Welcome to the North American Subaru Impreza Owners Club Monday December 16, 2019
Old 11-08-2019, 08:20 AM   #1
closevo
Member#: 268031
2006 Forester XT
Default Rotated 6 Speed Built Forester
Figured I would do one of these since my car was rebuilt. Mods prior to the current build;
Dom 1.5xtr
Perrin equal length header
3" Invidia catless exhaust
ETS 4" front mount intercooler
ETS intercooler piping
Grimmspeed Intake
Cobb 1050x injectors
DW300 fuel pump
ported intake manifold/throttle body
IAG TGV deletes
Perrin turbo inlet
Cobb Flex fuel kit
Grimmspeed lightweight crank pulley
Crawford AOS
Koyo Radiator
Tuned by Cam Tuning
Made 492 hp/475 tq and ran a 12.3 @ 113(5300' altitude)
https://i.imgur.com/CLuTVld.jpg
https://i.imgur.com/o9wrc4Q.jpg
https://i.imgur.com/9yMa1Bn.jpg
https://i.imgur.com/K8jXHmP.jpg
Much more to follow...
closevo is offline   Reply With Quote
Old 11-08-2019, 03:56 PM   #2
closevo
Member#: 268031
2006 Forester XT
Obviously, that kind of power on the stock motor was playing with fire. Ended up spinning a rod bearing last trip to the track. So, further down the rabbit hole we go.
First up, an IAG Built Closed Deck Shortblock.
https://i.imgur.com/u3xpCF5.jpg
https://i.imgur.com/Qs8Rvgx.jpg
https://i.imgur.com/AwOodMn.jpg
And a JDM Forester Sti 6 Speed.
https://i.imgur.com/3OGfUeA.jpg
Brembos after powdercoating and 04 STI BBS' to clear the brembos.
https://i.imgur.com/j7IwEBd.jpg
https://i.imgur.com/0lwCySA.jpg
Old 11-09-2019, 10:23 PM   #3
closevo
Member#: 268031
2006 Forester XT
Old 11-10-2019, 05:35 PM   #4
closevo
Member#: 268031
2006 Forester XT
Engine getting put together. Headwork done; Gsc s2 cams, +1 valves, beehive springs and retainers. Fuel system; radium fuel rails, ID 2000's, Torque solutions fuel lines, Walbro Hellcat 525 fuel pump.
https://i.imgur.com/H4njUE2.jpg
https://i.imgur.com/2Hh0RwJ.jpg
https://i.imgur.com/eDnuBb3.jpg
https://i.imgur.com/O7TEXIZ.jpg
https://i.imgur.com/Lhy5B9Y.jpg
Old 11-11-2019, 07:28 PM   #5
closevo
Member#: 268031
2006 Forester XT
Old 11-11-2019, 07:37 PM   #6
rolagonz85
Member#: 508261
dope!!!!
rolagonz85 is offline   Reply With Quote
Old 11-11-2019, 07:53 PM   #7
rmarchigiani
Member#: 164584
2019 STi Limited
2019 Ascent Touring
Nice sleeper
rmarchigiani is offline   Reply With Quote
Old 11-11-2019, 09:33 PM   #8
trueno92
Member#: 111755
This thread does not disappoint
trueno92 is offline   Reply With Quote
Old 11-11-2019, 09:39 PM   #9
closevo
Member#: 268031
2006 Forester XT
Originally Posted by rolagonz85 View Post
dope!!!!
Originally Posted by rmarchigiani View Post
Nice sleeper
Thanks.
Old 11-11-2019, 09:40 PM   #10
closevo
Member#: 268031
2006 Forester XT
Appreciate it.
Old 11-12-2019, 07:44 PM   #11
closevo
Member#: 268031
2006 Forester XT
Just about done. Only a few things left to finish up. Install the hellcat 525 fuel pump and re-install the interior around the shifter.
https://i.imgur.com/D57ikyg.jpg
Old 11-12-2019, 09:32 PM   #12
atomicsubi
Member#: 506108
This looks like a lot of fun!
atomicsubi is offline   Reply With Quote
Old 11-13-2019, 12:07 PM   #13
closevo
Member#: 268031
2006 Forester XT
From the day I got her back. Was thinking, this thing is gonna be nasty. Makes all kinda spooly noises even outside of boost. Still breaking it in, but only at 1 psi and thing had me grinning.
https://i.imgur.com/IDTEX7j.jpg
https://i.imgur.com/Jnemzs9.jpg
Old 11-13-2019, 04:50 PM   #14
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
Noice!!
fuelMuncher is offline   Reply With Quote
Old 11-14-2019, 06:46 PM   #15
closevo
Member#: 268031
2006 Forester XT
Break in done and car is tuned. 32 PSI on E-85, 8K RPM redline. Car is wild.
https://i.imgur.com/2fpZTkP.jpg
https://i.imgur.com/zZFB3Pz.jpg
Old 11-15-2019, 12:32 AM   #16
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
This is dope! I'd use the bumper space to add some fresh air ducting, but its definitely a sleeper w/out as mentioned above.
JDMJNKY is offline   Reply With Quote
Old 11-15-2019, 12:44 AM   #17
closevo
Member#: 268031
2006 Forester XT
What exactly do you mean? Air ducting for? Curious.
Old 11-15-2019, 11:02 AM   #18
closevo
Member#: 268031
2006 Forester XT
Installed some oem fender flares. Not too wild, just subtle enough.
https://i.imgur.com/Ibx14ow.jpg
https://i.imgur.com/a4DPFLY.jpg
https://i.imgur.com/KnXu3E6.jpg
Old 11-15-2019, 11:51 AM   #19
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
I like the matte grey. Thinking of doing same maybe.
Time for some suspension to handle that monster.
pazzoduc is offline   Reply With Quote
Old 11-15-2019, 12:44 PM   #20
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
Turbo inlet came to mind. But please don't let my thoughts sidetrack the beauty of it all.
Old 11-15-2019, 04:29 PM   #21
closevo
Member#: 268031
2006 Forester XT
Thanks, actually gonna be changing up the color soon. Should be done within the next couple weeks.
I do need to eventually get the suspension done. I'll probably focus on getting that done right before spring before the track opens back up.
Old 11-15-2019, 04:36 PM   #22
closevo
Member#: 268031
2006 Forester XT
Ahh, gotcha. Not entirely worried about it as it's speed density tuned and the IAT sensor is measuring the air temp just prior to the throttle body. Also;
1. The air pre turbo gets cooled by the intercooler.
2. I got the cold side pipe heat reflective wrapped.
3. My intake manifold has thermal dispersant coating.
Old 11-15-2019, 10:41 PM   #23
09slowrex
Member#: 437794
Amazing build. Love those body style fonzies. One tip, you have to get the coolant flowing out of the back of those heads. Personally, I'd install a fitting on the back of both and tee them together and back into the heater core return to water pump. Will run safer on 3 and 4.
09slowrex is offline   Reply With Quote
Old 11-15-2019, 11:00 PM   #24
closevo
Member#: 268031
2006 Forester XT
It's funny you mention that. Im actually gonna be installing the Getadomtune Cylinder 4 Chamber Cooling System mod.
Old Yesterday, 10:18 PM   #25
closevo
Member#: 268031
2006 Forester XT
Minor update, installed a Fuelab 6 micron fuel filter. Should keep my injectors nice and clean.
https://i.imgur.com/qOu2Edt.jpg
