Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Old 10-20-2002, 04:59 PM   #1
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Thumbs up STI headlights level switch install
ok i got this mod working .. it took some time and a lot of thinking lol
remember doing this will be at your own risk..
All the electronics you need to make the lights go "up/ and down" are inside the lights. no need for such thing as a "Black box".
you will need the level switch also.
tools: 10mm
wire cutters
radio shack 6 wire connector, male and female
6 diferent color wires , red,black,blue,green,orange,brown
soldering gun.
wire loom
step 1: have the sti head light on hand, cut the plug from the level motor , install the 6 pin connector "male".
do this on both lights
step 2: get enough wire to go from the right side head light to the left, on the right headlight connect the " 6 pin connector" to the end of the wires .., on the other side "driver side headlight,
get enough wire to go across the firewall, put the ends together
on the same oder on the same 6"pin connectors"
gabewrx is offline   Reply With Quote
Old 10-20-2002, 05:18 PM   #2
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Default part 2
after having all the wires on the engine bay and having the head lights back in place . go under the dash take the kick panel out.
with the wires under the dash look for a good ignition power sourse"12V"
and a ground.
time to do some soldering. take the switch. open it " Be carefull with the little spring inside the switch"
you are gonna find 4 positions tabs on the board inside the switch, and a main one on the center
solder the wires on each one of the position tabs follow the pic
try to make a little hole on the side of the level switch to pass the wires.
Old 10-20-2002, 05:24 PM   #3
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
pic1
Old 10-20-2002, 05:29 PM   #4
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
cut the side and have the 4 wires about 4-6 in. inches long.
Old 10-20-2002, 05:42 PM   #5
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Default part 3
connect the 4 wires from the switch to the wires from the headlights..
now from the same power wire that you use for the headlight ignition 12V run another wire to the switch and plug it in the 3rdpin.
2nd and 1st pin are dashboard lights. 2nd is the dashboard light power and the 1st is ground .
Old 10-20-2002, 05:49 PM   #6
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Default part 4
ok after connecting the switch and giving the switch power try going through the levels 0 to 4 and see if the lights move
have the car running, and the lights on!
well i hope you have fun. with this mod i love it!
please ask me if you need some help!
gabe.
Old 10-20-2002, 06:07 PM   #7
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Default pic
my car!
Old 10-20-2002, 06:18 PM   #8
vividracing
Member#: 6270
Only At
www.vividracing.com
Did you put this on the non HID or the HID lights? Very informative. Can I put the information on our site?
vividracing is offline   Reply With Quote
Old 10-20-2002, 06:47 PM   #9
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
lhd non hid headlights.
i think they are the same H.I.D or not
and what do i get for giving you this info??
i hope some cool stuff
i know what i need .. need help with the link ecu , i need stock base maps!
wanna trade???
Old 10-20-2002, 06:59 PM   #10
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
hey one question the kaminari front spoiler comes with the flat wing part on the bottom? when you buy the front spoiler?
Old 10-20-2002, 08:07 PM   #11
ChuckCheeze
Member#: 8143
2014 sti
WR Blue
i am glad my pics of the switch helped someone!
ChuckCheeze is offline   Reply With Quote
Old 10-20-2002, 09:52 PM   #12
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
yeah hehe if it wasn`t for those pics.... man.. i wouldn`t have done this!
Old 10-21-2002, 03:32 PM   #13
grandmasterchan
Member#: 3092
2002 WRX rally blue
www.zucru.ca
Wonderful information. Thank you!
grandmasterchan is offline   Reply With Quote
Old 10-21-2002, 08:08 PM   #14
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
This write-up just made my day!!! and month!!! I bought that level switch a while back, but never had the energy to do it. I have the morettes, which also have a level control. I'm gonna look at the wiring tonight on the headlights, and see if this is possible...
thanks alot for a GREAT write up...
WRXGuyInUSA is offline   Reply With Quote
Old 10-22-2002, 02:25 AM   #15
cobrabyteWRX
Member#: 24818
World Rally Blue
bump ... thanks for posting this mod.
Chris
cobrabyteWRX is offline   Reply With Quote
Old 10-22-2002, 03:38 AM   #16
WRX-ellent
Member#: 9071
2002 WRB Impreza WRX
FMIC/1820 inside & Link'd
Dude...this is GREAT!!! I'm gonna try this tomorrow morning. Thanks for posting
~joe
WRX-ellent is offline   Reply With Quote
Old 10-22-2002, 09:57 AM   #17
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
hey is there any way to put this mod on the scoobymods?
Old 10-22-2002, 12:13 PM   #18
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
Just PM Kastle
Thats how I got my stuff on there.
STR8OUT is offline   Reply With Quote
Old 10-23-2002, 03:21 PM   #19
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
So can anyone find the part number for the correct harness to plug into the motor on the light?
Mike
TheShadowWRX is offline   Reply With Quote
Old 10-23-2002, 06:47 PM   #20
128d
Member#: 7792
2002 Prodrive
widebody Cosworth 2.5 6sp
I might look retarded but I am going to ask anyway... Whet the hell does this "switch" do?
128d is offline   Reply With Quote
Old 10-23-2002, 06:50 PM   #21
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
It adjust the beam pattern on the STI headlights. STI headlights have motors mounted on them but our american cars are not prewired to accept them. This is the ghetto rig wiring of how to attach that switch to the motors.
You can aim your headlights low to high with this switch. It is the brain for the motors.
Old 10-23-2002, 06:58 PM   #22
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
This is awesome - what a terrific job!
I too would be interested in hearing about the possibility for morettes - although I have been waiting for my set since July....
...cursing the dock strike under my breath...
*grumble grumble*
CirrusWRX is offline   Reply With Quote
Old 10-23-2002, 09:30 PM   #23
daverup
Member#: 3708
2016 RS
I don't think this info is going to help us on the morrettes very much. As I understand this, the STi lights have a six pin plug for the aimer motor, and I know the morrettes have a 3 pin plug for the aimer motors. If I'm wrong, someone correct me.
daverup is offline   Reply With Quote
Old 10-24-2002, 11:13 AM   #24
NJWRX
Member#: 22163
2004 STi
Blue/Gold
Default Aftermarket HIDs
Would this work if you installed an aftermarket HID kit in the non-hid Sti lights, or would that somehow interrupt the movement of the lights?
Thanks for any help
-Nick
NJWRX is offline   Reply With Quote
Old 10-24-2002, 11:34 AM   #25
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
i don`t thing it will do anything.. you will be fine!
CA: STI Blank Key, STI Headlight Levelling Switch, 02 WRX Gauge Cluster my02wrx Interior/Dressup/Audio & Security 6 02-26-2009 02:09 AM
WTT: My 04-05 STI Headlight Level Switch For Your 06-07/JDM Switch MoclovFlop Interior/Dressup/Audio & Security 0 02-12-2009 11:52 PM
CA: STI Blank Key, STI Headlight Levelling Switch, 02 WRX Gauge Cluster my02wrx Interior/Dressup/Audio & Security 1 10-06-2008 04:48 PM
CA: STI Blank Key, STI Headlight Levelling Switch, 02 WRX Gauge Cluster my02wrx Interior/Dressup/Audio & Security 14 09-26-2008 10:37 AM
Headlight leveling switch install ? SLowery Interior & Exterior Modification 3 03-09-2003 01:40 PM
