Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 04-06-2006, 10:39 PM   #1
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Default JDM EJ20 Specs
Hey guys, I'm having a JDM EJ20 (from an 05 WRX) swapped into my WRX after having an engine problem, and I'm just looking to get some specs on it.
I know it's still a 2.0L open deck, and makes 246chp instead of the 227chp out of the USDM. I believe redline is the same, but I'm unsure.
It also has AVCS heads, so I was wondering if it was worth it to get a JDM ECU or get a standalone down the road to support this.
I remember hearing something about a higher compression ratio, and was wondering what that would do for my numbers. I currently have a gutted stock UP, Bosal DP, and Bosal catback, and a TXS unichip that I will possibly be hooking up soon.
So anyone that has any true specs for this motor, post 'em here please
Thanks,
Chris
wrxfactor is offline   Reply With Quote
Old 04-06-2006, 11:03 PM   #2
moss
Member#: 10197
It doesnt have a low compression ratio, it has a slighly high compression ratio. 9:1 . I have a MY02 JDM WRX EJ205. Your other specs are correct, though I was told 250chp. Redline is whatever the WRX is (7000-7200? Not sure I'm comming from a 2.5RS).
And yes AVCS heads. I got a JDM ECU with mine, so I'll be using it.
Keith
moss is offline   Reply With Quote
Old 04-06-2006, 11:04 PM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Keith, just found out about the compression, and edited the post. Is it any more responsive to mods with the higher compression or no?
Old 09-26-2018, 07:57 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
nevermind
Old 04-06-2006, 11:09 PM   #5
moss
Member#: 10197
Honestly. I'm not sure yet. My swap is still in the process of being finished (stupid wiring )
I would think with the higher compression ir would allow the turbo to spool faster and require less boost. But I'm still a n00b to turbos and what not.
Old 04-12-2006, 04:52 PM   #6
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Hurry up! The higher compression is nice. the jdm ej205 is a beast
petawabit is offline   Reply With Quote
Old 04-12-2006, 02:06 PM   #7
michaelpatrick
Member#: 101004
I though I had heard that the JDM ej20 has a redline of something like 8500, and that is why it is so appealing to us?
michaelpatrick is offline   Reply With Quote
Old 04-12-2006, 02:12 PM   #8
moss
Member#: 10197
the JDM EJ207s have better heads. Not the JDM EJ205s... read up.
Old 04-12-2006, 04:06 PM   #9
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Yuo, and the redline for the EJ207 is 8k rpm.
Old 04-12-2006, 04:46 PM   #10
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
ah, good call on the jdm wrx motor. I'm not sure why more people don't get them instead of rebuilding ej205's, considering the price that they go for. The compression is 9:1. They have cast or hypernautic pistons, not forged like the sti v7. I believe the pistons have the same construction as the JDM v8 sti. The heads have avcs, which means a jdm ecu controls them. AVCS is the shiz. You want it. Get a jdm ecu to run them. redline is 7200 on the motor. so you know, avcs will lower spool by 3-500 rpms when tuned. It is a solid motor, and a nice performance bump over the standard WRX motor. Great motor for the stg 4 guys. the comp ratio will be fun. Get a reflash for 93 octane and a vf series turbo and enjoy most of what the STi motor is, without the 8k redline.
Hope this answers some questions. I A performance sells a premade avcs harness. I wired my own and it took about an hour, and I'm not wiring savvy.
you could probably use a jdm sti ecu, somewhere could flash it for you.
good choice on the motor. you should be paying between 16-1900 max for the motor, with low milage.
If I can answer any other questions, let me know.
H.
skiblur is offline   Reply With Quote
Old 04-12-2006, 07:00 PM   #11
JRSCCivic98
Member#: 67080
Anymore info on this? I checked their site, but it looks like they are either redoing it or there's no info for anything on it. Anyway, do you happen to have a price or anything of that type of info?
JRSCCivic98 is offline   Reply With Quote
Old 04-13-2006, 12:27 AM   #12
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
I googled and tried to click the link for them and it didn't work, but I clicked the "cached" link and it showed it for $150.00, but it's for a JDM ECU ALSO. As I'm using a USDM ECU, that might be a problem. I'll be contacting them soon though, and I'll let you guys know.
moss, question for you. I believe they are capping a hose or something to do with a coolant line in the rear of the motor near the flywheel. Is there any issue with this, or is it supposed to be hooked up somewhere?
