12-13-2006, 09:01 AM | #1 |
Member#: 99128
Vehicle:2005 SAAB 92x Black |
OEM CD changer from 2007
Will the new 2007 cd changer work in a 2005 car
Prefer not to cut cables and rewire - I like the plug and play idea Thanks for any suggestions or idea
12-14-2006, 11:15 PM | #2 |
Member#: 69913
Vehicle:2011 STI Limited Dark Grey Metallic |
12-15-2006, 11:43 PM | #3 |
Member#: 130600
Vehicle:2004 WRX Silver |
Yup just swapped out my single CD in the 2007 to a 6 CD from a 2005 STI. No problem. Plug and play.
12-16-2006, 12:01 AM | #4 |
Member#: 70572
Vehicle:2018 Kona Pulse Red |
yes sir it will. I just put a 6 disc changer from an STI limited into my 05 wagon. Completely plug and play.
12-16-2006, 12:05 AM | #5 |
Member#: 99128
what color is the LED or background of the 2007 unit
Did you have tobuy the cable for the AUX in ? |
12-16-2006, 12:25 AM | #6 |
Member#: 70572
12-16-2006, 04:43 PM | #7 |
Member#: 99128
12-16-2006, 04:48 PM | #8 |
Member#: 88589
Vehicle:2005 STI the best one |
I'd be interested in knowing how to do this also.
12-18-2006, 12:49 PM | #9 |
Member#: 88589
Anyone?
12-18-2006, 01:03 PM | #10 |
Member#: 19259
Vehicle:2004 STI White/Silver |
I will be putting a 07 headunit with the accessory port on ebay in the next few days. I have no idea what it is worth. If interested shoot me a pm
12-18-2006, 03:45 PM | #11 | |
Member#: 110526
Vehicle:2007 STI Ltd 306 UGM 2008 STI Nav & BBS AW |
You can buy the cable needed at radio shack... they have a 3.5 to 3.5 cable that plugs into the ipod headphone jack and the other end plugs into the aux in that connects to the radio! Radio shack only has 6ft and 12ft cables though, but I found a 3ft cable at Best Buy. |
12-19-2006, 12:30 PM | #12 |
Member#: 88589
Does the 2007 unit play MP3s? Can that cable be made to work on a serial port on a PDA?
12-19-2006, 12:57 PM | #13 | |
Member#: 70572
Someone correct me if I am feeding BS. |
12-19-2006, 12:57 PM | #14 |
Member#: 70572
12-19-2006, 03:52 PM | #15 |
Member#: 110526
If that is what he is asking, then no, I don't think you can't connect the ipod directly to the back of the stock radio. I don't think there is anything to connect to, i.e. aux input! As someone else said though, yes the 07 radio plays MP3s.
12-19-2006, 06:17 PM | #16 |
Member#: 88589
What does the auxilary port look like? USB?
12-19-2006, 06:58 PM | #17 |
Member#: 20272
SCIC
Vehicle:2007 SWP STI |
I have an 07 STI and took my radio out while trying to connect the Sirius tuner to it. The aux port connects to a cable about 4 inches behind it--and it's not USB. Doesn't appear to connect to the radio. It probably connects through the main radio connector. If you can compare an 05 to an 07 connector, you'll probably see the differences. I assume there'll be a few more cables in it or something.
If I recall correctly, the stock unit has: 1. Radio connector 2. Antenna connector 3. Power connector 4. Sirius tuner connector That's it. Search here or iwsti.com for "ESN" or "SID" and you'll find wrxgrl's thread. I have a few pix uploaded. Here's the link to my site's pix: www.jsmithjr.com/subaru/radio John |
12-20-2006, 06:21 PM | #18 |
Member#: 99128
what if you want to use XM instead is there a CeNet unit for XM to connect to it ?
And which plug is for the Aux wire (is it the white connector) I bought a HU but seller did not include any wiring |
12-20-2006, 06:44 PM | #19 |
Member#: 20272
SCIC
Search for the thread I referenced above. It has pix along with information in it.
I don't know which one is the AUX. The aux ash tray unit has a mating plug behind it, but I don't know where that wire goes--maybe the small white one on the opposite end of the antenna plug? |
12-27-2006, 04:24 PM | #20 |
Member#: 61202
TXIC
Vehicle:2004 WRX Wagon WR Blue |
This is probably a stupid question, but I am assuming if this swap would work in an 05 there would be no issues in doing in an 04 wagon? It is just simple plug and play right? Would be so nice to burn MP3 disc and also work on getting the AUX input hooked up
01-05-2007, 05:18 PM | #21 | |
Member#: 8582
SCIC
Vehicle:2007 Impreza WRX Satin White Pearl |
Just took out my 2007 radio and aux port
The interconnecting wire connects from the radio rear port to the cable coming from the ashtray aux port. Here is a picture of the connectors from the ashtray aux port (left) to the interconnecting wire (right). Just an overview. |
01-05-2007, 06:24 PM | #22 |
Member#: 20272
SCIC
Right on the money. From right to left:
1. CNET cable for the Sirius tuner 2. AUX cable going to the ashtray port 3. Main radio cable 4. Antenna |
01-06-2007, 02:11 PM | #23 |
Member#: 8582
SCIC
connector details for interconnecting wire
SVXdc requested some detailed pics of the connectors for the interconnecting wire. There are 5 contacts, but I'm not sure what they are all for. Ground, left, and right? That would leave 2 for something else. I don't believe any of these wires are for lights as the "AUX" label in front doesn't light up. Use the 1 inch mark as the reference starting point. Sorry no metric.
This connects to the plug from the ashtray box. This connects to back of radio. Sorry they're a little blurry. Last edited by SilvrWRX; 01-06-2007 at 02:13 PM. Reason: grammar |
01-06-2007, 03:26 PM | #24 |
Member#: 99128
when you want to use the AUx port for input
does it automatically switched from cd to aux ? just wondering how it switches ? whats the CAT button for ? |
01-06-2007, 05:25 PM | #25 | ||
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
See this thread: SIRIUS ESN/ID Number (it gets interesting starting at about post #23) ADDED: That is the post by "wrx grl" that jsmithjr732 was referring to in post #17 above. . Last edited by SVXdc; 08-11-2007 at 10:23 PM. |
Similar Threads | ||||
WTB: 2007 WRX OEM cd-changer | pj_cab | NWIC Private Classifieds | 1 | 03-14-2013 08:14 PM |
FS: OEM CD Changer from 04 WRX | Leprakkon | Interior/Dressup/Audio & Security | 0 | 09-02-2009 01:09 PM |
WTB 2007 OEM CD Changer | jaWn | Private 'Wanted' Classifieds | 0 | 11-25-2007 05:02 PM |
FS: 6 Disc CD/MP3 Changer from 2007 Impreza 2.5i, with AUX Input Jack | tarp | Interior/Dressup/Audio & Security | 3 | 08-27-2007 03:58 PM |
FS: OEM 6 CD changer from 04 Forester XT | SzGuy | Private 'For Sale' Classifieds | 0 | 10-23-2005 10:05 PM |
