Welcome to the North American Subaru Impreza Owners Club Monday December 9, 2019
Old 11-05-2019, 11:24 PM   #1
Dinner123
Member#: 503482
2010 impreza
Default please help! what is this and why is it suddenly pissing oil
this is on a subaru impreza 2.5i 2010
What is this and why suddenly would it start leaking oil?
https://imgur.com/HPpgt5K
Could this be the camshaft seal and how hard is this to fix?
This was taken from the rear of the engine on the passenger side and it is below the air intake that is next to the firewall
Dinner123 is offline   Reply With Quote
Old 11-06-2019, 12:15 AM   #2
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
Looks like the oil pressure switch could be leaking (highest point with oil around it) Clean the area with brake clean then start it up and recheck.
08SpecB_DE is offline   Reply With Quote
Old 11-06-2019, 09:11 AM   #3
jmcgillis1225
Member#: 508071
2002 WRX Bugeye
Agree with the other guy. Also check your oil cooler gasket. Imprezas are somewhat notorious for cooler gaskets going out. Oilpressur switch is probably it, but check your oil cooler too
jmcgillis1225 is offline   Reply With Quote
Old 11-06-2019, 11:44 AM   #4
Dinner123
Member#: 503482
2010 impreza
Now next day mind you it is -20 and suddenly after driving for a bit the trac control and abs lights both come on haha what is going on??
Old 11-07-2019, 11:12 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
haha?
Old 11-12-2019, 12:40 AM   #6
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
Scan for codes and report back
Old 11-12-2019, 05:19 PM   #7
Gamil
Member#: 220375
2011 Outback Sport
Traction control and ABS are both features of the braking system. Your original problem is with oil on the rear of the right hand Head. Those are different systems and unlikely to be related.
What does "pissing oil" mean? Is it spraying and you could video it? or is it seeping out slowly? If it's the former, please provide video. If it's the latter, do like someone else said and (since it's really cold out) warm the engine up, then turn it off and give it a good hosing down with brake parts cleaner. Then start it and see if you can find the origin. Post more picks.
From the build up it looks like it's had at least a slow leak from the top of the oil pressure switch for a while. That's what triggers the AVLS.
Gamil is offline   Reply With Quote
Old 11-13-2019, 09:20 AM   #8
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
These oil pressure switches are known to leak (the switch with the white connector). Thread in a new one (DO NOT OVERTIGHTEN), clean the residual and call it a day!
CaptainSlowbaru is offline   Reply With Quote
Old 11-16-2019, 05:50 PM   #9
derrick-s
Member#: 508420
Default Oil Leak
I agree with the others but I would take it a step further. Clean and reseal the oil pressure switch and replace the gasket for the cam timing solenoid. Clean and retest. Its super easy and you would eliminate all oil leak problems in this area. The gasket would only cost a few bucks and its 4 bolts to remove the solenoid. I usually go above and beyond like this personally.
derrick-s is offline   Reply With Quote
