Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 10-24-2008, 12:24 PM   #1
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Default How much PSI does the A/C pump have?
Not sure if this is in the right forum but I was wondering how much PSI the A/C pump has. I don't use the A/C but have an idea on how to convert it to an air pump. Got the idea from Junkyard Wars and was going to pipe it into a tank. I want to use the A/C pump because it saves room and I don't have to worry about finding a place to mount a pump and running all that extra wiring. I was going to use the custom bumpers for the tank.
J.McDonald Knives is offline   Reply With Quote
Old 10-24-2008, 06:29 PM   #2
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Bump.
Old 10-24-2008, 11:01 PM   #3
hansj3
Member#: 192571
usually the 4x4 people i know use a york compressor. i think the Subaru one is oiled form the freon and the york compressors are either oil less or have an oil system like a car
hansj3 is offline   Reply With Quote
Old 10-25-2008, 12:23 AM   #4
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
I might just have to see if they make a York that will fit in place of the A/C pump.
Old 10-25-2008, 03:44 AM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
almost all A/C pumps are oiled from the freon (sp?) if the pressure of the freon is to low the compressor won't even kick on
scobaru is offline   Reply With Quote
Old 10-25-2008, 04:23 PM   #6
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
The high side pressure can normally be from 150-300 depending on the temperature and a/c load, so no problem filling tires or running air tools.
You can get an in-line oilier & filter meant for air tools and put it on the intake site to make the compressor last longer. Then you just need a pressure switch to tun the pump off over a safe psi limit or a safety valve (or both) and wire it from a dash switch to the compressor clutch. Then make an adapter to fit a quick release air fitting and your good to go.
bobjr94 is offline   Reply With Quote
Old 10-25-2008, 06:30 PM   #7
84cj
Member#: 85261
1993 Impreza L 1.8
white
Pretty much anything and everything you want to know: http://www.kilbyenterprises.com/compressors.htm
84cj is offline   Reply With Quote
Old 10-25-2008, 11:09 PM   #8
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Ya I was reading the whole site last night.
How much psi does cobb accessport raise boost? 123wrx123 Newbies & FAQs 13 01-17-2007 08:20 AM
how much psi can the stock engine hold? norcaliwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-16-2004 03:35 PM
how much *time* does the PS2 have left? IggDawg Off-Topic 24 12-18-2003 02:31 PM
How much heat does the stock turbo generate at 16.5 psi nicktckhoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-21-2002 08:32 PM
