Welcome to the North American Subaru Impreza Owners Club Sunday December 15, 2019
Old 08-17-2019, 10:08 PM   #1
lphthephunk
Member#: 505232
Default Hard start, dies when pressing gas
UPDATE: See post 17
Edit: car is 2006 wrx
Hey guys, just finished a rebuild and had a hard time getting it started due to no spark. Figured out the wiring issue, but I'm left with something else.
The car will only start when I have gas fully depressed (fuel cut out), idles rough and smells pretty rich. It also dies if I try to give it gas.
I did the screw driver method to listen to the injectors clicking and they all seem to be clicking. I'm not really satisfied with that though and will still end up pulling the manifold to check them.
Before I start this, I was wondering if there's anything else obvious that might cause this same thing after a rebuild, or just having the battery disconnected for a long time.
I know that the ECU needs time to relearn it's fuel trims, but I wouldn't think the base map would be so bad that it would cut off if I give it gas.
I'm hesitant to let it idle for very long with this issue.
Any thoughts?
lphthephunk is offline   Reply With Quote
Old 08-18-2019, 12:13 AM   #2
lphthephunk
Member#: 505232
Also noticed that there is a tear under the turbo inlet pipe where the clamp goes. Would this be enough to cause this issue?
Old 08-18-2019, 08:28 AM   #3
heiche
Member#: 400179
2009 wrx
Yes, that could do it.
heiche is offline   Reply With Quote
Old 08-18-2019, 05:02 PM   #4
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
Yes that would definitely cause it. Also check for vacuum leaks.
stu is offline   Reply With Quote
Old 08-18-2019, 06:59 PM   #5
lphthephunk
Member#: 505232
So I've got the intake off again, and there is in fact a large rip where the hose clamp goes on at the turbo side. I'll definitely be replacing this with an aftermarket unit, but wouldn't a vacuum leak like this cause a lean condition? I don't know if it explains why I have to cut fuel off in order to start it
Old 08-23-2019, 08:02 PM   #6
lphthephunk
Member#: 505232
Update: replaced the turbo inlet with a Tomei unit, but am still experiencing the same problem. I cleaned the MAF and it briefly seemed okay (ie: I could actually rev it to about 2500 rpm and it would come back down to idle).
When I hade the intake manifold off, I loosely set it back in the engine compartment with the fuel rail attached, hooked up the wiring harness and primed the pump. I could see no gas leaking from the Injectors.
I still have to start the car at full throttle, it will dip and rise in rpm a couple of times and then sit right below 1000rpm. Giving it any gas will cause it to stall.
I'm really at a loss here because I can't explain why I would need to start it in fuel cut out if the injectors are not leaking.
Do you guys have any more ideas? I am coming close to exhausting all options I can think of at this point.
Old 08-23-2019, 10:01 PM   #7
stu
Member#: 25768
2.3 slobaru
Look around for any loose hoses and vac lines. Try resetting the ECU. its one of those thing you have to just keep searching for. What is you Vacuum at idle?
Old 08-23-2019, 11:43 PM   #8
lphthephunk
Member#: 505232
I'll have to hook up a gauge and actually test that, but it's probably the next step. Does this seem like something small I'm just missing? I feel like I'm just going to find something blatantly obvious
Old 08-24-2019, 12:49 PM   #9
heiche
Member#: 400179
2009 wrx
Just to rule out leaks, you might want to do a boost leak test - I usually use < 5 psi. If it doesn't hold that, and it's leaking out, find the leak(s) and correct them.
It could be something else, but a boost leak test is usually a good thing to start with.
Old 08-24-2019, 01:35 PM   #10
lphthephunk
Member#: 505232
Awesome, I will try this as well. Thanks!
Old 08-24-2019, 07:15 PM   #11
lphthephunk
Member#: 505232
Another update: there is gas coming out of my tail pipe. The thing is running pig rich, but the injectors are not leaking. Something is telling the injectors to just push excess fuel. I replaced the front 02 with a new unit when doing the rebuild. Maybe it's a faulty unit?
Old 08-26-2019, 10:59 PM   #12
lphthephunk
Member#: 505232
Bump. Been too busy to run aforementioned tests, but hoping to get some more suggestions to do along with them.
I also took the intake off again and manually tested/cleaned each injector. All are working fine and spraying fine. Still seeing fuel dribbling out tail pipe after a few minutes of idling and seeing some whitish gray smoke accompanying it.
ALSO: I forgot to mention that I did the air pump delete and haven't gotten a tune yet. I wouldn't think that would effect the car this much though.
