#1 |
Member#: 66426
![]() Update (10/24/05) #2: I have contacted iamrazor and he is willing to sell his 6 disc changer for $100. I am not positive that this changer will even work with the stock in dash unit, but it looks like the plugs match.
Is anyone else in the DC area willing to join in the project and help dissuade some of the costs? -Tad Update (10/24/05): Still no additional progress. Come December, I will have more available time to dedicate to this project. The next (crucial) step is either 1. Getting the spec for the communication bus OR 2. Getting an external changer that works with the deck that can be hooked up and "sniffed", to capture the necessary commands. If you know anyone that may be able to get us this information, please speak up. In addition, if you are in the Washington DC area and have an EE background and want to work on this project, let me know. Here is the original (as far as I know) that began to address this connector http://forums.nasioc.com/forums/show...hreadid=119963 ----------------------------------------------------- Update (7/19/05): I am still waiting to hear back iamrazor about the 6 disc unit he was going to pull. The service manual has been mirrored by a nice fellow here: http://jeremy.seeded.net/nasioc/WRX-...vicemanual.pdf ----------------------------------------------------- Update(5/27/05): Scanned the service manual, WRX-6disc-servicemanual.pdf (17.3mb) This link will only work until the end of June, so if someone else could re-host, that'd be great. ------------------------------------------------------ Update(5/25/05): In order to continue, I need your help. Read on... EDIT/UPDATE: A user on another forum (TTL), whom I have been unable to contact here http://www.subaruforester.com/viewtopic.php?t=3525 managed to get an external cd changer working with the stock 6-disc wrx unit. If i can get an external cd player working, I believe that I can "watch" the bus line with a data logger/scope and mimic that transmission with a small microprocessor. This would enable the aux in pins on the back of the stock 6-disc changer. A direct/wire aux input is NOT impossible like so many people claim, but I need your help. My first attempt involves the stereos from the following vehicles: BAJA 03-04 FORESTER 01-02 LEGACY 00-04 I believe these vehicles have a separate cd player and receiver, connected with a 16pin data cable. I need someone to 1. confirm that the stereos for these vehicles do indeed use 16 pin cables between the two units. 2. confirm that these units are matsushi ta/panasonic manufactured 3. hopefully provide a unit for testing temporarily Original Post (connector on rear of MY02 stock in-dash 6-cd...) ---------------- THis is the connector in the lower left corner of the unit (looking at the back). It looks like two horizontal rows of 8 pins. anyone know what this is for? I vaguely recall someone mentioning that it was used to attach an additional cd changer to the unit. I know people used the din plug in the MY05 forester as an auxiliary input... does anyone have the pinout for this connector so we can see if something similar is possible? [imgx]http://home.ptd.net/~richmana/wrx/stereo/allback.jpg[/img] [imgx]http://home.ptd.net/~richmana/wrx/stereo/plugbac k.jpg[/img] Fixed pictures: just so we're clear, this is the deck/connector we're talking about ![]() ![]() Last edited by tad_02Wgn; 10-24-2005 at 11:49 AM. |
#2 |
Member#: 2132
Vehicle:11 STi Sdn Sparkling Slvr Met |
![]() Bump, I'd like to know as well as I got an MP3 player for xmas and want to hook it up via an aux jack. I don't want to buy another headunit.
#3 |
Member#: 66426
![]() Well... here's the status update. The 16 pin connector on the back of the stock matsu****a 6-cd in dash changer is indeed a connector for an additional cd changer. The input pins are all there, however the unit must somehow be tricked into thinking that a cd changer is attached to switch over to these inputs.
"MidlifeCrisis", the main contributor to this thread: http://www.imprezawrxsti.com/postnuk...wtopic&t=11218 suspects that the inputs are run through an audio IC where an internal switched gate controls which audio signal gets passed through. He suspects, and I agree, that if we can somehow emulate the control signal (maybe with a simple PIC), then we should be able to get the unit switch over to the external input. If anyone else has any information about the bus protocol, please post here. I put in a request through a friend at Panasonic (subsidiary of matsu****a) to try and dig up the bus protocol... so we'll see if that pans out. In the meantime, here is the information that "MidlifeCrisis" originally posted from the service manual: ![]() ![]() ![]() ![]() ![]() |
#4 |
Member#: 66426
![]() still working on this.
