08-22-2003, 01:36 PM | #1 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
Prodrive/UK300 light owners: Help needed
Was sitting at my local Wendy's for lunch just a little while ago; upon gazing at my car head-on, I realized that the orange blinker bulb is really ruining the clean look of these lights. I've noticed this all along, but I guess today I realized it in a different way
Has anyone modded their light so there's no orange blingin' out of the blinker assembly? If so, what type of bulb and wattage will I need? Thanks!!!
08-22-2003, 01:58 PM | #2 |
Member#: 4329
Vehicle:2005 LGT Wagon 5MT OBP |
Phillips makes a Silver Vision bulb that is silver and illuminates amber!!!
http://www.powerbulbs.com/products/p...offer&type=IND |
08-22-2003, 02:09 PM | #3 |
Member#: 16157
South East
Thanks for the link and option. Do you know if the bulbs in that link will work with the Prodrives? And also, the actual bulb is silver coated then? Will that be seen through the headlight assembly lens? I mean I guess silver wouldn't be as obvious as orange, but I was thinking maybe a clear bulb? Don't know if that's possible...
08-24-2003, 10:31 PM | #4 |
Member#: 16157
South East
Bump
08-24-2003, 11:01 PM | #5 |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
I wish I can help. The blinker bulbs were the only unknown piece in the assembly.
However, I don't use my UK300 lights any longer. I crashed at a track in New England and one of the assemblies was basically shattered. I'm back to oem lights now. I'll take out the blinker bulb and give you the info that I can gather. post back in a few days. |
08-24-2003, 11:36 PM | #6 |
Member#: 16157
South East
Bummer xstar That stinks that you have to drive at night w/o the lights. These lights are great - even better since I put HID's in them back in February. I just wanted to clean up the look a bit, so this seemed to be a farily easy and cheap mod Thanks for offering to help. I'll keep an eye on this thread...
08-26-2003, 10:31 AM | #7 | |
Member#: 25254
Vehicle:2003 WRX wagon |
I think this should work based on this thread: http://forums.nasioc.com/forums/show...e+silvervision I have also been thinking about ordering these. (I should just do it and answer this question once and for all.) |
08-26-2003, 04:34 PM | #8 |
Member#: 16157
South East
Orson - thanks for the link and your response. I went ahead and ordered a pair last night. Hopefully they'll get here soon - and if you still haven't bought them by then for your Prodrives, I could send you a pic
08-27-2003, 11:38 PM | #9 |
Member#: 1725
International
Vehicle:2002 Subaru Forester SG silver |
Please post a pic when you get these. I was thinking about using them as well on mine!
08-28-2003, 12:17 AM | #10 | |
Member#: 16157
South East
09-08-2003, 09:18 AM | #11 |
Member#: 16157
South East
Got them installed...
Shoot me a PM or email if you want pics They look schweeet!!!
09-09-2003, 08:51 AM | #12 |
Member#: 8943
TXIC
Vehicle:2006 MINI + Corvette Both Blue |
Thanks for letting us know about this nice mod for us UK300 owners! The pics you sent look fantastic. I've got this down on my "things to do" list for sure now.
GoodFinder |
09-09-2003, 09:03 AM | #13 |
Member#: 16157
South East
You bet!!!
I'm really glad I did this mod. Fairly cheap and it never ceases to amaze me how little things can change your opinions on your own car. I really dig the cleaner look now of the lights...
09-09-2003, 09:19 AM | #14 |
Member#: 25254
Hank3 - I hope you don't mind me sharing the photos you sent. If you do mind, e-mail me and I will take them down.
And for reference, here's my yellow-eyed version: Last edited by Orson; 09-09-2003 at 01:11 PM. |
09-09-2003, 09:53 AM | #15 |
Member#: 16157
South East
Orson - thanks for posting them up for me. Don't mind at all. I couldn't get those sites you referenced to work - or I guess I should say that I didn't really know how to link pics onto there. I've got some clearer/crisper version of those three pics. Email me again with your email and I can send those versions to you and you can post those up here instead? I'll downsize them to 640 x 480? LMK
09-09-2003, 12:34 PM | #16 |
Member#: 1725
International
Yeah, looks great. Thanks for taking the plunge!
