Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 09-19-2012, 08:38 AM   #251
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by goregasm View Post
Nope. Nobody said "Make sure you unclip the shielding from the holders"
I'll try tonight.
That should do it.
Here's another tip:
When you're getting ready to put the center console back together again, before you snap all of the clips in place, make sure that you can see those mechanical cables on the driver's and passenger's side. I almost couldn't find the cable on the passenger's side after I had snapped the center console back in place, and came very close to having to remove it again. I was barely able to find it by poking and reaching blindly with my fingers, but it was a close call.
Also, don't forget to protect your dash with painter's tape, as I showed in my previous pictures.
sgoldste01 is offline   Reply With Quote
Old 09-21-2012, 07:32 PM   #252
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Originally Posted by sgoldste01 View Post
That should do it.
Here's another tip:
Son of a BITCH that sucked. But everything appears to be working. I soldered the parking brake switch into the ground wire of the harness. I also only have two screws holding it in, but that's because kenwood doesn't know how to frickin place screw holes. And it felt sturdy to me.
Did happen to forget the microphone, but I don't use bluetooth for calls and wouldn't in a car this noisy.
goregasm is offline   Reply With Quote
Old 09-21-2012, 08:34 PM   #253
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Congrats. I'm sorry it was an unpleasant job for you. Mine took a long time because I was going slow, but I was generally enjoying myself and was pleased with the result.
Anyway, you probably saved $200 doing it yourself!
Old 09-21-2012, 10:43 PM   #254
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
It literally left me scarred and otherwise wounded. I ripped half an inch of skin off of my fingernail, and got several pokes under the fingernail, and otherwise bruised several times.
Old 09-21-2012, 10:49 PM   #255
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i'm not looking forward to taking my dash apart again to install my new amp, but i think the result will be worth it. just need to find time to do it and somewhere to stash an amp that is 7.5x2.5x1.5" (alpine KTP 445U)
Old 09-22-2012, 06:26 AM   #256
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
How heavy is the amp? If it's light (and doesn't generate huge amounts of heat), you can do what I did with my Pioneer XM receiver and zip tie it up as high as possible in the front passenger's side foot area (under the glove compartment, and to the left of the blower fan motor). I can only see it if I have the passenger's seat fully reclined, and even then, I can barely see it. And it's easy to get cabling from the HU to this area.
For reference, my XM receiver's dimensions are 5.5 x 7 x 1.1 inches--a larger footprint than your amp's.
Old 09-22-2012, 09:04 AM   #257
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It's pretty light, heavier than a tuner but not by much. I will do some looking
Old 09-22-2012, 09:04 AM   #258
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Also, gold, I did the whole install without removing my glove box. I don't know why people said they had to remove it. In fact, it was easier than the driver's side where there was hydraulic fluid in a pipe at about 400º right next to the linkage.
Old 09-22-2012, 11:15 AM   #259
Justhermz
Member#: 70352
2001 2.5 RS
Sorry don't know where else to ask this, I have the crap 2012 Stereo and am looking to pull the trigger on a setup for it, but half the bestbuy employee's don't know what they're talking about and I don't know enough to differentiate them from the good employee's .
You can get the install nearly free right now if you pair them correctly. You can get $100 of Faceplate with Speaker & install, and $100 of Sub and amp with install.
Sub 8" Polk DXI108 - $150
Amp 600W A/B 4 Channel PA660 - $200
Alpine Speaker SPE-6000 - $60
The concerns I have with this setup are a) Can the 4 channel amp power just the front speakers & the amp? b) Do I need two pre-amp outputs or one? Any help would be greatly appreciated, thank you.
Justhermz is offline   Reply With Quote
Old 09-22-2012, 11:15 AM   #260
Justhermz
Member#: 70352
2001 2.5 RS
Old 09-23-2012, 06:05 AM   #261
bobclavi
Member#: 333042
Default automatic windows
did your automatic windows stop working after you changed you head unit?
bobclavi is offline   Reply With Quote
Old 09-23-2012, 07:58 AM   #262
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes. I need to look up in the owner's manual how to reset it. I guess this happens whenever the battery is disconnected.
I also noticed that starting the car for the first time after reconnecting the battery is difficult. I assume this is normal too.
