#1 |
Member#: 12855
Vehicle:2002 2.5TS Blue Ridge Pearl |
![]() I ordered a sub/amp from exeter and it's
on it's way. I have been wondering if installing it with an aftermarket system is at all difficult. I have been reading older posts, and have a .pdf file of the instructions. Do you think an install shop will be able to install this w/o any major hassle? My local sube dealer will only do the totally factory install. I have a Nakamichi 45w x4 hu and it's my understanding that the sub will run off the rear speakers.... Will a reputable shop be able to do this? I have spoken to 2 shops and they claim they can do the install, fwiw
#2 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
![]() Shouldn't be a problem. IIRC, the factory sub just has a harness that hooks into the factory harness for power and signal.
#3 |
Member#: 12855
![]() will the factory harness still be there if the
factory head unit is not? sorry if this is a dumb question.... |
#4 |
Member#: 11662
Vehicle:2002 Subaru 2.5RS Silver |
![]() Unless you cut the factory connector off to hook up a 3rd party head unit. This would be a dumb thing to do as a connector with pig tails is $10-$15 from Circuit City or Best Buy.
I have the factory sub on a Kenwood Z828. No problem. |
#5 |
Member#: 620
![]() On the GC8 there is a wire harness that plugged in between the radio plug and the radio. It pulls its signal as well as power/turn-on/ground (not totally positive on these 3) from the radio harness then runs under the drivers seat. I believe you will need this harness to run the amp/sub. If you have the instruction sheet as well as the wire harness for it you should be able to easily install it yourself. It shouldn't take more than an hour or so.
-Doug |
help with oem sub fir aftermarket hu | SUBOO5 | Car Audio, Video & Security | 6 | 10-25-2006 01:09 PM |
Factory sub with aftermarket HU | lovemyrex | Car Audio, Video & Security | 12 | 02-12-2006 11:04 PM |
Factory Sub with Aftermarket setup help | i_drank_what | Car Audio, Video & Security | 4 | 01-02-2006 02:21 PM |
Wiring factory sub to aftermarket HU | wiz561 | Car Audio, Video & Security | 0 | 10-16-2005 08:36 PM |
Factory Sub to Blaupunkt HU ? | lobelsteve | Car Audio, Video & Security | 1 | 10-13-2003 06:31 AM |
