Welcome to the North American Subaru Impreza Owners Club Thursday March 30, 2023
Old 01-06-2007, 05:30 PM   #26
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by SilvrWRX View Post
SVXdc requested some detailed pics of the connectors for the interconnecting wire. There are 5 contacts, but I'm not sure what they are all for. Ground, left, and right? That would leave 2 for something else. I don't believe any of these wires are for lights as the "AUX" label in front doesn't light up.
Thanks for posting the additional close-ups!
Three of the pins have to be ground/left/right.
As for the extra two wires, I wonder if they're just looped together at the ashtray box, to tell the radio to enable AUX mode (otherwise the CD/AUX button will only switch to CD)? Or might be +12V and ground to power an iPod (not supported on the box you have).
Could you perhaps use a meter to check the pinout all the way out to the audio jack? Then see if either of my guesses are right about the leftover pins.
ADDED: Source for OEM interconnect harness found!
dajohnson53 found that the harness is sold as a replacement part from Clarion (the HU manufacturer).
Details in his post here (#323 in that thread). Also see my reply after that.
SVXdc is offline   Reply With Quote
Old 01-06-2007, 05:43 PM   #27
goixiz
Member#: 99128
2005 SAAB 92x
too bad there is no XM that conects to the CeNet plug
goixiz is offline   Reply With Quote
Old 01-07-2007, 02:41 AM   #28
SilvrWRX
Member#: 8582
2007 Impreza WRX
Satin White Pearl
I think I remember pressing the CD/AUX button while nothing was hooked into the Aux port, and I think it just stayed in CD mode. So I think your guess on the loop continuity check is right. Perhaps someone who still has their 07 stock stereo installed can check. Otherwise I can look for my multimeter to check. Now, if I can remember where I last left it...
SilvrWRX is offline   Reply With Quote
Old 01-10-2007, 05:35 PM   #29
SilvrWRX
Member#: 8582
2007 Impreza WRX
Satin White Pearl
Default aux port connector
I found my meter, and I checked the pins in the connector to the ashtray aux port. Without anything plugged into the front, the circled pins aren't connected. Once something is plugged in, then the circuit was completed. So, it must be a signal to the radio that something is plugged in the aux port as you had guessed.
Hope this helps!
Old 01-23-2007, 10:43 PM   #30
mvorchard
Member#: 42540
2007 Forester XT
Metallic Grey
Question Looking for wire harness
Hey Guys,
Would any of you please tell me which is the wire harness I need to get for the new OEM cd changer???? I'm about to install my head unit, and do not want to rip the original wires off
Thanks and regards,
MO
mvorchard is offline   Reply With Quote
Old 01-24-2007, 12:49 AM   #31
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Are you saying that you want to replace the OEM radio in your '07 Forester with an after-market radio?
The rear of this new OEM HU looks like this (click to see larger image)...
The radio harness in the car still looks like this...
(same as it's been for years, with the exact same pin-out).
To install an after-market HU, you'll want the matching 14-pin wiring adapter (or "forward" harness). It's the standard one for 1995-up Subarus.
Old 01-24-2007, 08:02 AM   #32
mvorchard
Member#: 42540
2007 Forester XT
Metallic Grey
Thanks, SVXdc. You already got my order and payment........ hoping that you can send the harness as soon as possible.....
Cheers,
MO
Old 01-24-2007, 08:29 AM   #33
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
For what its worth, the aux box does not fit properly in the tray of an 2005 wagon dash. It fits, and fits perfectly, but does not have the extra plastic on the top of the ashtray section which the aux unit plugs into. I havent figured a good way yet to make it "stay put" without glue or the like.
atech_rallyrs is offline   Reply With Quote
Old 01-25-2007, 12:06 PM   #34
SilvrWRX
Member#: 8582
2007 Impreza WRX
Satin White Pearl
The way the aux box locks into the slot is by a metal clip. I think it looks like the clip on a garage door opener. I had to slide it out in order to pull out the aux box. I'm guessing your model has a little hole at the top of the ashtray slot with some sort of locking clip to prevent the ashtray from simply sliding all the way out? You probably need something similar to this.
Old 01-26-2007, 12:23 AM   #35
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
do u guys know the aux part #
teamslow wrx is offline   Reply With Quote
Old 02-07-2007, 02:24 PM   #36
errosfitz
Member#: 94535
2006 WRX Wagon
Steel Grey
Hi all,
Any ideas on where to get a used 07 HU w/ Aux from someone getting an aftermarket - very few are showing up in the wanted forums, ebay etc.
found one!
errosfitz is offline   Reply With Quote
Old 02-07-2007, 04:11 PM   #37
wtscooby
Member#: 139690
Default Aux Input part # for 2007 CD Changer
The Part# for the aux input that goes in the ashtray is 86257SA010. However, I can't find the part number of the Cable that goes from the aux input to the back of the HU. Can anyone help with that?
wtscooby is offline   Reply With Quote
Old 02-09-2007, 08:09 PM   #38
johnso156
Member#: 107663
2006 Limited WRX
Wow, so the 07 headunits don't have rear outputs for the OEM subwoofer?
johnso156 is offline   Reply With Quote
Old 02-09-2007, 08:51 PM   #39
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Right. The subwoofer in a 2007 will use the "old style" T-harness, like on 2004 and earlier -- where it T's off of the radio's main 14-pin speaker/power connector.
