Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-13-2000, 07:20 PM   #1
mjos
Guest
Member#:
Thumbs up Installed the Bell RRFPR..what a diff!
Good news!
After installing the Bell fuel riser and bumping up the FP to 85-90psi under max boost, I am a happy camper. The car was hitting 1600 deg F without the Bell unit and with my SAFC maxed before a CE light limit and boost at 15psi.
Now, with the Bell in place(leaving my SAFC settings the same) I hit a max 1350 degF EGT. I can now turn down the safc and possibly up the timing with all kinds of room to spare. The car lost its flat spots at vac to boost transition and at 4k too. Life is good!
I need to play with the SAFC and ITC now on the dyno again to see what kind of power I can make.
Mark
99 RS Turbo www.subaru.stinsonweb.com
Old 05-13-2000, 08:25 PM   #2
JJTheSubeDriver
Member#: 391
2004 STi Blue/Gold
2000 RS BRP
Talking
RIGHT ON!! Can't wait to see your car again, you going to the Autox May 27/28?
JJ
JJTheSubeDriver is offline
Old 05-14-2000, 08:40 AM   #3
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Cool
WOW!! (droooooooooool (ala Homer Simpson)
Hopefully I'll be seing you in a week or two when Robert comes to visit. Man, I hate it when you post news on your car, it makes me even more depressed that I can't have a turbo.
I'll just have to live vicariously through all the turbo guys
Strepto is offline
Old 05-14-2000, 11:28 AM   #4
shiv
Member#: 607
Post
Mark,
Which FPR did you use?
shiv
shiv is offline
Old 05-14-2000, 11:49 AM   #5
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
shiv, hehe wassup..
I gotta question. does the TEC-II affect fuel pressure in any way (if /when I got the tech-II, would a fpr be useless.?
STi Sev is offline
Old 05-15-2000, 12:20 AM   #6
mjos
Guest
Member#:
Post
Shiv: It's the Bell Rising Rate One. Model 20005. Works great!
Colo Guys: Thanks...I'm going to try and make the autocross.
Mark
Old 05-14-2000, 01:12 PM   #7
shiv
Member#: 607
Post
Mark,
Just curious, why did you go for that model and not the other one (#20002)? I would think that the car would run too rich down low at lower boost levels with the 20005.
Sev-- the TEC-II does not affect fuel pressures in any way. In fact, I re-installed the stock fuel pressure regulator. The only fuel mods are 550cc injectors and a high flow fuel pump.
shiv
shiv is offline
Old 05-14-2000, 02:40 PM   #8
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Thumbs up
Mark,
Glad to hear the good news!
rao is offline
Old 05-14-2000, 02:45 PM   #9
mjos
Guest
Member#:
Post
Shiv: After talking with the guys at Bell, they recommended this one due to the boost level I was running and the EGT readings I was getting.
Mark
Old 05-14-2000, 02:45 PM   #10
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Question
Why'd you take it out shiv? Listening to you talk about the fpr made it seem like you liked it a lot...
[This message has been edited by STi Sev (edited May 14, 2000).]
STi Sev is offline
Old 05-14-2000, 03:48 PM   #11
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Sev - with the tec II and larger injectors there should be no need whatsoever for a FPR - that's one of the big benefits of a stand alone ecu
rao is offline
Old 05-14-2000, 05:49 PM   #12
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Question
Shiv, what injectors did you end up with? I am tring to track down 440s. Can you get them for me? I really don't want to mess with fuel pressure's unless I have too.
TIA,
MattC
MattC is offline
Old 05-14-2000, 09:26 PM   #13
shiv
Member#: 607
Post
Matt-- I ended up with low resistance 550cc injectors. You're going to have a hard time getting anything bigger 350cc injectors to work with the stock ECU. You'll also have to use saturated injectors (high resistance) or low resistance with add-on ballasts.
Shiv
shiv is offline
Better bell-ringing song: For Whom the Bell Tolls or Hell's Bells perret318 Off-Topic 39 01-18-2006 01:39 PM
do i install the fuel pressure gauge after the rrfpr? GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-08-2004 05:47 PM
Bell RRFPR (model 20005) - too much fuel? Diz Normally Aspirated Powertrain 5 11-30-2000 06:03 AM
WTB: a Bell rrfpr AdamSTi Normally Aspirated Powertrain 9 10-31-2000 06:41 AM
Shiv..Where did you tie into the fuel return line for the Bell RRFPR? mjos Technical Forum Archive 6 05-08-2000 08:55 AM
