01-21-2002, 10:05 PM | #1 |
Member#: 6375
Vehicle:2004 STi Java Black Pearl |
P1312 - Exhaust Temp. Sensor Malfunction
I just pulled this code from my car.....(2002 WRX)
Does this typically mean that the O2 sensor is screwed? Maybe we goofed it up putting in the new up-pipe & downpipe? (installed them 10 days ago) Any thoughts? Should I just order a new OEM 02 sensor? Last edited by Kenneth2000; 01-21-2002 at 10:12 PM. |
01-22-2002, 09:06 AM | #2 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Check again to make sure their aren't additional trouble codes stored, like P0545, P0546 or P1544. If P1312 was the only code stored, then you'll have to replace the EGT sensor (NOT the O2 sensor) which is located on the uppipe.
03-18-2002, 10:46 PM | #3 |
Member#: 14343
egt sensor malfunction
i am interested in how this was handled. i have an aftermarket uppipe and downpipe as well, and my egt has decided to quit?
03-19-2002, 06:51 PM | #4 | |
Member#: 12012
Re: P1312 - Exhaust Temp. Sensor Malfunction
03-19-2002, 07:30 PM | #5 |
Member#: 2992
NESIC
I happen to subscribe to the theory that the EGT sensor mounting bungs used by most aftermarket uppipes do not allow the sensor to seat properly. This leads, according to my theory, to either a loose sensor or to sensor damage. There probably was a reason why the Service Manual cautioned that the EGT sensor must be oriented in a particular way in the OEM uppipe.
03-19-2002, 11:17 PM | #6 |
Member#: 7962
MWSOC
Vehicle:08 335i TwinTurbo PSM 02WRX, 97 Dipped CRV |
egt sensor
My stock sensor went bad and caused my car to be a paper weight. I finally made SUbaru change the egt probe at MY expense and that solved the problem. $80, then install ed by Subaru only.
This is upseting of coarse. |
04-04-2012, 12:12 PM | #7 | |
Member#: 291964
Vehicle:2011 WRX WRB |
I need help! I believe this is why my car is stuck in limp mode. Just ordered a new OEM EGT probe for it, will be in soon. |
08-31-2012, 12:03 PM | #8 |
Member#: 135007
Vehicle:2014 STi Hatch Crystal Black Silica |
Question: I have a megan downpipe and a stock uppipe with the EGT, and a p1312. Should I do the resistor mod or replace the EGT? Thanks for any advice...
08-31-2012, 03:34 PM | #9 |
Member#: 135007
OK so I went and did the resistor mod and after driving for about a half hour the code was still on so I cleared the ECU. I drove another half hour and so far no code... but I've been fooled before
08-31-2012, 11:24 PM | #10 |
Member#: 135007
I enjoy talking to myself I guess. Maybe it will help someone some day... 70 miles and no cell. Should I get my hopes up? Hard to believe $1.20 in resistors can fix something
Similar Threads | ||||
exhaust temperature sensor malfunction | andrew3776 | AccessPort | 1 | 07-31-2008 08:55 AM |
how to change exhaust temp sensor? | scritchy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 02-05-2007 08:36 PM |
P1312 Exhaust temperature sensor malfunction | NorCalEnthu | Service & Maintenance | 1 | 08-25-2005 12:42 PM |
Exhaust Temp sensor on JDM up pipe | savageblitz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-17-2005 09:08 AM |
stock exhaust temp sensor | wRx137 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 01-16-2003 09:21 AM |
