Welcome to the North American Subaru Impreza Owners Club Wednesday July 16, 2025
Old 08-19-2006, 01:11 PM   #1
dyingsubconscious
Member#: 108179
04 wrx
black
Default downpipe questions and others
Ok so i want to replace me turbo xs downpipe and cat because it hangs to low. I was looking to get one that would be tighter to the body the 2 I have in mind would be the cobb with a cat and the perrin with a cat i just want to know which one fits better.
Another question is will either of them fit up to me turbo xs mid pipe which is 3 inch and the stock style donut gasket
last question is my boost go up to about 14 psi at full throtle and then goes down to about 10 and then hops back up to about 12 and i wanted to know what would be causeing that and how to fix it.
Sean
dyingsubconscious is offline   Reply With Quote
Old 08-19-2006, 03:01 PM   #2
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
i have a 3" catless perrin twin tip with a invida DP catless and mine doesnt hang low
i also got some hangers because the 3" catless exhaust was tapping one of the mounts for the tranny above the exhaust
Fast_Wrx62 is offline   Reply With Quote
Old 08-19-2006, 03:17 PM   #3
STi_671
Member#: 103525
04 iTS
FailedStance
i have an hks carbon ti with and invidia v2 catless dp and it is fine im also sporting the kartboy long hangers
STi_671 is offline   Reply With Quote
Old 08-19-2006, 03:40 PM   #4
FromageTheDog
Member#: 81095
2005 WRX EJ205 weed-
whacker. OS self-tuned!
Crucial Racing all the way, baby.
FromageTheDog is offline   Reply With Quote
Old 08-19-2006, 04:12 PM   #5
o2sys
Member#: 43842
200? WRX STI
Stromung DWG FTW, is cheap, is good quality and known name, is 3" + dwg tube...
http://forums.nasioc.com/forums/show....php?t=1061094
o2sys is offline   Reply With Quote
Old 08-19-2006, 05:08 PM   #6
2.0Tawd
Member#: 92415
2011 OBP WRX
Default question
I too have the turbo xs catless tbe and i am experiencing some banging from what sounds like the downpipe catpipe area. i just installed the exhuast on monday and everything is tight together. My question is do you think that the hangers would help with the problem?
2.0Tawd is offline   Reply With Quote
Old 08-19-2006, 07:18 PM   #7
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
yes it would it did with me, i got some kartboy large hangers i payed 32 for 4 of them
Old 08-19-2006, 07:20 PM   #8
dyingsubconscious
Member#: 108179
04 wrx
black
do you mean banging as in its moving or it's hitting the ground cause with mine theres no way it's moving around. make sure you connected the metal hanger to the tranny mount. you can lift the dp up a bit by puttin the cars jack under it and jacking it up a little and then tightening the bolt but it's still not enough for me im not sure for you.
Old 08-19-2006, 08:25 PM   #9
dyingsubconscious
Member#: 108179
04 wrx
black
no one with a cobb or perrin?
Catback and other FS Oreotsi NESIC Private Classifieds 9 09-07-2010 10:57 AM
Exhaust confusion, Greddy Evo2 and Helix High Flow downpipe, and other STi Q? SkylineR35GTRx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-22-2006 08:31 AM
STI V7 block questions and other internal questions View Askew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-17-2003 02:48 PM
downpipe question and possible buy Wheeler Bement Texas Impreza Club Forum -- TXIC 13 04-02-2003 11:43 PM
kyb warranty question...and others??????? randyHUGE Brakes, Steering & Suspension 4 11-13-2002 01:47 AM
