Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 05-16-2007, 05:18 PM   #1
snowcrzy
Member#: 110895
Default delete
archived.
snowcrzy is offline   Reply With Quote
Old 05-17-2007, 08:58 PM   #2
snowcrzy
Member#: 110895
Somone has to have some idea...!
Old 07-13-2009, 03:07 PM   #3
kidofdoomz
Member#: 163848
2007 WRX STi
Obsidian Black Pearl
did u figure this problem out?
kidofdoomz is offline   Reply With Quote
Old 07-13-2009, 03:13 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The original posts are really old. You should have started a new thread on this I think.
If you have no power when you turn the ignition ON I suggest you first check all the fuses in the main panel under the hood. Check them carefully as folks seem to miss bad fuses on the first.
Old 07-13-2009, 04:26 PM   #5
snowcrzy
Member#: 110895
no i just gave up and threw the car in the trash.
HELP! Where is the ignition fuse on an 08' 2.5i Steckers Electrical & Lighting 1 05-01-2010 11:04 AM
Where is the tail/illum. relay fourstrokephysics Electrical & Lighting 2 04-21-2006 02:01 AM
Where is the power window relay or power window circuit breaker iam1ru12 Electrical & Lighting 0 03-15-2005 01:58 AM
where is the fuel pump relay? bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-11-2004 10:47 AM
where is the ignition coil? dandbest Normally Aspirated Powertrain 5 05-09-2001 12:25 AM