Old 04-04-2016, 02:05 AM   #13
Nuunchi
Member#: 419049
so quick question. How much is the ej205 capabile of? How much boost should I be pushing with my vf23 and how much should I push this motor?
Nuunchi is offline   Reply With Quote
Old 09-26-2018, 07:06 PM   #14
trueno92
Member#: 111755
H.
Really doing the necrobump
RE: AVCS
Does ANYONE have the wiring pinout and what the engine side of the harness looks like?
trueno92 is offline   Reply With Quote
Old 11-05-2019, 08:41 PM   #15
Daymonslegacy
Member#: 508063
Hey so new to the forum I bought a jdm ej205 and plan on using a standalone ecu I plan on using the AVCS now could someone tell me what all I need to make it run I hear about the cam and crank sensors need to be switched to USDM ones does and body know where I can find the intake wiring harness to ecu pin outs
Thanks for the help
Daymonslegacy is offline   Reply With Quote
Old 04-12-2006, 04:53 PM   #16
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
the jdm ej205 heads are still pretty big in terms of intake port. More so than the US sti
Old 04-12-2006, 07:06 PM   #17
moss
Member#: 10197
REALLY? The older ones? the A type ? Production 8/00-9/01?
Super 16g here I come
keith
Old 04-29-2011, 08:59 PM   #18
nedalrabadi
Member#: 244358
1996 impreza
orange & black
what about the JDM EJ20X in the LEGACY 2.0 GT STI
nedalrabadi is offline   Reply With Quote
Old 03-28-2015, 03:14 PM   #19
JMlegacy
Member#: 341649
Your question is years old, but for those wondering, the EJ20x/EJ20y
has big port heads with quad avcs.
The bigger port in this pic is that of the Ej20Y. The other is the USDM STI 257
Buy the heads off a Ej20x if u get it for cheap, then slap on a build bottom end and make power. Rev to 7500, this is redline for ej20Y
JMlegacy is offline   Reply With Quote
Old 03-26-2015, 08:05 PM   #20
Joshields54
Member#: 411615
I know this is an old post but anyone know if the jdm ej205 comes with a slightly different turbo. Or is it exactly the same
Joshields54 is offline   Reply With Quote
Old 03-28-2015, 12:14 AM   #21
jackassofalltrades
Member#: 309550
UNIQ 15' WRX Limited
Galaxy Blue Pearl
Same TD04-13T Turbo as the USDM.
jackassofalltrades is offline   Reply With Quote
Old 10-18-2015, 05:21 AM   #22
bilbo93
Member#: 317073
They actually come with a td04 HL turbo which is slightly bigger than the usdm models. Dont want anyone misinformed from previous posts.
bilbo93 is offline   Reply With Quote
Old 12-11-2015, 11:04 PM   #23
OneManArmy
Member#: 36154
2004 WRX Wagon
Are people not aware that all EJ205's are NOT AVCS?
OneManArmy is offline   Reply With Quote
Old 12-13-2015, 11:18 AM   #24
bilbo93
Member#: 317073
Jdm models came with single avcs
Old 12-13-2015, 11:40 AM   #25
El Guapo
Member#: 234937
2004 STi
20G'd Blue
I think you are unaware that some JDM EJ205s have AVCS.
El Guapo is offline   Reply With Quote
Differences between JDM V9 STI, JDM V9 Spec-A/B/C, & JDM V8 Spec-C (Heads)??? nomorem3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-06-2013 09:57 PM
domestic ej20 versus JDM ej20 subenick Subaru Conversions 15 03-22-2004 07:00 PM
Differences between US EJ20 and JDM EJ20? Lee Chun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-03-2004 09:35 PM
Using a usdm ej20 block with jdm ej20 bottom end, whats the block diffrence with sti Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2003 04:13 AM
Need JDM EJ20 Legacy Motor Specs from the past MY99 2.5GT Legacy Forum 4 05-09-2003 11:44 AM
