05-23-2013, 08:08 AM | #351 |
Member#: 330507
Vehicle:2015 Jetta TDI Pure White |
That's interesting, i had never noticed before that they are quoting imperial gal instead of us gal.
05-28-2013, 02:21 AM | #352 |
Member#: 329526
SWIC
Vehicle:2013 Impreza Spt cvt Silver |
You mean like above 2000 rpm? My CVT is over 2000 rpm on the flat at the speed limit. Even paddled in 5th gear it won't climb as well as my other identically rated car in high gear.
05-28-2013, 07:10 AM | #353 |
Member#: 354284
Vehicle:2013 Imp Sport CVT SWP |
Your not really comparing the "gears" in the cvt to gears in a reg auto or 5-speed are you? Any cred you had is out the window
05-28-2013, 07:40 AM | #354 | |
Member#: 329526
SWIC
So yes, I'm comparing M mode to a manual transmission. I would try to engage in a constructive conversation with you, but since you attacked right away and showed how little you actually know about it, I'll just leave you as you are, with your head up your A$$. |
05-28-2013, 08:46 AM | #355 | |
Member#: 354284
05-28-2013, 09:06 AM | #356 |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
05-28-2013, 11:14 AM | #357 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
05-28-2013, 06:05 PM | #358 |
Member#: 330507
05-28-2013, 11:31 PM | #359 |
Member#: 329526
SWIC
Yeah, well whatever. The EPA considers AWD vs. FWD n their estimates, that's why the FWD versions of identical cars get better mpg than the AWD versions. But her, if that's too difficult of a concept for you, just go away...
05-28-2013, 11:33 PM | #360 |
Member#: 329526
SWIC
05-29-2013, 12:51 AM | #361 |
Member#: 354284
I'm confused, if your saying that your post is too difficult a concept for me, then finally your right on the money. It started with lots of maturity, then got very hazy in the middle saying I guess, that the only reason the FWD cars get better mpg than AWD is because the EPA considered it in their reports. Then finishes by telling me to go away. Is that an accurate deduction? Besides the incoherent nature of the post, it was off topic as well.
05-29-2013, 01:55 AM | #362 |
Member#: 343343
VIC
Vehicle:2014 Impreza 5dr Ltd SWP |
Explain how this is a valid comparison, as the gear ratios in the two vehicles are probably different (which would obviously effect the fuel economy either positively or negatively when compared at a particular gear).
I don't know what your Corolla uses but for reference these are the gear ratios for the 2013 Impreza (sport package, 5-door) 5MT CVT First Gear 3.454 3.581 Second Gear 1.888 2.262 Third Gear 1.296 1.658 Fourth Gear 0.972 1.208 Fifth Gear 0.738 0.885 Sixth Gear N/A 0.618 Reverse Gear 3.333 3.667 Final Drive Ratio 4.111 3.7 Also, just because two vehicles have similar fuel economy ratings does not mean they will will perform the same in every situation. Last edited by webster354; 05-29-2013 at 02:02 AM. |
05-29-2013, 07:43 AM | #363 | |
Member#: 329526
SWIC
Obviously not - differences in tuning, gear ratios, wind resistance, weight, etc. That is all compensated (yes, including AWD vs FWD) for by the EPA testing. Some vehicles will perform better in some circumstances, others in other circumstances. Unless of course one of them is 5 standard deviations deficient... |
05-29-2013, 08:10 AM | #364 | |
Member#: 299286
Vehicle:2017 Legacy Limited White |
"Subaru's small car is well-rounded, with a roomy interior and compliant ride. Fuel economy is impressive given the standard all-wheel-drive. It's available both as a sedan or hatchback. It's Consumer Reports 2012 Top Pick small car." Ditto for the 2013 Impreza... I know you get all worked up when we point that out...knowing you are just a hack trying to work their data to prove a point that is continually being undermined by the reported mileage, on this forum, from our real, "non-professional" CVT owners, who keep getting those "unattainable" EPA mpg numbers. What is that about 5 standard deviations? And now you have also road tested and failed your holy grail, gold standard, new Toyota corolla, as it also sucks fuel. Must be a sad week for you. Last edited by Zeeper; 05-29-2013 at 09:01 AM. |
05-29-2013, 10:39 AM | #365 | |||
Member#: 329526
SWIC
As for the 2013 Corolla I rented - yes, it only got 33 mpg at 75 mph - but it's only rated at 34 mpg epa highway. |
05-29-2013, 11:35 AM | #366 | |
Member#: 299286
Golly, five standard deviations? Why do you think Consumer Reports, who created the data set you are mining, recommend the car for its excellent fuel economy? Maybe they are not as concerned with "deviation" as you seem to be, perhaps a psychiatrist could help with your unique fixation? Last edited by Zeeper; 05-29-2013 at 02:11 PM. |
05-29-2013, 12:27 PM | #367 |
Member#: 355974
Vehicle:2013 2.0i 5 door dark grey |
some of you worry about stupid $hit
05-29-2013, 08:42 PM | #368 |
Member#: 335945
Vehicle:2013 Sport Limited Satin White Pearl |
And some need to get their thoughts together before posting... Last Edited Again.. Really, I am going to start counting for Socialogical Stats.....
05-29-2013, 09:28 PM | #369 |
Member#: 79498
SWIC
Vehicle:2020 XV |
How many of the people getting unsatisfactory mileage frequently use manual mode instead of just letting the CVT do it's thing?
05-30-2013, 04:50 PM | #370 |
Member#: 219225
Vehicle:2013 Impreza Dark Grey Metallic |
Damn...you get 30mpg on your impreza? I get only 26...average
05-31-2013, 08:36 AM | #371 | |
Member#: 329526
SWIC
I get better mpg with a judicious use of the paddles, but it's still unsatisfactory. |
05-31-2013, 09:15 AM | #372 |
Member#: 89967
Vehicle:2020 Volvo S60 Gray |
^I'd still think you're better setting the cruise control at a reasonable speed and let it do its thing, rather than trying to paddle shift to keep the rpms down.
5 standard deviations aside, do you really think you're supposed to get the EPA mpg driving the speed your driving over rolling hills on the highway? |
05-31-2013, 01:29 PM | #373 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
Any complaint Steve has with the CVT is invalidated now that he's admitted to bypassing its operation. |
05-31-2013, 02:11 PM | #374 | |
Member#: 329526
SWIC
And, I do get the EPA mpg driving the speed I'm driving over rolling hills on the highway. In fact I get better than the EPA highway mpg rating of 36 mpg. In my Corolla. With summer gas I get over 40 mpg driving the speed limit. |
05-31-2013, 02:22 PM | #375 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
But yet a new corolla fails to exceed the epa numbers as well....
There is something to be said about the power band, there are times I can get better mpg in 3rd then 5th gear.... |
