Welcome to the North American Subaru Impreza Owners Club Monday August 20, 2018
Old 01-18-2006, 01:51 PM   #1
gqchynaboy
Member#: 88529
Default 04-05 STI Headlights in 04-05 WRX - Need Relay?
I bought a wire harness from chaiofangimports.com so I can use 04 STI headlights in my 05 WRX and it works great, however I was reading that you need a relay or else you can cause serious damage to fuse boxes, ecu, etc. Or is the WRX Wiring good enough and I don't need a relay?
gqchynaboy is offline   Reply With Quote
Old 01-18-2006, 02:24 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The important thing is to have the ballasts directly grounded and NOT use the factory switched ground from the original low beams.
Old 01-18-2006, 02:26 PM   #3
gqchynaboy
Member#: 88529
^^ Yea the wire harness I bought from him directly grounds to the fender. So I should be okay? No relays needed?
Old 01-18-2006, 02:32 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I haven't looked at one of those harnesses so be sure that the ground is actually connected right to the ballast. As long as it is, you're good. A relay certainly won't hurt if you want to add one, but isn't absolutely necessary. The factory headlight power circuits should support the HIDs, I've had no problem with this in the 02.
Old 01-19-2006, 01:16 PM   #5
gqchynaboy
Member#: 88529
How long have you been runing HID system on ur 02 on stock wires? I have ran S2000 and A6 ECE on my old car on my stock wiring, but really didn't have any problems.
Old 01-19-2006, 01:23 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Almost 4 years. Not all stock wiring, just the factory headlight power. The ballasts are directly grounded. The factory power circuits are adequate since each side has its own feed with a separate fuse and relay, it's the switched ground wiring that isn't up to the task of powering HIDs.
Old 01-19-2006, 02:11 PM   #7
gqchynaboy
Member#: 88529
But you did install some relays? correct? I'll try to take some pictures tonight of the wire harness I got.
thx 4 your help!
Old 01-19-2006, 02:14 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I have no additional relays. Not saying that's how you should do it, but that's what I did.
Old 01-19-2006, 02:32 PM   #9
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I also have several years experience running the 04 STi HIDs on both my 04 and 05 WRX. I directly grounded the ballasts and used the existing positive power wires. No problems at all. IIRC, the power supply routing is the same for both the STi and WRX, so there is a relay and 15A fuse for the power to each headlight. I figured if Subaru used the same power supply, so would I.
jac04 is offline   Reply With Quote
Old 01-21-2006, 11:49 AM   #10
wagons_ho!
Member#: 16574
There's relays already in the circuit, and 15A fuses. Having the fender ground is the most important thing... and I've got that covered.
wagons_ho! is offline   Reply With Quote
Old 01-25-2006, 05:40 PM   #11
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
If the ballast is grounded directly to the fender, how does the switched ground from the car turn the light on and off? Is it connected to some other wire on the ballast?
DjRez4 is offline   Reply With Quote
Old 01-25-2006, 05:42 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It doesn't, and it doesn't need to. The headlight power is switched when you turn the headlight switch on and off, and that will control the power to the HIDs.
WTB: 04-05 STi Headlights in good shape. Samurai_jim Private 'Wanted' Classifieds 0 01-08-2009 12:46 AM
05 sti headlights in 04 wrx RobWRX04 Interior & Exterior Modification 5 10-11-2008 12:34 AM
05 STI headlights in 05 WRX v8eaterWRX Interior & Exterior Modification 4 09-23-2007 05:01 PM
WANTED: 04-05 STI Headlights and 04-05 WRX or STi seats ProdriveRex NWIC Private Classifieds 5 07-23-2006 11:18 PM
WTB : 04-05 STi headlights & 04-05 tail lights STi-JDM Private 'Wanted' Classifieds 8 07-15-2006 09:55 PM
