#1 |
Member#: 11015
Vehicle:'06 Volvo V70R Sonic Blue |
![]() I am hard wiring a V1. Does anyone know the Subaru color scheme for wiring, specifically '02s. I need to tap a ignition controled hot wire.
The install is going really well, I'll post picts later. Thanks Chris
#2 |
Member#: 4422
TXIC
Vehicle:00 RS Yellow |
![]() dont have the wiring info but good luck
#3 |
Member#: 5424
South East
Vehicle:BRP STi Version 3 Type RA V-Ltd RHD |
![]() Hmmmmm... Ignition controlled hot wire... like, say, the cigarette lighter? I tapped into mine for just that (since I don't use it much anyway). Simple to do, especially once you take apart the dash as if you were removing your stereo. Like a five minute job. Two screws and everything else just pops off. Check out the tech section on my web site for detailed instructions...
#4 |
Member#: 11015
![]() thanks I'll check it out. I will be using a converter to run a laptop DVD for the trip. Do you think that would be an issue?
#5 |
Member#: 5424
South East
![]() Usually the cig. lighter circuit is about 20 amps. Cig. Lighters draw alot of current to get hot. As long as the Valentine 1 and the laptop don't draw more than 20 amps, you should be fine. I wouldn't think they would draw anywhere near 20 amps. Worst thing that could happen is you blow a fuse, then you know not to run both together, but I think it should be fine.
(I think 20A should be sufficient to run a 27" tv and a VCR BTW) |
2001 2.5RS speaker wire color codes | Fred | Car Audio, Video & Security | 3 | 10-09-2010 06:55 PM |
Factory speaker wire color codes | alfabc | Car Audio, Video & Security | 7 | 03-19-2006 04:20 PM |
XT speaker wiring color code. | TURBO_EEXTEE | Car Audio, Video & Security | 2 | 04-15-2004 07:08 AM |
STi Owners: Anyone know interior clock harness wire color codes? | artdoesart | Electrical & Lighting | 4 | 04-13-2004 04:49 AM |
2000 Impreza RS Instrument Cluster Wire Color Code | Sunrise City Rider | Subaru Conversions | 0 | 04-21-2003 08:11 PM |