Old 02-13-2007, 03:33 PM   #40
mvorchard
Member#: 42540
2007 Forester XT
Metallic Grey
It'll be great making a rca adapter for this cable.................
Old 02-14-2007, 02:34 AM   #41
wtscooby
Member#: 139690
Default Aux Input 2007 CD Changer
I think I have figured out how to make a cable that would plug in to the aux in on a 2007 CD Changer and have stereo RCAs. I just need to find the connecter. Apparently it is a i85 connecter. I could use more info on who makes these connecters and where I can get them. Any help would be appreciated.
Old 03-26-2007, 10:21 AM   #42
frito
Member#: 136183
I am attempting to install an 07 HU with the AUX in my 04 forester. I have the radio but need the harness from the AUX. Has anyone come up with a solution other than the factory harness or does anyone have a spare harness after an aftermarket HD install?
Also, my forester has the sub in the cargo area and the 04 HD had the sub output. I read about a t-harness. I think 07 foresters have the same sub so they must use this t-harness. Any leads (no pun intended)?
frito is offline   Reply With Quote
Old 03-27-2007, 02:10 AM   #43
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by frito View Post
I am attempting to install an 07 HU with the AUX in my 04 forester. I have the radio but need the harness from the AUX. Has anyone come up with a solution other than the factory harness ... ?
The horizontal spacing between pins appears to be 0.1" which is common in computer stuff. Unfortunately the spacing between rows appears to be 0.125". But you could get two 2-pin female connectors to access the 4 pins you need. See link below for the pin-out. The Aux enable pin should be connected to the outside case of the radio (not to aux signal ground)
Also, my [2004] forester has the sub in the cargo area and the 04 [HU] had the sub output. I read about a t-harness. I think 07 foresters have the same sub so they must use this t-harness. Any leads?
Your '04 sub is a plain, unpowered speaker. Your factory head unit has a 5th channel output for the sub.
The 2007 OEM HUs do not have a sub output. [CORRECTION: Some (but not all) 2007 models do. Sorry.]
If 2007 Foresters still have a plain speaker in the rear (not a powered unit that sits underneath either the driver's or front passenger's seat), then the car must have an amp somewhere. [CORRECTION: I was wrong. Some 2007 Forester HUs still have a 5th channel powered subwoofer output]
The T-harnesses that we've been talking about in earlier posts above are only used with the powered underseat subs.
See this thread for more info and pics that may help:
Stock head unit information -- pin-outs, subwoofer, aux inputs, and more
In any case, you would need a single-channel sub amp to drive your sub. The input to the amp would come from one or more of the speaker outputs. Ideally you'd want to find an amp that takes 2 speaker level inputs, does a low-pass filter, sums them, and provides a single subwoofer output.
Old 03-27-2007, 09:45 AM   #44
frito
Member#: 136183
Always something. Thanks a lot.
*THe forester owner I bought this from says that the 07 sub was run directly off the HU. He had his interior more or less gutted as part of an install and no amps were found.
Old 04-25-2007, 11:03 AM   #45
Wilson_
Member#: 122118
2006 OBS
Steel Grey
sorry for the old bump but i have a question
i have a 06 obs with the 6-disc in dash with a factory sub
is the 07 head unit with aux input a bolt/plug in? will every thing look like its factory? any modifying??
TIA
Wilson_ is offline   Reply With Quote
Old 04-26-2007, 01:21 PM   #46
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
I just installed an OEM 2007 MP3 player...works great!
My only question is how the heck to install the AUX ashtray input! I removed the ash tray, and tried to jam the whole thing in there...but it didnt fit! Is it supposed to fit in the stock ash-tray hole? Or do I have to buy a 2007 ash tray area part?
GooseMan is offline   Reply With Quote
Old 04-26-2007, 02:52 PM   #47
Wilson_
Member#: 122118
2006 OBS
Steel Grey
is the head unit plug and play? does it bolt right in??
Thanks
Old 04-26-2007, 02:59 PM   #48
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
Yup! Took like 20 mins.....coulda been faster, but I had trouble taking the ground clip off the bracket. Then I realized I could just take the bracket off the old HU and keep the ground clip on
Old 04-26-2007, 07:24 PM   #49
Wilson_
Member#: 122118
2006 OBS
Steel Grey
cool man thanks, do you have any tips other than the ground?
mabe a step by step?
Old 04-27-2007, 11:28 AM   #50
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
WTB: 2007 WRX OEM cd-changer pj_cab NWIC Private Classifieds 1 03-14-2013 08:14 PM
FS: OEM CD Changer from 04 WRX Leprakkon Interior/Dressup/Audio & Security 0 09-02-2009 01:09 PM
WTB 2007 OEM CD Changer jaWn Private 'Wanted' Classifieds 0 11-25-2007 05:02 PM
FS: 6 Disc CD/MP3 Changer from 2007 Impreza 2.5i, with AUX Input Jack tarp Interior/Dressup/Audio & Security 3 08-27-2007 03:58 PM
FS: OEM 6 CD changer from 04 Forester XT SzGuy Private 'For Sale' Classifieds 0 10-23-2005 10:05 PM