Got the full service manual/schematic. It's definitely going to be tricky. The BUS.LINE breaks down to CD-CH.IN and CD-CH.OUT, which refers to the serial I/O lines going into the CPU in the main block. The CPU then sends data along a control line to the Electronic Volume Control, which switches between either the internal source line (AM/FM, tape, cd) and the external source line (the one we want to be able to use). The output from that IC then heads over to the power amp stage... and the rest is music :-P I've dug up an old thread on nasioc where somebody mentioned that they were able to get an external cd changer that was meant for a legacy (not sure of the year) to work with the wrx deck (although apparently the internal unit was disabled while connected). If i can get my hands on this or a similar changer, I may be able to capture the contents of the data line and then emulate it to make an aux input available. THe other (better) option would be to find the actual spec for the CPU control line. The only info I have on the CPU is: Part No: C2BBGF000085 If we could figure out what data it is expecting, we could again emulate this data and switch over to the external input. |
#5 |
Member#: 84701
TXIC
Vehicle:2010 Yaris 5dr Hatch Black Sand Pearl |
![]() tad_02Wgn-
Wondering if you can magically get your hands on the MY05 WRX stock-in-dash 6-disc changer? Here's the info: Matsu****a Electric Industrial Co., Ltd. (made in Japan) Model No. 86201FE210 Ref. No. CQ-EF6360A Would be much appreciated, sedeuce |
#6 | |
Member#: 66426
![]() Quote:
Someone needs to find the damn communication protocol spec, and we'd be SO golden. |
#7 | |
Member#: 18453
Vehicle:MY02 WRX Sport Wagon |
![]() Quote:
speaker |
#8 | |||
Member#: 66426
![]() Quote:
#9 | |
Member#: 18453
![]() Quote:
speaker |
#10 | |
Member#: 66426
![]() Quote:
WRX-6disc-servicemanual.pdf (17.3mb) This link will only work until the end of June, so if someone else could re-host, that'd be great. |
#11 |
Member#: 10309
Vehicle:'02 OBS 2-tone! White |
![]() Have you considered emailing Matsu****a with the question?
#12 | |
Member#: 66426
![]() Quote:
We're looking for the protocol for the BUS.LINE (pin H on the CN702 connector). It is probably a serial protocol that allows the cd changer to talk to the head unit - let it know it's connected, send/receive commands, etc. In addition, if someone has/can get an external changer that is compatible with the stock deck, we could get the protocol from that. I don't know where to get one, otherwise I would. |
#13 |
Member#: 10309
![]() I don't know if this one has the right connector, but it at least shows a photo of the connector, and there are lots of similar auctions on eBay: http://cgi.ebay.com/ws/eBayISAPI.dll...766878043&rd=1
Good luck in your hunt! |
#14 |
Member#: 66426
![]() bump for update..
i need your help |
#15 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
![]() I am surprised, you seem to be getting quite far into this.
The connector and pins were discussed before. The only additional info is that by searching I had found a link to a relatively recent tread of a fellow Swedish (I think) Subaru owner that proceeded to actually make a circuit board for an input adapter and then got the factory head unit to recognize that as an external unit. Not as an alternate cd changer, no toggling between sources, but once his board plugged in, whatever was plugged into it would play as audio source, under CD. At the same time some nonsense message was displayed on the display such as "u 121" instead of CD and Track. This is all recolection that I have, not cold facts (I may have some details wrong, feel free to correct), but I had such interest that I saved the link to tread on a floppy. My curent solution involves a digisette. Digisette has on-board power and a MMC card slot. The biggest currently available MMC card is 2Gb, with a 1Gb being affordable already. I estimate that a non-music oriented person needs only 10 Gb to have all the music one ever wants to listen to. The Forrester Head unit has a round changer connector and they have been able to make an external source play through that connector by having a blank recorded CD play in one of the slots. Also, note that UK sites list both CD changers for WRX 01 and up and CD changers code converters. The price is not that bad. They had different units that we never got though. Vlad |
#16 |
Member#: 87974
![]() I've been following the various threads in the various forums concerning directly connecting an IPod to the Panasonic-manufactured Subaru stock head-unit that has the square 16-pin connector.
