#1 |
Member#: 49222
Vehicle:2005 Legacy GT Wagon Limited 5MT 580whpQ16 |
![]() Does anyone know if their is such a thing? I noticed that the Hyundai wiring harness is the actual same size and shape as the Subaru wring harness. The wiring diagram is not the same, but the physical plug is. Just wondering if anyone has found anything that will plug into the factory radio on a 02+ WRX.
#2 |
Member#: 12170
MAIC
Vehicle:2002 WRX Sedan Platnum Silver Metallic |
![]() If you know someone who has trashed their factory sub (like me
![]() Dale |
#3 |
Member#: 72305
Tri-State
Vehicle:2006 Sti Sgm 15 FXT CBSP |
![]() ya, it will plug right in, but the pins are not going to match up in the wiring harness. If you really wanted to use one for the radio you could, however you should use a dmm to test for power, and speaker colors.
#4 |
Member#: 49222
![]() Actually, after doing some research online, I found that Scosche makes one. I found a place that sells it for $9. Thanks for your help guys.
#5 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
![]() The Scosche reverse harness lacks one of the illumination wires. The stock HU won't light up correctly without this.
I've been making reverse harnesses with all 14 wires. Send me an e-mail if you're interested. David C. |
#6 | |
Member#: 122209
![]() Quote:
I have an '05 WRX wagon and want to connect my ipod to the stock stereo. I read in your post above that you are selling harnessess to make this work. Is that correct? If so i would like to buy one. Thanks, Tim |
#7 | |
Member#: 25837
South East
![]() Quote:
Unfortunately, my harnesses won't enable you to create an aux input for you iPod. The easiest way to do that on the '05 radios is with a hack that you can install inside. See this thread: Subaru Radio Aux-in |
#8 |
Member#: 144220
![]() excuse my ignorance, but is this reverse harness so you can have an aux input on a stock cd player or so you can power an aftermarket amp/sub with the stock cd player. I want to power an aftermarket amp/sub with stock cd changer, do I just need a oem amp/sub harness? Please clarify for me. Thanks
#9 |
Member#: 15440
NWIC
Vehicle:2015 STi DGM |
![]() I need one of these wiring harness, I had to cut my harness from the stock amp when i sold my stock one, and i'm putting different stock one again, but it would be nice if i can just get the whole new cable for the amp or something
#10 | |
Member#: 25837
South East
![]() Quote:
The stock plug for the radio is part of the instrument panel wiring harness. A new one of those will cost >$100 (and require disassembling most of the dash). A replacement harness for the subwoofer is available too, price ~$75. What I'm selling is the 14-pin plug that plugs into the stock radio (AKA, a "reverse" wiring harness). The wires are about 6" long, with pre-stripped ends. It looks like this... WRX Reverse harness If you're interested in getting one, send me an e-mail (click on my user name at the upper-left corner of this post, then click the "send e-mail" link). See this thread on the SVX forums for testimonials from other satisfied buyers. Last edited by SVXdc; 10-31-2009 at 07:12 PM. |
#11 |
Member#: 331799
Vehicle:2012 Impreza Sport P Gray |
![]() SVXdc,
How can you be contacted to order one of your wiring harnesses? The system won't allow me to send you a PM. Thanks, MapDaddy |
#12 |
Member#: 11107
RMIC
Vehicle:2015 WRX STi Crystal White Pearl |
![]() SVXdc - you've got mail!
#13 |
Member#: 49222
![]() Thanks SVXdc for the spare pins and wires. If anyone needs a harness, he is the person to talk to!
Here is a pic of my finished product. Plug and Play RCA output harness for my stock 05 WRX radio! All this so I wouldnt ahve to hack up the factory harness. Notice the green/black wire under the orange. SVXdc supplied me with the extra wire and pin for both connectors so I would retain illumination on my factory radio. |
#14 |
Member#: 64466
MWSOC
Vehicle:05, STI on green |
![]() wow...thats very interesting.
#15 |
Member#: 55915
South East
Vehicle:04 WRX stage 1/2 Wr blue pearl |
![]() Not flaming bro but thats a no no, you shouldnt use twist caps or use crimp caps.
#16 |
Member#: 49222
![]() Says who? I have been installing car stereos for over 15 years and I couldn't tell you an isntaller that used a soldering iron on an everday basis. Hell, the last time I used a sodlering iron was when I was modifying my ecu board in my Honda a few years ago. I agree on the twist caps but crimp connections? Are you serious? Go to any car stereo shop and let me know if you see anyone soldering any of the connections. I can promise you that they will all be using crimp connectors and have a big bin filled with all sizes of crimp connectors and crimp caps.