Old 09-23-2012, 08:16 AM   #263
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
If you're thinking about adding satellite radio to a Pioneer head unit, you should read this thread first:
http://forums.nasioc.com/forums/show....php?t=2411096
Old 09-23-2012, 08:21 AM   #264
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
You need to roll it half down then up, then all the way down and up. That should make it work again
Old 09-23-2012, 08:30 AM   #265
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
My automatic windows worked half-assed after I disconnected the battery the first time. Sometimes they work, sometimes they don't. I didn't notice any difference starting it. LMK if you find anything about it, I like my automatic windows...
Edit: the post above me is sorta right. Just play around with them like a little kid for a minute or two and they work fine.
Old 09-23-2012, 08:12 PM   #266
bobclavi
Member#: 333042
holy cow that worked thanks man
Old 09-23-2012, 08:59 PM   #267
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Wow!
Alpine KTP 445u = perfect upgrade for factory radio amplifier. Only problem is now i will need new speakers too because the stock ones distort easily now, couldn't really get then to distort with the factory radio. I used to run +6 to +8 bass and treble. Now maybe +2 bass and neutral mid/treble. A lot of the boominess is gone too with a similar sound to my ear and ear splitting volumes.
Volume level 6 now is equivalent to 20 before and 25 is pretty much too loud.
Great purchase for 125 ( 170 with the harness from svdx)
Old 09-24-2012, 05:54 PM   #268
TopGearUK
Member#: 332410
Hello everyone. I looked into getting the CDN bezel that comes with the Pioneer unit. The bezel comes together with the Pioneer Nav, can't buy it separately. Hopefully there will be a JDM solution .
TopGearUK is offline   Reply With Quote
Old 09-24-2012, 06:06 PM   #269
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Wow!
yeah, i messed with mine just to see how they sounded at full range w/o the crossover turned on and they sucked.
i'm still running my OEM speakers w/ the amp crossed over @ 200Hz. they sound pretty good. *still debating if i'm even gonna replace them.
ChesterWRX is offline   Reply With Quote
Old 09-24-2012, 08:46 PM   #270
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
But you are running a sub? I have no plans to put a sub in this car because i need all the space i can get. So sometime in the future i will be buying new speakers.
But i am quite happy with the sound/volume levels i can achieve now. It is certainly loud enough to cause hearing damage and give me a headache if i listen to long
Old 09-24-2012, 09:25 PM   #271
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Yeah, i have a 12" sub mounted in a custom enclosure where my spare donut goes.
The sub, enclosure and related beauty panels raised the floor by about 3" to accommodate the mounting depth. Kind of a win win outside of NOT having the donut, but i can remove all the stuff at will if i wanted to and put the donut and OEM fiber board panel back in.
Old 09-24-2012, 10:21 PM   #272
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
This is where my amp ended up.
Old 09-25-2012, 12:45 PM   #273
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
nice.
its kinda hard to tell, is that where the xm/sirrus receiver would go?
how did you wire it? break-out harness?
Old 09-25-2012, 01:22 PM   #274
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Originally Posted by ChesterWRX View Post
nice.
He should have been able to wire the power/ground/illum connections from the 07+ Niaasn harness into the HU, then the connection from the HU to the PowerPak, then the speaker outs from the external amp in to the speaker connections/inputs on the Nissan harness.
phenryiv1 is offline   Reply With Quote
Old 09-25-2012, 01:33 PM   #275
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
nice.
i used the combination harness from ae64 (svdx)
and this is where my satellite receiver is (my car didn't have the option for satellite so i got creative with a forester HU.
2012 STI Stereo Build with OEM NAV H/U Lateralis Car Audio, Video & Security 143 05-10-2022 11:57 AM
2012 Impreza Sport stock stereo good? 2012subisport Car Audio, Video & Security 29 06-28-2015 06:18 PM
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 22 01-11-2015 01:28 PM
2005 subaru impreza stereo vs. STI stereo breakdirt916 Car Audio, Video & Security 3 12-05-2011 08:02 PM
2012 Impreza Stereo Upgrade Sidewindor Car Audio, Video & Security 5 11-14-2011 05:25 PM