Old 08-27-2019, 03:16 AM   #13
drewdogg
Member#: 90003
2005 STi
have you tried starting it with the MAF disconnected completely?
drewdogg is offline   Reply With Quote
Old 08-27-2019, 11:21 AM   #14
lphthephunk
Member#: 505232
I did and it hardly starts. Idles incredibly low and dies almost immediately.
Old 08-27-2019, 10:29 PM   #15
lphthephunk
Member#: 505232
It appears I may have gotten ahead of myself with saying that fuel is coming out of the exhaust. It appears to just be condensation dribbling out. There is no fuel odor. I guess I just made a quick assumption due to the signs pointing to rich mixture.
Still haven't figured this out though. Hoping to pressure test intake lines tomorrow or Thursday.
Old 08-28-2019, 06:39 PM   #16
lphthephunk
Member#: 505232
I'm going through my injector plugs to make sure they aren't shorting out. Maybe I'm crazy and my previous leak test wasn't successful after all.
They are getting power when the key is on of course. When I probe their negatives with the key on, I get a very faint light for ground. Is this normal for the fuel injectors? Wouldn't a partial ground like that still trigger the injectors to open?
Old 08-31-2019, 01:26 PM   #17
lphthephunk
Member#: 505232
I found out that injector 4 was not getting a pulse. I suppose it is normal to see a slight ground with the key turned on at the harness. Please correct me if I'm wrong because that could be the whole issue.
I fixed the wiring issue to the #3 injector and replaced the front O2 again just to be sure. Car is still hard to start and is idling pretty rough still. Also, I'm pretty sure it is just condensation out the tailpipe since I'm not getting any black smoke.
For the fuel pressure test, I'm getting 40 psi with just the pump primed, 40 psi at idle, and when I remove vacuum to the FPR I'm at about 42-45 psi.
According to my OBD2, vacuum at idle is about 14 in/hg which is roughly 6psi.
I have a new MAF coming in the mail today just to rule that out.
Thanks again for any replies. It helps me troubleshoot.
Old 08-31-2019, 03:18 PM   #18
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Did you upgrade the injectors during the rebuild?
jeff6666p is online now   Reply With Quote
Old 08-31-2019, 03:19 PM   #19
lphthephunk
Member#: 505232
No they are the stock WRX blue ones
Old 09-01-2019, 07:14 PM   #20
lphthephunk
Member#: 505232
MAF was reading approx 8.0 g/s at idle and short term fuel trims were showing about -14. Looks like the O2 is trying it's hardest to correct the problem. I replaced the MAF and got the same readings.
Why would the MAF be reading so high? It might be worth noting that I replaced this sensor with a Duralast unit from AutoZone. I might try getting one of their OEM refurbished ones. I'd rather not shell out the cash for a new Denso until I know that the MAF is the culprit.
Any other reason why I would be reading so high on the MAF at idle?
Edit: the only reason I've found online for this would be a boost leak. Guess I'm going through the lines again to double check everything. As always, all ideas are appreciated!
Old 09-01-2019, 08:18 PM   #21
heiche
Member#: 400179
2009 wrx
Did you try a boost leak test?
Here is an example I just found:
I usually don't bother capping off everything, but just run low pressure, like 4 or 5 psi. Good idea to remove the oil cap as he says.
Old 09-01-2019, 09:32 PM   #22
lphthephunk
Member#: 505232
Here is an example I just found: https://www.youtube.com/watch?v=MkzuyDuSmbE
Thanks for the link! I'm actually just returning from the store with all the hardware to assemble a tester. I'm going to put it together in the morning and report back with what I find.
Old 09-01-2019, 10:40 PM   #23
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
a boost leak wouldn't happen at idle though. Boost leaks are post-turbo vacuum leaks, and they only cause richness when your turbo is pushing positive pressure.
You could try looking at each of the spark plugs and comparing them to each other to see if one particular cylinder is having an issue.
I've had issues like this before where one of the injectors was so clogged that it was just p*ssing gas on the cylinder wall in one of the cylinders. Getting the injectors cleaned by a reputable shop fixed it.
If you were using the current MAF before the build, I wouldn't suspect that as the culprit, myself. If it IS new to this build, I'd try swapping back to the old one if possible or temporarily swap one with a fellow Subie friend's.
BeastianSTI is online now   Reply With Quote
Old 09-01-2019, 10:47 PM   #24
lphthephunk
Member#: 505232
Thanks, that is very good to know. I had all injectors out prior to this and bench tested them. I squirted carb cleaner through them and supplied 12 volts to each one to open and close the injector. The spray patterns looked okay for being the original injectors. Probably could have been better, but they didn't seem bad.
Old 09-01-2019, 10:57 PM   #25
lphthephunk
Member#: 505232
Also, it is probably worth noting that all cylinders plugs are fouling out equally