#17 | ||
Member#: 25837
South East
![]() Quote:
![]() For more pictures and tips, see section 2.5.4 of my SVX Audio Install instructions (scroll down to steps 10 and 11, and click on the thumbnails for larger pics). It helps in the SVX, where there's very little space behind the radio. BTW, where did you find space to cram that LOC in the WRX?! ![]() Last edited by SVXdc; 10-31-2009 at 07:11 PM. |
#18 | ||
Member#: 49222
![]() Quote:
![]() Quote:
#19 |
Member#: 12170
MAIC
![]() I always use crimp-on bullet connectors. I like to be able to disconnect them whenever I want if I put in new gear or want to put it in another car (or realize that I've connected up the wrong wires by accident
![]() Dale |
#20 | |
Member#: 64374
MAIC
Vehicle:07 WRX SWP *SOLD 03 2.5ts BRP long gone |
![]() Quote:
#21 |
Scooby Scammer- Do Not Buy From User
Member#: 132902
MAIC
Vehicle:2006 wrx tr silver 99 BMW 323is |
![]() Just as a future reference Metra makes a reverse harness for just about every harness they make. Usually it just has different prefix check with metra online.
#22 | |
Member#: 25837
South East
![]() Quote:
As I said above, the Scosche reverse harness lacks one of the illumination wires. The illumination on the stock HU won't work without this. The whole point of a reverse harness is to use with a factory radio, so I don't know why Scosche continues making theirs with only 13 of the 14 wires. [Update:] Metra now does have a reverse harness. You still need to verify that it has all 14 wires. I keep looking periodically, and to date "forward" harnesses from Metra, Scosche, and all the other big harness manufacturers still have only 13 wires. Last edited by SVXdc; 04-02-2012 at 03:07 AM. |
#23 |
Member#: 353744
![]() Last night I installed the HU receiver above but this morning when I turned my headlights on the screen goes blue and the radio volumes goes to near zero. I then cannot increase the volume nor control the receiver in any way (just a blue screen). I wonder if you can help out. I used the appropriate harness, but if I leave off the orange wire (backup camera) would that solve the issue? I don't have a backup camera but the blue screen that comes on when the headlights show says something about the AV input or the backup camera.
Also I connected the pink (parking brake) wire to ground so the DVD player would work. Is this a grounding issue because the unit works great until the headlights come on? How do I get the headlights not to turn the stereo off? Please assist. Here is what I installed: Harness http://www.amazon.com/gp/product/B005EWTKAA/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1 |
#24 |
Member#: 353744
![]() The BOSS Tech dept got back to me in less than 8 hours! Here is there response.
If you do not have a back up camera connect to the unit then just disconnect the orange wire and that will fix your problem. Its seems that you have it connected to an illumination and that why it trigger only when the lights come on. Thank You for Your Time, Phillip D. Samuel Technical Support Department Supervisor |
#25 |
Member#: 132902
MAIC
![]() The shop I work at uses T Taps and crimp connectors on everything. Reason being that the average customer will be back in less than 2 years to have there stuff uninstalled and reinstalled in a new car and its just easier. In the last 6 years I have seen one t tap failure and it was because the installer used a red t tap on like 20 ga honda lock wires and it wasnt really a solid connection and it int. didnt work. On my vehicle I solder things just becasue I know I will have it for a while but in a biz where time is money solder just doesnt make sense.
WTB: complete wiring harness or plugs for the HID Leveling motors and leveling switch | Speedoponic | Private 'Wanted' Classifieds | 2 | 06-17-2009 11:11 PM |
NEED: Plug/Clip that plugs into WRX spark plug coil | BeBop86 | Private 'Wanted' Classifieds | 16 | 07-16-2008 03:05 AM |
wire harness that plugs in radio for gauges. | StarDogChampion | Car Audio, Video & Security | 4 | 11-05-2002 05:37 PM |
WRX Aftermarket Wiring Harness quick question | Schleppy | Car Audio, Video & Security | 7 | 04-05-2002 02:20 PM |
Cusco Shift Light that plugs into cigarette lighter..where to buy? | Mr. Ixnay | Mid Atlantic Impreza Club -- MAIC | 7 | 10-26-2001 09:02 AM |