Now, a question for you UK300 folk, have any of you wired up your lights using an external relay with direct connection to the battery? So that you get maximum volts to the lighting system? I'm thinking of trying this out when I get the time. I know that there was a 1 volt drop at the high beams on my system using the RAlly Performance harness adaptor, so that is not too good. |
09-09-2003, 01:16 PM | #17 | |
Member#: 25254
Since we have a ground-switched system, though, mulder gave the idea that it would be easy enough to run a fused wire from the battery to the common high wire on the harness. The only question that remains, then, is which wire is the common high? I'll try to make time to run out with a voltmeter. |
09-09-2003, 01:27 PM | #18 |
Member#: 1725
International
Orson, riiiight, I got the relay notion from reading your posts in that one thread discussing this. I will be installing some Hella FF1000's on wednesday with Andrew Bacon (he's an electrician) to help me out. We'll check the wiring out on the headlights and see what we can find.
I'd ideally like to run direct power for both the low and high beams. ya know, make sure that the lamps are getting the max voltage possible. Last edited by Arnie; 09-09-2003 at 01:39 PM. |
09-09-2003, 01:40 PM | #19 |
Member#: 25254
I just did a quick multi-meter. I checked on the OEM vehicle 9007 vehicle-side connector (not at the conversion harness).
The middle wire is the common high and the other two are switched grounds. But it looks like making a direct link from the battery to the common high is only half the problem. With the low-beam and high-beam on, I measured a 1V drop from one switched ground to the battery ground and a 2V drop from the other switched ground to the battery ground. I forgot to measure the voltage drop from the common high to the battery. Doh. Time to study that Rallyperformance harness a little closer. |
09-09-2003, 01:56 PM | #20 |
Member#: 1725
International
Yeah, we got the same 1 volt voltage drop as well.
As an aside, one of my Rally Performance harnesses was completely dead. We tested each of the wires and absolutely nothing. It looked like the wires made no contact to the spades in the 9007 adaptor and they just epoxied the whole thing together. What we did was buy a cheap 9007 bulb and soldered the wires to the base of that bulb after cutting off the bulb part. I'll try to get Andy on this thread as he was doing the meat of the rewiring. Arnie |
09-09-2003, 01:57 PM | #21 |
Member#: 2267
SCIC
Vehicle:00RS rutherforddesign.com |
Arnie- We can wire up a deal so that the OEM circiutry in your car is just turning 3 relays on and off, and the relay switches are making/breaking ground. Also, I think the 16-18 AWG wire that is in there is a bit small for the UK300, definately too small for those monster fogs, but is fine to turn the relays on and off.
You'll have to get some 14 AWG wire, 2 more relays & some split loom. I'll bring up my iron & stuff. I'll draw up a quick scematic ASAP and fax it to you; send me your fax number when you get a chance. Last edited by Andrew Bacon; 09-10-2003 at 03:32 PM. |
09-09-2003, 02:15 PM | #22 |
Member#: 25254
I haven't looked at UK300 wiring closely, but I assume that the input to the UK300 is still one common high and two switched grounds - is this correct? If so, it seems the only way to avoid butchering the UK300 wiring is to use relays to switch the ground and running a fused high wire to each headlamp.
09-09-2003, 02:29 PM | #23 | |
Member#: 2267
SCIC
09-10-2003, 01:23 PM | #24 |
Member#: 25254
Here's Andrew's schematics:
{edit: deleted - see post below} My quick time with a multimeter indicates a common positive on the middle pin, so I guess the second schematic applies here. The second schematic is pretty much what I had in mind. Question, though: isn't the stock UK300 input connector also a single common high? Last edited by Orson; 09-10-2003 at 03:19 PM. |
09-10-2003, 02:48 PM | #25 | |
Member#: 2267
SCIC
Help - Prodrive UK300 lights (aiming revisted) | Hank3 | Electrical & Lighting | 64 | 12-31-2004 03:37 AM |
Once and for all: are Prodrive UK300 lights DOT legal (yes I did a search)? | Orson | Interior & Exterior Modification | 8 | 02-11-2003 10:24 PM |
FS: Prodrive UK300 lights. Local to STL only! | RacerinLSL | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 06-03-2002 03:49 PM |
Installed my Prodrive-UK300 lights! | RacerinLSL | Interior & Exterior Modification | 6 | 05-21-2002 05:04 PM |
check out my prodrive uk300 lights | christoph1371 | Interior & Exterior Modification | 6 | 12-15-2001 04:52 PM |
