.
Superorb is offline   Reply With Quote
NC: STi coilovers (rare), STi suspension, and WRX suspension dowroa Suspension/Brakes/Handling 7 06-01-2010 05:41 AM
SOCAL: VF34 + STI pinks + Cobb AP + 04 STI Suspension + 02 Suspension StepinRazor Private 'For Sale' Classifieds 21 11-10-2005 01:05 AM
STi prodrive suspension, oem exhaust, sti suspension.. more MikeRambot[KaM] Private 'For Sale' Classifieds 0 06-15-2005 04:10 AM
STi version suspension vs. STi suspension wrx_sti_ver4 Brakes, Steering & Suspension 0 08-15-2002 09:35 PM
('93-'01) RS with Prodrive WR suspension vs. WRX with STi suspension? danc Impreza Forum 4 10-04-2001 05:18 PM
