Welcome to the North American Subaru Impreza Owners Club Saturday December 7, 2019
Old 11-08-2019, 06:32 PM   #1
electricmarquis
Member#: 407348
2019 Impreza Sport
Grey
Default 2020 ej257 fumoto
Is the 2020 STI still F105 fumoto? All the sites stop at 2019.
electricmarquis is online now   Reply With Quote
Old 11-08-2019, 07:21 PM   #2
byorita
Member#: 470530
2020 is now. im sure they havent updated and r/d yet.
Check the bolt pattern and see if it fits.
byorita is offline   Reply With Quote
Old 11-15-2019, 09:30 PM   #3
Boost.and.freckles
Member#: 508405
Should be
Boost.and.freckles is offline   Reply With Quote
Old 11-16-2019, 11:28 AM   #4
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Before you buy or install a fumoto valve, just google "My Fumoto Drain Valve Leaks"
I have 3 in my garage. Subaru, Honda Toyota. They all leaked, and made a mess in the engine covers and the garage floor.
They were all purchased at different times, properly installed and correctly torqued. They didn't leak from the drain ports, or mating surface, but instead out of the lever mechanism. They say its impossible, but I had the mess to prove it.
You also won't get all of the oil to drain out of your pan. When installed, even with a washer or two, they "reach" into the pan and create a lip which keeps the last bit of oil from draining. Not sure how important this is to you?
Some people swear by them. I happy to endorse a good product, but fumoto valves = POS (for me anyway) Anything that increases the likelihood of unexpected oil evacuation from your engine is no bueno. I'm sure there is someone else here who will tell you how great theirs is. If you get one, check your oil level regularly (which you should be doing anyway)
Here's a thread... first post, mine is leaking, then 5 more, mine is great.
shadowsports is offline   Reply With Quote