To that end I have purchased a spare single CD stock head-unit and a used add-on 6 CD changer that will connect to and work with that head unit. My plan is to try to capture the signals between the units as described in this thread, and to build a small custom device that will allow an IPod to appear to the head-unit as a CD changer. Two family members who are electrical engineers are coming to visit this weekend so I may be able to actually make some progress on this. I will post follow-ups here. |
#17 |
Member#: 66563
Vehicle:2002 Impreza WRX WR Blue Pearl |
![]() Well belkin is coming out with a tape adaptor that lets you control your ipod using the hu controls. These are some related links i found. First one is a guy who figured out the volvo protocol and made an adapter. 2nd link is a panisonic cd changer protocol which might help. and the last is another nasioc thread about this subject.
http://forums.swedespeed.com/zerothr...print&id=32512 http://www.lafrog.com/cdcemu/ http://forums.nasioc.com/forums/show...1&page=3&pp=25 |
#18 | ||
Member#: 66426
![]() Quote:
#19 |
Member#: 52324
Vehicle:2011 WRX LTD (FS) 1990 T30 miata |
![]() tad: I have this:
![]() I'm not sure if its the exact model or not, but i could take a photo of it for you if you want. Also, I think i'm buying a radio this week (aftermarket) so maybe you'd be interested in it? when you say "stock deck" you mean stock WRX radio? I have the radio thats in the legacy + outback (tape + single CD) along with the external 6CD changer. I'd assume the pinout would be the same.... |
#20 | |
Member#: 66426
![]() Quote:
Does the back of your changer (the 6 disc) connect to your single disc using the rectangular plug (16 pin, two rows of 8)? In addition, do you know if your units are made by matsu****a/panasonic? If it's the same connector... and your changer is a panasonic make, I would be very interested in getting my hands on it for a while to see if I could reverse engineer the protocol. |
#21 |
Member#: 52324
![]() tad:
I'll let you know when i take it out. I'm picking up a single din MP3/ Sat radio HU from a fellow member within the next few days. when it comes out, I'll post some pics. |
#22 |
Member#: 52324
![]() pic bump
unit we're talking about, right? ![]() plug: ![]() ![]() connection to radio: ![]() ![]() |
#23 |
Member#: 66426
![]() that definitely looks VERY hopeful.
That SHOULD plug right into the back of the 6-disc indash unit. I read somewhere that someone got it to work. If it does, I should be able to capture the commands sent and *hopefully* emulate it with a stand-alone controller. Any chance you'd be willing to let me borrow it for a while? Drop me an email, richmank AT ptd.net and we can discuss. Thanks! -Tad |
#24 |
Member#: 52324
![]() you have been emailed.
#25 |
Member#: 92848
Vehicle:2003 Forester silver |
![]() I'm interested in this mod, too. I've wired up the audio inputs, like some others have, and the head unit doesn't recognize the input.
CD in-dash 6 CD Changer with cassette player | cspangler6 | Interior/Dressup/Audio & Security | 2 | 06-29-2007 05:22 PM |
Stock in-dash 6-disc CD from WRX | MBasile | Private 'For Sale' Classifieds | 1 | 06-21-2005 09:56 AM |
Mint 2004 Stock In-dash 6-cd Head Unit | magisimo | Private 'For Sale' Classifieds | 4 | 10-18-2004 03:56 PM |
FS: Stock in-dash 6 disk cd player. | WRB04STI | Private 'For Sale' Classifieds | 1 | 09-22-2004 03:21 PM |
Subaru In-Dash 6-CD Changer/Stock Speakers | magisimo | Private 'For Sale' Classifieds | 3 | 09-18-2004 04:28 PM |
