08-17-2008, 04:06 PM | #1 |
Member#: 62182
NWIC
Vehicle:2005 STI White |
FS: WL WRX Sed Lat Links + EndLinks, Tein Flex for 05-07 STI
For Sale:
SOLD Whiteline Lateral links for 02+ WRX Sedan. These are the fully adjustable (camber and toe) ones. All 4 arms have turnbuckles, not just two. They have poly bushings. About 35k miles on them. They need to be thoroughly lubed as they're quite a bit. They don't fit an STI properly. I had to shift my swaybar to one side and run one endlink inboard and one outboard. Included with them are Whiteline heavy duty rear swaybar endlinks. Billet aluminum with yellow poly bushings. There are some rub marks from rubbing on the swaybar at one point (when I had new swaybars installed, the mechanic didn't shift it like it was before, so it rubbed on his test drive). Asking $300. SOLD Tein Flex for 05-07 STI with EDFC. These have somewhere between 20-30k miles on them (I lost count, because they came on and off a couple times). They're way, way out of warranty. One rear is leaking. Front pillowballs are floppy, and feel like there's a hint of play. I also cut the bumpstops, to get more bump travel. Make no mistake, these things definitely need a rebuild, which will cost $125 per corner, plus parts (dunno what to expect for that), and probably some pillow balls (don't know on that, either). If you're looking to do a stiff, custom-valved, track-only setup, this could be a good base. Asking $500 obo, including EDFC. -Mike
Tein Flex coilovers 05-07 sti | bello | NWIC Private Classifieds | 13 | 04-25-2010 04:02 PM |
Tein flex coilovers 05-07 STI | bello | Suspension/Brakes/Handling | 24 | 04-25-2010 03:06 PM |
FS: (WY) Tein Flex coilovers 05-07 STi | Dobbs | RMIC Private Classifieds | 7 | 11-21-2009 08:27 PM |
FS: TEIN Flex for 05-07 STI | DeLaSLO | SCIC Private Classifieds | 0 | 09-27-2008 04:41 PM |
OK: Tein FLEX for 05-07 STI & EDFC kit | benw | Suspension/Brakes/Handling | 14 | 03-01-2008 11:14 AM |
