#1 |
Member#: 269042
Vehicle:2011 DGM STI Sedan |
![]() Howdy friends,
So I've been chasing an engine code that seems to jump and I need a bit of support so I don't spend more money than I have to as these small fixes tend to add up. Recently I've had issues with a jumping P2442 and a P2443 code. They both seem to be related to the Secondary Air Injection system valves. I've removed the intercooler and sprayed the air injection system with WD-40 and PBB which clears the codes temporarily but it always seems to return back to one of these two codes. P2442 - Secondary Air Injection System Switching Valve Stock Open (bank 2) P2443 - Secondary Air Injection System Switching Valve Stock Closed (bank 2) Is there an alternative fix to this, or am I left replacing a nearly $400 part? Thanks guys
#2 |
Member#: 269042
![]() RockAuto solves the day.
#3 |
Member#: 512891
Vehicle:2010 STi/21 Passport RIP 19 WRX & 16 FXT |
![]() From everything I read you would have to replace it or remove the system and have the CELs tuned out. I don't have a problem with mine for now but I will be removing it when I have the chance.
#4 | |
Member#: 269042
![]() Quote:
After replacing the system, I'm considering if there's a lubrication or maintenance schedule that should go into the valve to prevent it from seizing again before natural condensation makes it rust out again. 11 years isn't a bad run though. |
#5 |
Member#: 269042
![]() Thought replacing the valve would be the solution but the P2443 code still persists. I inspected the internals of my secondary air valve and the condition was fair and there were no visual traces of rust that I could see.
I've reset the battery since replacing the valve and it seems to only trigger upon starts in the first/morning start up. Driving the car while it's warm does not trigger the P2443 code. I wonder what else could be causing this issue. |
#6 | |
Member#: 531989
Vehicle:2011 STI World Rally Blue |
![]() Quote:
