04-22-2014, 01:32 PM | #26 |
Member#: 230462
Vehicle:2006 STI WRB |
I just had to do this on my 2006 STI, same problem I had on my used 2002 Impreza OBS with the clock. It's so annoying that this is such a common and widespread problem. But thanks to handy DIY's like this, I've been able to fix both cars. Thanks again luftpirate, instructions are clear and correct to the tee and worked like a charm! The only thing I would add is, be careful not to lose the small white cylindrical bumpers, I think there are 4 of them, that cushion the two mirror halves. One of mine fell out and I was lucky enough to find it right outside the driver's side door. They look like little white mechanical pencil erasers. Probably not a big deal if you're missing one, but I like to know absolutely nothing is missing from my car!
06-09-2014, 12:16 AM | #27 |
Member#: 393103
Thanks luftpirate
Thanks, luftpirate. I had the same dim mirror-compass problem: now the direction shines brightly after thirty-minutes work.
06-29-2014, 10:56 PM | #28 |
Member#: 283110
Vehicle:2007 WRX w/vf39 Silver |
My compass stopped working right after I bought my car (used) and it's up and running again. Thanks a million.
07-31-2014, 09:28 AM | #29 |
Member#: 212379
Vehicle:2011 WRX Limited 4dr Spark Silver Metallic |
I can confirm that this also works on the 2011 WRX's mirror compass.
I imagine that might lump the 2008-2013 years in (since they have practically the same body). |
08-03-2014, 12:56 AM | #30 |
Member#: 53916
NESIC
Vehicle:16 19 ND RF / 818s Soul Red/ Gel coat red |
Awesome fix. Going to test this out on my 07 FSXT soon. Thanks for posting.
08-07-2014, 06:24 PM | #31 |
Member#: 359706
Vehicle:2010 WRX Premium Lightning Red |
Worked for my 2010 wrx
10-22-2014, 09:55 AM | #32 |
Member#: 61721
Vehicle:2006 WRX Steel Grey Metallic |
Hey luftpirate, what's your paypal email addy? I need to buy you a beer.
11-17-2014, 11:49 AM | #33 |
Member#: 406532
Vehicle:2010 Forester |
Worked for Me!
I completed this repair on the mirror/compass for my 2010 Forester. The hardest part was opening the mirror's clamshell. I chewed up the plastic a little bit, but nothing that a bit of filing didn't fix. (Honestly, I tried using plastic tools to open the clamshell, but they didn't do the job. I had to go with metal, unfortunately.) I had bought a replacement metal spring clip for the mirror's mount, but I ended up not needing it. I removed the mirror and replaced it with no problem. The spring clip still holds tightly.
Thank you for the tip that saved me $135 or more. |
01-25-2015, 12:13 PM | #34 |
Member#: 411822
Luftpirate is a genius - Thank you!!
From a fellow Cincinnatian, I would like to offer my extreme gratitude for Luftpirate. I thank you for your service to the city, the nation and the Universe. You are a gift to humanity.
My compass is now shining brightly. I used guitar picks to hold the clips open as I worked my way around the mirror to get it separated. Pushing on the resistors didn't make it come on but I don't think I had the "Compass" button pressed - the right sided button. I simply bought tiny solder from Radio Shack and melted some on the tip and touched it to the sides of those resistors as described. The end result looked like Luftpirate's photos. I plugged it in and the compass came on bright immediately. I danced around the car like a lunatic for 3.5 minutes. Every time I see that bright compass it will remind me of Luftpirate, a shining star in this beautiful world. Thanks Man!!! |
05-06-2015, 03:25 AM | #35 |
Member#: 301299
TXIC
Vehicle:2006 Forester 2.5XTL Urban Grey Metallic |
You're a genius OP. Worked in my 06 FXT. Thanks so much! So worth the Radioshack ripoff on flux. Whatever that is.
Last edited by leadguitar27; 05-06-2015 at 03:26 AM. Reason: spelling fix and additional thanks |
06-09-2015, 03:28 PM | #36 |
Member#: 94519
On my other car a 2007 Honda Accord OEM mirror with compass...same circuit board, resoldered the top resistor as described. Boom! Got my compass back nice and bright. Thank you OP...you rock
07-13-2015, 07:26 AM | #37 |
Member#: 424035
RMIC
Vehicle:2011 Impreza 5 door Black |
I wonder if it would be possible to reflow the whole board using a heat gun or something. I could just carry it to my buddy and have him stick it through the wave soldering oven at his job.
07-13-2015, 01:11 PM | #38 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Dipping an already assembled board in the tank would probably trash it, I'd just do the spot repair.
12-26-2015, 08:53 PM | #39 |
Member#: 434866
Yipper. That worked.
A little late after the original post. I just performed this fix tonite, Dec. 26, 2015. It worked fantastic. Nice bright letters now. But I would get a smaller soldering iron if I do this again. One of the resistors popped off and I needed a tweazer to find it and put back on. ALSO my board was covered in bad/cold solder joints. But I only fixed the biggest ones, the resistors on your photo, plus the ribbon going to the N/S display. Thanxxx!
01-11-2016, 05:48 PM | #40 |
Member#: 306730
SCIC
Vehicle:2011 WRX OBP |
thanks for the info. My has been dim for a year.. finally got tired of it. Done!
02-02-2016, 10:20 PM | #41 |
Member#: 134262
Vehicle:-1 centrifugal bumble-puppy |
So it looks like I've got this going on too...
what iron are people using? Would a fine tip butane torch iron work? Alternatively, has anyone tried solder paste (http://www.amazon.com/MG-Chemicals-4860P-35G-Solder-Paste/dp/B00M1RC0YY) or conductive glue: Silver Conductive Wire Glue or would that not hold up to the heat and vibration of a car over the long term? (and altho I haven't done is yet, thanks Luftpirate for this fix!) |
05-15-2016, 08:16 PM | #42 |
Member#: 400886
NESIC
Vehicle:2004 STi PSM 2010 STi SSM Hatchback |
Even since this is basically a zombie thread seems i am not the only one getting help from this so just wanted to thank the OP for the great writeup. Just fixed this on the wifes 2009 Forester we just picked up the other day and writeup was very good.
Pohenegamook, i would definitely advise against a butane iron as it may be to hot for PCB work. You want limited temp and plenty of flux/good solder to let it flow without heating it up too much. |
07-22-2016, 11:39 AM | #43 | |
Member#: 270358
02-12-2017, 07:29 PM | #44 |
Member#: 438620
Vehicle:2006 WRX Sedan CGM |
Just did this yesterday, big thanks to OP. 20 min work and it looks new!
03-03-2017, 04:09 PM | #45 |
Member#: 420754
Vehicle:06 Impreza Outback Silver |
Hello all!
Stumbling upon this thread gave me great joy after experiencing this issue in my 06 Impreza for 4 years. Upon getting the circuit board out and detached I noticed something that does not look promising. There seems to be a smudge/burn on the display window and I am wondering if maybe this is the reason why my mirror display no longer works. Any thoughts? (See images below) Thanks! |
03-04-2017, 08:19 AM | #46 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
There is still some air inside so they have a small metal pad that they apply voltage to once to consume the remaining oxygen, thus the spot. If you find the "clock repair" thread (same issue, failed solder joints) the spot you show is covered there as well. In short, not the issue, you need to fix a likely bad solder joint. |
03-04-2017, 03:45 PM | #47 | |
Member#: 420754
06-23-2017, 11:32 AM | #48 |
Member#: 469802
Additional Info
Thanks Luftpirate for posting this helpful fix! I have performed this fix at least 3 times on my 2010 Forester. Apparently, the constant expansion and contraction from hot and cold takes its toll on those tiny resistors and I eventually have to make the repair again.
The last time I did the repair, about 2 years ago, I reinforced the solder joint with a small piece of very thin wire. I figured even if the joint split open again, maybe the wire would allow for expansion and carry the current through the circuit. This also allowed me to add a little more solder to the joint. So far so good! 7-31-18 update: Had to go in and repair it again, but at least my previous repair lasted about 3 years! I also wanted to add that I live in North Carolina, so the summers are pretty brutal on a car interior. For today's repair, I had some plastic Spudger tools, an old plastic Walmart Gift Card, and a 1.0 mm guitar pick. I must say, out of this set of tools, the guitar pick was the easiest to work with as it worked into the crack easily and was easy to move around the outside of the mirror. Thanks again Luftpirate!!! Last edited by GuiTarzan6405; 07-31-2018 at 07:52 PM. |
08-01-2017, 07:45 PM | #49 |
Member#: 327448
Thank you for this! I just followed this to repair the compass in my 2009 Impreza.
01-20-2019, 12:08 PM | #50 |
Member#: 210924
Vehicle:2002 WRX Wagon That bluish/blackish one |
Digging up the dead in 2019. Found this link over on the Forester forum, and subsequently fixed the compass in my 07 XT using the info. Many thanks to Luftpirate for write-up!
Wtb: 06 -07 Wrx Clutch | Fast06wrx | Private 'Wanted' Classifieds | 3 | 11-10-2011 09:55 PM |
FS : 06 -07 wrx v-limited style lip | NMZ_WRX | SCIC Private Classifieds | 21 | 07-14-2011 06:17 PM |
WTB : 06 -07 wrx rear diff | dunham06 | Private 'Wanted' Classifieds | 0 | 12-23-2010 06:22 PM |
FS/FT : Cobb Accessport V2 (AP-SUB-002 - 06 -07 WRX/STI) $425 OBO | deftonez99 | Engine/Power/Exhaust | 4 | 10-23-2010 01:45 PM |
FS: (Socal) Cobb Stage 2 for 06 -07 WRX (280HP), AccessPort + TXS turboback [$750] | ungarisch | Engine/Power/Exhaust | 6 | 01-29-2009 07:24 PM |
